Home Reviews Best Noise Cancelling Headphones Sony WF-1000XM6 vs Momentum True Wireless 4: The Best Premium Wireless Earbuds...
Sony WF-1000XM6 vs Momentum True Wireless 4: The Best Premium Wireless Earbuds Compared
The premium true wireless earbud market continues to evolve rapidly, with manufacturers pushing the boundaries of sound quality, noise cancellation, and wireless connectivity. Two of the most compelling options currently available are the Sony WF-1000XM6 and the Sennheiser Momentum True Wireless 4. Both models target listeners who want audiophile-grade sound in a compact wireless format, but they approach that goal in different ways.
Sony’s WF-1000XM6 focuses heavily on cutting-edge noise cancellation, advanced processing, and a feature-rich ecosystem. Meanwhile, Sennheiser’s Momentum True Wireless 4 prioritizes codec flexibility, high-resolution wireless audio, and a balanced sonic presentation. In this comparison, we’ll examine how these two flagship earbuds stack up in design, Bluetooth connectivity, battery life, and sound performance.
WF-10000XM6 Momentum True Wireless 4
  • Earbuds
  • Charging case
  • USB Charging Cable
  • Four sizes of earbud tips
  • Momentum True Wireless 4 Earbuds
  • Charging Case
  • Extra Wing fins
  • S/M/L Ear Tips
  • USB Type C Charging Cable
  • User Guide
Sony WF-1000XM6 vs Momentum True Wireless 4 single
Both earbuds aim for a premium aesthetic, though their design philosophies differ. The Sony WF-1000XM6 features a compact, ergonomic housing with a rounded shape designed to fit securely in the ear. Sony refined the design compared to earlier models, making the earbuds slimmer and more comfortable for extended listening. The charging case remains compact and pocket-friendly, and the earbuds carry an IPX4 rating, protecting them from sweat and splashes.
Sennheiser’s Momentum True Wireless 4 follows the brand’s familiar ergonomic approach to true wireless design. The earbuds prioritize a natural seal and comfortable fit that works well for casual listening sessions and longer wear times. Both models feel secure once properly fitted, though Sony’s slightly larger housing may divide listeners when it comes to comfort.
Sony WF-1000XM6 vs Momentum True Wireless 4 case open
Both earbuds focus heavily on modern convenience features. Sony integrates a wide ecosystem of audio technologies into the WF-1000XM6, including 360 Reality Audio, customizable EQ, and DSEE upscaling, which enhances compressed audio sources. These features are part of Sony’s broader wireless audio ecosystem and help tailor the listening experience to different users. The Momentum True Wireless 4 also emphasizes functionality, offering strong wireless connectivity and robust companion-app controls. Its overall design balances sound customization with reliable everyday usability. Each model includes touch controls and companion apps that allow users to adjust sound settings and manage features such as noise cancellation and EQ.
Noise Canceling
Noise cancellation performance is one of the most important aspects of premium true wireless earbuds. Sony’s WF-1000XM6 delivers exceptionally strong ANC performance, creating a vacuum-like silence that rivals or surpasses many other true wireless earbuds on the market. Sennheiser’s Momentum True Wireless 4 also provides effective noise cancellation, but its tuning leans slightly more toward preserving audio fidelity while reducing background noise rather than aggressively eliminating it. If maximum noise isolation is the priority, Sony generally holds the advantage here.
Sony WF-1000XM6 vs Momentum True Wireless 4 case closed
Wireless connectivity is a major differentiator between these earbuds. The Sony WF-1000XM6 uses Bluetooth 5.3 and supports SBC, AAC, and LDAC, allowing compatible devices to stream higher-resolution audio over Bluetooth. Sony also includes multipoint connectivity, making it easy to switch between devices without disconnecting. The Momentum True Wireless 4 takes a different approach by focusing on broad Bluetooth compatibility and advanced codec support, including aptX Lossless. Both earbuds provide excellent wireless stability, but Sony emphasizes high-resolution streaming via LDAC, while Sennheiser focuses on broad codec compatibility and flexibility.
Battery performance is competitive between the two models. The Momentum True Wireless 4 delivers about 7.5 hours of playback on a single charge, with the charging case extending total listening time to roughly 30 hours. Battery life for Sony’s WF-1000XM6 remains strong as well, positioning it among the top true wireless options for extended listening sessions. Both earbuds also include quick-charge capabilities, allowing short charging sessions to provide additional playback time.
Sony WF-1000XM6 vs Momentum True Wireless 4 pair
The Sony WF-1000XM6 delivers a spacious and immersive presentation for a true wireless design. The improved driver and processing create a sense of width and depth that works well for cinematic music and modern pop production. With the Momentum True Wireless 4, you get a slightly more natural stage. While it may not feel quite as expansive as Sony’s presentation, it tends to offer more precise imaging and separation.
Sony’s tuning leans toward a powerful and energetic low end. Bass is deep and impactful, making the WF-1000XM6 especially enjoyable for electronic music, hip-hop, and cinematic scores. Sennheiser’s bass response is more controlled and neutral. It still extends deep into the sub-bass region, but it prioritizes accuracy over sheer impact.
The midrange on the Momentum True Wireless 4 is one of its strongest attributes. Vocals and acoustic instruments sound natural and well-defined, reflecting Sennheiser’s traditional hi-fi tuning. Sony’s mids are slightly recessed compared to the bass and treble, which can make the presentation feel more energetic but less neutral.
Treble on the WF-1000XM6 is crisp and detailed, benefiting from Sony’s processing and driver design. The top end adds sparkle without becoming overly harsh. Sennheiser’s treble is smooth and balanced. This results in a more refined presentation that many audiophiles may prefer.
The Sony WF-1000XM6 and Sennheiser Momentum True Wireless 4 represent two different approaches to flagship true wireless earbuds. Sony focuses on delivering the most advanced noise cancellation, wireless features, and immersive sound, making the WF-1000XM6 a strong choice for commuters and travelers who want maximum isolation and a feature-rich listening experience. The Momentum True Wireless 4, on the other hand, stands out with balanced sound tuning, strong Bluetooth capabilities, and reliable battery performance, making it a compelling option for listeners who prioritize audio fidelity and codec flexibility.
Ultimately, both earbuds rank among the best premium wireless options available today. Choosing between them comes down to priorities: Sony excels in ANC and feature integration, while Sennheiser shines with its refined sound and wireless versatility.
The Sony WF-1000XM6 and the Sennheiser Momentum True Wireless 4 are available at Audio46.
Previous articleFerrum WANDLA GoldenSound Edition Gen 2 Announced: A Major Upgrade to the Award-Winning DAC/PREAMP
Next articleAustrian Audio Arranger Review: Studio Accuracy with Everyday Musicality
