Beoplay H9 Over-Ear Active Noise Cancelling Headphones
Built just like B&O’s previous active noise cancelling make (the H8), Beoplay H9 is the over-ear active noise cancelling headphones we have all been waiting for.
Meet Beoplay H9 Over-Ear Active Noise Cancelling Headphones
Beoplay H9 displays the same gorgeous exterior as the rest of the B&O family – minimal yet fab. The earcups are comprised of luxurious lambskin leather filled with adaptive memory foam. This makes for a comfortable pair of cans that adapt to the shape of your head and ears – perfect for long listening sessions or lengthy plane rides.
Beoplay H9
Beoplay H9 is more than just a beauty, it’s got brains too. One of the ear cups acts as a user interface optimized with smart gestures. Simply slide your finger up and down to turn active noise cancelling on and off. A single tap on the center of the surface will pause or play your music as well as answer an incoming call. Gliding your finger along the outer rim of the surface will adjust the volume.
The H9 holds a replaceable and rechargeable Lithium-Ion battery that powers the over-ear headphones for up to 14 hours with Bluetooth and active noise cancelling technology engaged. You can achieve a full 16 hours with only Bluetooth running and a whopping 21 hours when active noise cancelling goes solo while only taking a mere 3 hours to charge.
The H9 uses 40mm electro-dynamic drivers to provide detailed audio along a frequency range of 20 to 22,000 Hertz. If you’re looking for wire-ree luxury you’ll find it in Beoplay H9 for $499. Snag yours at B&O.com.
Previous articleNew Release: Beyerdynamic Xelento Hi-Res In-Ear Monitors
Next articleChoosing the Best Westone Earphone for Audiophile Music Listening
