HomeIndustry NewsHow Apple Is Bringing Lossless Audio To The AirPods Max
Bluetooth headphones have many advantages, but you might not be aware that most of them don’t support the lossless audio that most modern music streamers offer. Bluetooth headphones use CODECs to decode audio signals when listening wirelessly, with information being lost through transmission. This has been an issue for Apple users longer than other brands due to the iPhone only supporting AAC and SBC CODECs, while Android users can listen through better formats like LDAC and aptX.
While there have been no updates as to when Apple will start to integrate more Bluetooth audio formats, they have just announced a way AirPod Max users can get the most out of Apple Music lossless streaming. Next month, the Apple Airpods Max are getting a major software update. This update allows you to experience lossless and ultra-low latency audio through the Apple Airpod Max USB-C connection.
Lossless Audio for the Ultimate Listening Experience
Using the AirPods Max wired through USB-C will allow you to listen to Apple Music and other lossless streaming services with sample rates up to 24bit 48kHz. The highly acclaimed Focal Bathys also has a similar function, and this new update will soon allow you to use the AirPod Max the same way. It is a way to enjoy the sound of the AirPod Max completely uncompressed, allowing you to listen to tracks with more clarity and definition. More or less, this is a way of experiencing music through the Apple Airpods Max the way the artist intends, with nothing getting lost in translation.
Lossless streaming through the Apple headphones Max and Apple Music could also enhance spatial audio tracks. Especially with Apple Music’s extensive spatial audio library, Apple music lossless streaming has the opportunity to unlock more depth from the AirPods Max. If more precision can be extracted from lossless spatial audio streaming, the AirPod Max can be even more impressive with better immersion.
Seamless Gaming and Livestreaming Performance
Ultra-low latency is also part of Apple’s upcoming firmware update, which aims to significanlty upgarde game audio performance on the Apple Airpods Max. USB-C wired listening with the AirPod Max will allow for listening without lag. If you use your Apple headphones Max for games and livestreaming, your audio will benefit from real-time audio synchronization without dealy.
When Can You Expect Lossless Audio With The AirPods Max?
A free firmware update will be availble for the AirPod Max sometime in April. It will be compatible with iOS 18.4, iPadOS 18.4, and macOS Sequoia 15.4 for AirPod Max with USB-C.
The Apple AirPods Max Compatible Products at Audio46.
