Home Reviews Comparison Reviews Beyerdynamic DT 900 Pro X or DT 990 Pro X? Breaking Down...
Beyerdynamic DT 900 Pro X or DT 990 Pro X? Breaking Down the Best for Mixing & Mastering
When it comes to studio headphones, Beyerdynamic has built a legacy of trusted, professional-grade models used by audio engineers, producers, and musicians around the world. With the launch of the DT 990 Pro X and the all-new DT 900 Pro X, Beyerdynamic modernizes its classic line with updated styling, lower impedance, and the highly regarded STELLAR.45 transducers for improved compatibility and sound clarity. But how do these two models actually differ in practice, and which one is the better choice for mixing, monitoring, or casual listening? Let’s break down the DT 990 Pro X vs DT 900 Pro X across build quality, comfort, soundstage, bass response, mids, and highs, helping you decide which headphone is best suited to your workflow and preferences.
DT 990 Pro X DT 900 Pro X
  • DT 990 PRO X
  • 3.0M (98 ft.) MINI-XLR-CABLE (MINI STEREO JACK 3.5MM)
  • 6 1/4″ ADAPTER (6.35 MM)
  • DRAWSTRING BAG
  • DT 900 PRO X
  • 1.8 m (5.9 ft) & 3.0 m (9.8 ft) mini-xlr-kabel (mini stereo jack 3.5 mm)
  • 1/4″ adapter (6.35 mm)
  • Drawstring bag
Beyerdynamic-DT-900-Pro-X-Vs-DT-990-Pro-X headbands
Beyerdynamic’s Pro X line refines the build of products that haven’t changed for years. Both the DT 990 Pro X and DT 900 Pro X are more modernized headphones, carrying Beyerdynamic’s latest logo and aesthetics. The DT 990 Pro X is an updated version of a more famous model, while the DT 900 Pro X is completely new. Both headphones are very professional in their design, with large, soft velour ear pads that are common in Beyerdynamic headphones. The DT 900 Pro X has larger pads that are more comfortable than the 990 Pro X, which is important to keep in mind when in long mixing sessions.
Beyerdynamic-DT-900-Pro-X-Vs-DT-990-Pro-X face off
Both the Beyerdynamic DT 990 Pro X and DT 900 Pro X use the latest STELLAR.45 transducers. All of Beyerdynamic’s recent over-ear headphones use these drivers, and for the DT 990 Pro X specifically, it reduces the impedance so that you don’t need to worry about using an amp to drive them with. These are both 48-ohm headphones and should work with any 3.5mm or quarter-inch plug.
Beyerdynamic-DT-900-Pro-X-Vs-DT-990-Pro-X side
Both the DT 990 Pro X and the DT 900 Pro X are designed to do virtually the same thing with their soundstage. That is, to provide an accurate stereo field where all of the sound elements can be displayed for critical assessment. Considering their primary function as a studio tool, the DT 990 Pro X and 900 Pro X will have more similarities than differences regarding the soundstage and spatial imaging. For instance, both headphones provide very specific positioning that feels nailed down to the foundation of the mix. This can cause the soundstage to appear true but linear; however, the sound elements showcase a proper scale and fullness that communicates an in-studio environment.
If I could pinpoint a difference between the two, it would be that the 900 Pro X is not as strict with its linearity as the 990. With the 900 Pro X, the soundstage is allowed to rise off the ground, which shows a bit more holographic tendencies for higher immersion.
You never want the bass to get too thick or dominant in the mix when it comes to studio headphones, so the DT 990 Pro X and the 900 Pro X will have a more settled tone. They both have a very direct, tight bass performance that gives natural clarity to physical notes, but the 990 Pro X is slightly better with synth bass due to its more expressive rumble. The 900 Pro X is lacking some sub-bass depth in comparison, which might help make the decision easier, depending on what kind of music you’re going to be dealing with.
The DT 990 Pro X and 900 Pro X won’t have any problems reproducing clear midrange fidelity. Frequencies are elevated on both headphones, with the 990 Pro X showcasing a warmer timbre and the 900 Pro X exhibiting more lushness. Both headphones have a very full midrange response, but they’re slightly different in how some instruments are pronounced in the mix. The strike on piano keys is more prominent in the 900 Pro X, but vocals have more body to them on the 990 Pro X.
Beyerdynamic is known for its heightened treble, but the DT 900 Pro X has the tamest brightness. The 990 Pro X is definitely harsher with its highs, but if you like that about Beyerdynamic’s sound signature, then the 900 Pro X might be too reserved. No matter how they handle the extension of the highs, both headphones will offer natural resolution and control to their respective treble responses.
The DT 990 Pro X and DT 900 Pro X represent two thoughtful evolutions of Beyerdynamic’s studio-focused lineup, each offering subtle but important distinctions. The DT 990 Pro X retains the brand’s classic open-back spaciousness and adds a touch more rumble in the bass and warmth in the mids, ideal for users who appreciate a more expressive sound. On the other hand, the DT 900 Pro X delivers a slightly more immersive, holographic soundstage and smoother treble, making it better suited for long, fatigue-free mixing sessions.
Ultimately, your decision between the DT 990 Pro X and DT 900 Pro X will come down to your personal sonic preferences and how you plan to use them. If you’re looking for sharper vocal presence and brighter highs, the 990 Pro X may be your pick. But if comfort, tighter imaging, and a more balanced treble are your priorities, the 900 Pro X could be the better fit.
The Beyerdynamic DT 990 Pro X and DT 900 Pro X are available at Audio46 and Audio46 Express.
Previous articleIs the Bowers & Wilkins PX7 S3 the Best Bluetooth Headphone in 2025? We Tested It
Next articleBest Wireless Headphones 2025: Sony WH-1000XM6 or Bowers & Wilkins PX7 S3?
