HomeReviewsBest Noise Cancelling HeadphonesBeyerdynamic Aventho Y vs. Sennheiser Accentum: Which Wireless Headphones Are Better?
The affordable wireless headphone market offers more compelling choices than ever, with established audio brands bringing their distinctive sound signatures to increasingly accessible designs. The Beyerdynamic Aventho Y and Sennheiser Accentum both combine active noise cancellation, companion-app features, long battery life, and spacious sound, but they emphasize different strengths. The Aventho Y focuses on durability, powerful bass, and an unusually wide presentation, while the Accentum offers stronger codec support, effective noise cancellation, and a lightweight, comfortable fit. Which wireless headphone is the better choice?
Aventho Y Accentum
  • AVENTHO Y
  • USB-C CHARGING/
    AUDIO CABLE
  • DRAWSTRING BAG
  • ACCENTUM Wireless headphones
  • USB-C charging cable
  • Quick guide
Both headphones use fairly simple designs, but the Beyerdynamic Aventho Y feels like the more durable product. Its colorful, somewhat playful look may not be as sophisticated as Beyerdynamic’s more expensive headphones, but the aluminum yokes add stability to the frame. Its replaceable battery and interchangeable ear cushions also make the Aventho Y a more practical long-term investment.
The Sennheiser Accentum resembles a smaller and more affordable version of the Momentum 4. Its mostly plastic construction does not feel as premium as the Aventho Y, but the lightweight frame makes it very comfortable. The smaller earcups still surround the ears properly, while the moderate clamping force keeps the Accentum comfortable during extended listening sessions. The Accentum has the advantage in lightweight comfort, but the Aventho Y offers the sturdier and more serviceable design.
The Aventho Y provides active noise cancellation, adjustable EQ, and personalized sound settings. Its ANC performance is adequate for commuting and everyday environmental noise, although it is not especially powerful compared with the best noise-canceling headphones in this category.
Sennheiser gives the Accentum a more developed selection of software features through the Smart Control app. Users can adjust the EQ, create Sound Zones, and use Sound Check to develop a personalized tuning. Its noise cancellation also feels slightly more effective than the Aventho Y’s system, even if it does not reach the performance of Sennheiser’s Momentum series. Listeners who prioritize customization and ANC should lean toward the Accentum. The Aventho Y covers the essentials, but its functionality is more straightforward.
The Aventho Y uses Bluetooth 6.0 and supports multipoint pairing. Its connection is fast and stable, but codec support is limited to SBC and AAC. This should be sufficient for most casual streaming, although Android users looking for a higher-quality Bluetooth codec may find the selection restrictive.
The Accentum uses the older Bluetooth 5.2 standard, but it maintains a similarly reliable connection. More importantly, it supports SBC, AAC, aptX, and aptX HD. That broader codec compatibility gives the Sennheiser an advantage for listeners using compatible Android phones and other aptX-enabled sources. The Aventho Y offers the newer Bluetooth version, but the Accentum wins for codec support. These connectivity differences are outlined in the original Beyerdynamic Aventho Y review and Sennheiser Accentum review.
Battery life is one of the Aventho Y’s biggest strengths. It offers up to 90 hours of playback with ANC turned off and approximately 60 hours with noise cancellation activated. These figures put it among the longest-lasting wireless headphones in its price range. The Accentum supplies up to 50 hours of playback. That remains excellent for an affordable wireless headphone and should easily cover several days of regular use, but it cannot match the Aventho Y’s endurance. Both headphones perform well here, but the Aventho Y is the clear winner for battery life.
 The Aventho Y produces an impressively wide soundstage for a wireless headphone in this category. Its left-to-right spread feels expansive, with precise placement helping individual instruments maintain their own space. It is not especially deep or open, but its organized presentation makes the Aventho Y sound larger and more sophisticated than expected. The Accentum also delivers a wide stereo image with distinct left and right channels. It supplies accurate positioning and even introduces some height, particularly around vocals. However, its layering does not create much depth, and the spatial presentation feels slightly less organized than the Aventho Y. Sennheiser provides a respectable sense of space, but the Aventho Y offers the more convincing soundstage.
Bass is prominent on both headphones, although the Aventho Y presents it with greater depth and control. Its low end is thick, punchy, and supported by a satisfying sub-bass bloom. The bass possesses enough impact to sound energetic without becoming bloated or muddy, giving the Aventho Y a good balance between natural tone and entertainment.
The Accentum also uses an elevated bass response. Its low end feels full and impactful, with enough underlying rumble to support its thicker textures. It remains relatively clean, although much of its detail stays closer to the surface. Additional bass can be introduced through the EQ, but the default tuning already supplies sufficient weight. The Accentum has an enjoyable, consumer-friendly bass response, while the Aventho Y provides better definition, extension, and tonal character.
The midrange creates the most significant distinction between these headphones. The Aventho Y maintains a full and energetic response that complements its powerful bass. Its resolution is not exceptional, but instruments retain authority and separation rather than becoming overwhelmed by the low end.
The Accentum follows a more noticeable V-shaped tuning. Its lower and upper mids receive some emphasis, but the center of the range sounds recessed and hollow. Hard-hitting genres can still sound engaging, though more dynamic or midrange-focused recordings may lack body and detail. Neither headphone delivers a perfectly neutral midrange, but the Aventho Y is more consistent and better balanced.
Beyerdynamic gives the Aventho Y a crisp and lively treble response. The highs are airy, tight, and generally well-controlled, adding energy and clarity to the sound. Certain tracks can expose slightly hot areas, but the treble avoids becoming consistently harsh or excessively sharp.
The Accentum is also brighter than expected. Its highs sound clean and expressive, with enough emphasis to reveal details that could otherwise become lost in its bass-heavy signature. There is a slightly thin or metallic quality to some treble notes, but the response remains smooth enough to avoid serious harshness. Both headphones offer energetic highs. The Aventho Y sounds airier and more refined, while the Accentum provides a safer presentation for listeners who are sensitive to sharper treble peaks.
The Beyerdynamic Aventho Y is the stronger all-around headphone. Its superior build quality, replaceable components, massive battery life, wider soundstage, and more balanced tuning help it stand out in the affordable wireless category. Its bass is especially impressive, offering more depth and control than the Accentum without overwhelming the rest of the frequency range.
The Sennheiser Accentum remains a worthwhile alternative for listeners who prioritize comfort, stronger ANC, broader app functionality, and aptX HD support. Its thick bass and expressive highs create an entertaining sound, although its recessed midrange prevents it from sounding as complete as the Aventho Y. Choose the Beyerdynamic Aventho Y for the better build, battery life, soundstage, and overall sound quality. Choose the Sennheiser Accentum if comfort, codec support, app features, and noise cancellation are more important.
The Beyerdynamic Aventho Y and the Sennheiser Accentum are both available at Audio46.
