Home Latest News JH Audio Announce Jolene Hybrid In Ear Monitors
Jerry Harvey Audio is back with a brand new flagship IEM, the Jolene.
JH Audio’s Jolene is a 4-way, 12 element hybrid in-ear monitor. The driver configuration combines balanced armature and dynamic components. The LF band (20Hz- 400Hz) uses a pair of 9.2mm dynamic drivers. These diaphragms provide for an excellent sub-bass punch. The mid-range (400Hz-4KHz) is powered by two 4.9mm dynamic drivers that produce a very natural low-end bass with exceptional tonality and rich texture.
The High-Mids (4KHz – 10KHz) and HF bands (10KHz – 23KHz) are both powered by quad balanced armatures, similar to the JH Audio Roxanne. The tonality of the dynamics blended with the balanced armatures creates a wonderfully balanced IEM. Jolene is the most natural, analog-sounding IEM Jerry has ever designed.
The Jolene is crafted using JH Audio’s unique new construction process. Utilizing state-of-the-art equipment and premium materials, the IEMs go through an initial machining process and are later finished at the hands of talented engineers and technicians at the JH Audio Headquarters in Orlando, FL. The shell construction is more durable than any other monitor on the market and results in a stunning aesthetic. The Jolene is available in two standard options: Jupiter shells with engraved copper faceplates or Hyper Black shells with engraved aluminum faceplates.
Impedance: 10 Ohms
Sensitivity: 114dB @1mW
Frequency Response: 20Hz – 23KHz
Noise Isolation: -26dB
The JH Audio Jolene will cost $1,599 for the universal fit and $1,799 for the custom fit.
Pre-Order at Audio 46. (Universal fit)
Previous articleAudeze Euclid Review
Next articleOneOdio A30 Wireless Headphone Review
