After months of speculation, Apple has finally revealed its latest Airpods. However, these aren’t your standard true wireless earphones that you’re used to seeing. Instead, the latest Airpods, called Airpods Max, are tried and true over-ear wireless headphones. This is a first for Apple and a major leap forward for Airpods as a brand. With the Airpods Max, Apple looks to deliver high fidelity audio with noise-cancellation and a ton of added features.
The Airpods Max will use precise craftsmanship to accomplish the best acoustic design possible. The breathable knit mesh canopy, spanning the headband, is made to distribute weight and reduce on-head pressure. The stainless steel headband frame provides strength, flexibility, and comfort for a wide variety of head shapes and sizes. Telescoping headband arms smoothly extend and stay in place to maintain the desired fit.
- Adaptive EQ: AirPods Max uses Adaptive EQ to adjust the sound to the fit and seal of the ear cushions by measuring the sound signal delivered to a user and adjusting the low and mid-frequencies in real-time — bringing rich audio that captures every detail.
- Active Noise Cancellation: AirPods Max delivers immersive sound through Active Noise Cancellation so users can focus on what they are listening to. Each ear cup features three outward-facing microphones to detect environmental noise, while one microphone inside the ear cup monitors the sound reaching the listener’s ear. Using computational audio, noise cancellation continuously adapts to the headphone fit and movement in real-time.
- Transparency Mode: With AirPods Max, users can switch to Transparency mode to simultaneously listen to music while hearing the environment around them — ensuring everything, including a user’s own voice, sounds natural while the audio plays perfectly. Switching between Active Noise Cancellation and Transparency mode can be done with a single press using the noise control button.
- Spatial Audio: AirPods Max uses spatial audio with dynamic head tracking to place sounds virtually anywhere in space — delivering an immersive, theater-like experience for content recorded in 5.1, 7.1, and Dolby Atmos. Using the gyroscope and accelerometer in AirPods Max and iPhone or iPad, spatial audio tracks the motion of a user’s head as well as the device, compares the motion data, then remaps the sound field so it stays anchored to the device, even as the user’s head moves.
- Automatic switching allows users to seamlessly move sound between iPhone, iPad, and Mac. When playing music on Mac, users can easily take a call on iPhone and AirPods Max will automatically switch over.
- Audio Sharing makes it possible to easily share an audio stream between two sets of AirPods on iPhone, iPad, iPod touch, or Apple TV 4K. Simply bring AirPods Max near the device and connect with a single tap.3
- Siri capabilities include the ability to play music, make phone calls, control the volume, get directions, and more. Siri can also read incoming messages as they arrive with Announce Messages with Siri.
AirPods Max is available to order starting today for $549 (US) from apple.com and in the Apple Store app in the US and more than 25 other countries and regions. AirPods Max will begin shipping on Tuesday, December 15.
