Home Reviews Audiophile Reviews Noble Audio Van Gogh Review
When a product is named after one of the most iconic artists in history, expectations for creativity, uniqueness, and character run high. The Noble Audio Van Gogh is the latest set of IEMs in their catalog, replacing the Stage 3 for the price of $699. Let’s explore how the Van Gogh balances bold design choices with precise sonic execution, from its deep soundstage to its airy treble response.
  • Van Gogh IEMs
  • 8-core OCC silver-plated cable with 4.4mm plug
  • Small drawstring bag
  • 6 sets of silicone ear tips
  • Cleaning tool
  • Noble Audio Sticker
Noble Audio Van Gogh single
Any product with the name Van Gogh better have some sort of interesting artistic design to it that stands out. The obvious Gogh work to take inspiration from would be Starry Night, which is exactly where these IEMs gets their palette from. It’s not just the color of the Van Gogh that retains the soul of his artistry, with every pair being hand-painted with custom swirls. Even with this level of craftsmanship on display, the most surprising aspect of these IEMs, in my opinion, is their size. The Van Gogh’s shell is smaller than I’ve seen on a lot of IEMs in this range, especially from Noble Audio. It’s a welcome design, especially when it can be an easy universal fit, no matter how small your ears are. The Van Gogh barely feels like anything at all, maintaining a comfortable and lightweight fit throughout your listening sessions.
Noble Audio Van Gogh cable
The Noble Audio Van Gogh contains a 4-driver hybrid configuration. It utilizes an 8mm dynamic driver, two Sonion E-series balanced armatures, and a Knowles RAD series balanced armature. The dynamic unit uses a magnesium-aluminium diaphragm and dual-magnetic circuit. With the Van Gogh comes its stock 8-core 4.4mm cable made of OCC silver-plated material. To use these IEMs, it’s best to be aware of what type of headphone outputs your system offers.
Noble Audio Van Gogh pair
While I don’t think the Van Gogh has a particularly wide soundstage compared to other IEMs from Noble’s catalog, it has a lot of depth. This very in-your-head soundstage seems quite linear, but its layering elevates the spatial imaging to feature a larger scale. You get tons of separation between instruments, allowing sounds to appear over and behind others to expand the soundstage inwardly. In terms of headspace, the Van Gogh doesn’t do anything out of the ordinary, but doesn’t sound too closed off either. There’s definitely a limit on how far certain sounds can expand, but the tightness and accuracy of the soundstage make up for it.
For the most part, the bass frequencies on the Van Gogh are neutral. They have great note resolution that helps add shape and clarity to the lows, which makes physical bass instruments feel very transparent. You’ll get a smooth buzz from these instruments, but you might miss some impact. I wasn’t bothered by this, as the bass was consistently articulate and showcased good weight and form. If you’re listening to bass synths and expecting more texture and bigness from the bass, you might be disappointed. The Van Gogh is better when it comes to supplying a real and defined bass with deep grooves.
There’s a good level of clarity to the midrange frequencies, but their detail feels a bit small sometimes. The timbre of individual instruments is distinct, with the response resolving into a flat presentation. While this response allows for a very even and accurate midrange presence, the frequencies feel restricted. It’s like the resonance of certain instruments is shortened and put into a container. This doesn’t deteriorate the resolution of instruments, but the response is slightly dulled in my opinion.
The treble a a lightness to it that adds some nice coloration to the sound signature. There’s an airiness to the timbre that makes the highs appear delicate as frequencies are carefully dispersed throughout the mix. They add height and presence to the response that doesn’t feel too restrained or soft. It never approaches anything resembling harsh territory, but the frequencies are also not reduced in gain. There’s a tight and even presentation of high frequencies that are clicky and tail off with a satisfying ring.
The Noble Audio Van Gogh IEMs are a compelling blend of aesthetic brilliance and refined acoustic tuning. While they may not deliver thunderous bass or the widest soundstage, they excel in clarity, comfort, and artistic integrity. Their lightweight, compact shell and accurate, detailed sound make them ideal for listeners who value a delicate but defined audio experience. If you’re an audiophile who appreciates both sonic nuance and visual artistry, the Van Gogh IEMs are not just headphones; they’re a statement piece.
  • Stunning hand-painted design
  • Good soundstage depth
  • Neutral yet defined bass
  • Airy treble
  • Premium cable
  • Compact and lightweight shell
  • Mids can sound a bit restricted
The Noble Audio Van Gogh is available at Audio46 and Audio46 Express.
Previous articleSennheiser Accentum Open Review: The Best AirPods Alternative?
Next articleiFi Go Pod Max Review
