Lypertek Unveil Their First True Wireless Earphones
The PurePlay Z5 is the very first true wireless system from Lypertek brand, complete with hybrid noise-canceling capabilities and a companion smartphone app.
Powerful 10mm dynamic drivers deliver sound like never before, setting a new standard in what can be achieved in the world of affordable true wireless audio: Deep bass that goes low with controlling authority. Mids that provide insightful clarity with richness and emotion. Treble that effortlessly extends far, creating space and definition in a way that sounds as natural as real life.
PureControl ANC integrates an extra layer to the experience, providing added functionality and personalized service to help create your own individual setup. Use the setup assistant to easily get you started on using your PurePlay Z5 quickly and without fuss.
  • Make the most of the Hybrid Active Noise Cancelling technology – significantly reducing the amount of audible outside noise for distraction-free listening.
  • Ambient Sound Mode allows you to hear the world around you without removing your earphones. Talk to people, listen out for travel updates or just be more aware of your surroundings with the click of a button.
  • Auto-Ambient is a brand new feature, designed and developed by Lypertek which reduces the need to interact with your earbud controls – automatically activating Ambient Sound Mode when you stop or pause audio playback. Effortlessly become aware of your surroundings, and then resume playback to switch back to your preferred listening mode. This feature can easily be switched on or off via the app.
  • LDX™ Audio Mode provides a fully programmed and easy to select sound profile specifically designed for the PurePlay Z5 – taking the already impressively tuned sound to a new level, with added impact, energy, and width for those who desire more.
  • Easily customize the touch controls to make using the PurePlay Z5 as comfortable as possible, and be extra safe with the ability to remove single touch controls – reducing the chance of accidental presses.
The PurePlay Z5 earphones have been designed with extreme comfort and stability in mind, and to further enhance this, meticulous attention has been applied to the selection of ear tips provided – a vital accessory that too often gets overlooked.
  • PurePower™ ear tips use a thick silicone and narrow bore design to provide a focused and powerful sound.
  • PureSpace™ ear tips use a thinner silicone and wide bore design for a spacious and open sound.
  • PureComfort™ ear tips use high-density foam for added comfort and smoother sound.
Lypertek PurePlay Z5 Features
  • Driver: 10mm Dynamic Drivers
  • Battery: Up to 7 + 28 hours
  • Audio Codecs: aptX / aptX Adaptive / AAC / SBC
  • Microphone: cVc8.0 – 2 mic setup
You can find the Lypertek is available for $129 on Amazon.
Previous article7 Hertz Eternal Review
Next articleShure Aonic 40 Review
