HomeReviewsAudiophile ReviewsMeze Astru Review: Titanium Build Meets Audiophile-Grade Sound
In today’s competitive high-end IEM market, finding a pair that balances premium craftsmanship with a refined, engaging sound signature can be a challenge. Meze Audio has built a reputation for delivering both, combining striking industrial design with musical tuning that appeals to audiophiles and casual listeners alike. With the release of the Meze Astru, the brand continues to push its in-ear lineup forward, offering a single dynamic driver configuration housed in a meticulously engineered chassis.
Positioned as one of Meze’s more premium in-ear monitors, the Astru aims to deliver a cohesive listening experience that prioritizes tonal balance, spatial precision, and long-term comfort. Let’s take a closer look at its build quality, driver technology, and overall sound performance to see how it stacks up in today’s crowded audiophile IEM landscape.
  • 5 sizes of ear tips (XS, S, M, L, XL) with wax guard
  • Protective pouch
  • Soft PU leather envelope
  • Premium dual 2-pin balanced cable with 4.4 mm balanced termination
  • 4.4 mm to 3.5 mm adapter
Meze Astru Review single
The Astru is the latest IEM design that Meze introduced with the Advar, and later on, the more economically priced Alba. The Astru is the priciest IEM they’ve made in a while, so with that comes even more premium materials packed into the same ergonomic shape. You get a CNC-machined titanium housing with an electroplated satin finish for a build that looks as durable as it does stylish. If you like the fit of the Alba and Advar, the Astru will be just as comfortable. The cable is also a big part of the Astu’s design, featuring silver and aluminum plating, with a middle piece that has a unique design.
Meze Astru Review cable
The Astru uses only one 10mm dynamic driver that has an advanced multi-layered metal-coated composite diaphragm. Titanium is also used in the interior design, along with a gold-coated dome that is meant to control ressonance. For the listening test I did for this review, I used a Fiio BTR17 and a Chord Mojo 2.
  • Frequency Range: 5 Hz – 35 kHz
  • Impedance: 32Ω
  • Sensitivity: 111 dB SPL/mW at 1 kHz
Meze Astru Review pair
The Astru offers a wide soundstage while keeping its headroom close and intimate. It sounds like a well-articulated stereo field, more typical of an IEM than of over-ear headphones. A lot of the imaging appears in your head, but with good layering and separation. The left and right channels have a solid identity, and the Astru only leans toward the middle when necessary. This gives the Astru a linear presentation, but it’s not one that bores.
There’s good depth to the soundstage and imaging, which significantly expands the stereo environment. The Astru communicates pinpoint instrument placement while maintaining an immersive scale. It has a very dynamic sense of space, even when the soundstage seems very direct. Everything that happens through the Astru appears in front of your face, with just enough wraparound to provide imaging motion and localization. Instruments can stack on each other and give off a front-to-back presentation with grace and articulation.
It’s all about the mid-bass with the Astru, providing clarity and power for a wide spectrum of frequencies. While the bass appears with a broad natural tone, the impact of the lows can vary. This is a very dynamic bass resposne that delves deep, while at the same time staying out of the way when necessary. The Astru is more concerned with communicating accuracy in its bass than thickness or slam. However, the Astu can be surprisingly capable of giving tracks an injection of thump and body to its timbre. Industrial dance beats and synthwave bass synths can show a lot of drive, while physical bass instruments can feel a bit more laid back, articulating notes well but with less impact. The only thing consistent with this chameleon of a bass response is its definition, maintaining presence and shape no matter what genre you’re listening to.
While the midrange frequencies aren’t as dynamic as the bass, the instruments still appear full and in clear resolution. You get a clear display of instruments with a warm timbre in the low-mids, and more mellow detail in the fundamental and upper-mids. It feels like a step back in terms of power, but you never feel like you’re losing anything important. There’s a rawness to the timbre that I appreciate, so scaling the mids back a bit does better for maintaining smoothness. These frequencies display a lot of closeness with limited strike, but everything decays very accurately with concise release points. Vocals are very clear and feature an expressive range of tone. Male voices are deep and intimate, while female voices are smooth but concentrated with a crisp underline.
There’s a light shimmer to the treble that gives the high frequencies just enough presence to stand out. The Astu has a satisfying, metallic ring that has a level of brightness that is very well controlled, letting the highs exhibit natural flavor without becoming too piercing. It could still be a bit much for some, but the Astru’s highs allow the sound signature to feel more energetic while height is still limited. Everything comes through transparently, but the highs have a steadiness to it that feels like a barrier, just not one that reduces clarity or detail retrieval.
The Meze Astru stands out as a thoughtfully tuned single dynamic driver IEM that leans into precision, balance, and musicality rather than overwhelming coloration or exaggerated detail. Its titanium construction and premium cable design reinforce its position as a high-end offering, while its ergonomic shape ensures that comfort remains consistent across extended listening sessions. Sonically, the Astru excels in delivering a spacious yet intimate soundstage, with impressive imaging and layering that elevate its overall presentation. The bass prioritizes articulation over sheer impact, the mids offer a natural and expressive timbre, and the highs introduce just enough shimmer to keep the sound lively without becoming fatiguing. This results in an IEM that adapts well across genres, offering both analytical clarity and musical engagement.
For listeners seeking a premium dynamic driver IEM with balanced tuning, excellent imaging, and high-end build quality, the Meze Astru is a compelling option. It may not cater to those looking for aggressive bass or ultra-bright detail, but for anyone who values coherence, refinement, and long-term listenability, the Astru delivers a highly satisfying experience.
The Meze Astru is available at Audio46.
