Here’s Your Rave Starter Pack: Philips Nitro LED Speakers & Headphones
Philips Nitro LED Headphones & Speakers
Philips Nitro just launched a line of light-up audio products for your amusement. Consider these Philips Nitro LED headphones and speakers items part of your home rave starter pack.
The LED line consists of a speaker, headphones, and in-ear monitors – all of which are said to light-up simultaneously with your music creating a rave-worthy light show in your home.
The NTX400 is a tower speaker. It uses Bluetooth to play music from your cellphone, tablet, and other smart devices. The USB port can be used as well. Moreover, the speaker has the incredible ability to play compact discs. Retro ravers that one was for you! The 1000W speaker houses 260,000 LED lights that I’m pretty sure will create a show that will put Coachella’s Sahara tent to shame. The NTX400 should also come close to supplying one of those face-melting bass drops with a feature called “NX Bass.” It’s a bass booster.
The HX50s are the LED headphones. They obviously display a simpler light show also pulsed to your music. Unfortunately (or fortunately?) onlookers will see the light show rather than you. But, if you’re all about that PLUR life, sharing is caring so “Light shows for everyone!” The LED display can be turned off whenever you decide your waking rave is over. This can be done by pushing a button on the left ear cup. The HX50s are said to provide an auditory experience as amazing as the lights, with “deep bass and powerful sound.”
For those who would rather provide a teaser of a rave can opt for the HX10 LED in-ear monitors. The earbuds also have an added bass feature called Bass Reflex Port. The LED lights in both the in-ear and over-ear model are powered by a built-in battery that should last between six to eight hours.
The Philips Nitro LED products are already available in Europe. The NTX400, HX50, and HX10 currently retail for 399.99 GBP, 49.99 GBP, and 29.99 GBP, respectively.
Previous articlePokémon Go Headphones for the Poké Enthusiast
Next articleMurel Zero Wireless Buds
Sade
