HomeLatest News64 Audio Reveals Duo Dual Driver UIEM
64 Audio’s latest UIEM, Duo, is a dual driver hybrid design. Built with the complete Tia System, Apex Core, Wave Sync, and LID, Duo presents 64 Audio’s signature balanced sound in a whole new way. The simple audio design captures the listener’s auditory senses while forgetting they’re wearing IEMs in the first place. The seamless faceplate machining and perforated grille is a departure from traditional IEM aesthetics bearing a welcome resemblance to classic open-back designs.
The constant pursuit of an open, wide, and fatigue-free listening experience has led us to develop Apex Core, a deeper understanding of air movement within an earphone system. Duo’s faceplate features a striking perforated grill that leaves the shell of the IEM open to the outside atmosphere for a less obstructed airflow resulting in an effortless reproduction of music and minimal physical fatigue.
Rather than constricting the sound of the drivers by fitting a tube onto them, Duo’s complete Tia System reduces unwanted resonance and distortion by allowing the 9mm Dynamic Driver + Tia High Driver to radiate freely into the single large Tia bore with no obstructions to the front of the drivers.
Due to the high crossover point between the two drivers, Wave Sync was developed to ensure coherence; another industry first. By using a type of “all-pass” filter, we’re able to introduce a crossover while correcting for time without having to change the physical distance between the drivers.
The complex faceplate assembly not only serves an important role in protecting the shell of the IEM while allowing air to flow freely, it is also a major step in 64 Audio’s product design evolution. Duo is a timeless and elegant design reminiscent of open-back over-ear headphones.
Driver Type/Count
2 Drivers: Dynamic and Balanced Armature
Driver Configuration
1 Tia high, 1 Dynamic Low
Frequency Response
20Hz – 20kHz
Sensitivity
98dB/mW (98dB @ 1kHz @1mW (95mV))
Impedance
Crossover
Integrated 2-way passive crossover
Isolation
-12dB internal apex technology
Cable Specs:
  • 0.23 Ohms Total Impedance
  • 7 x 7 x 4 Multi-Twist
  • SILVER PLATED OCC Copper wire
  • 26 AWG
64 Audio Duo in-ear monitors are now available at Audio46.
Sennheiser Momentum 5 vs HDB 630: Which Wireless Headphone Is Better?
Sennheiser now offers two compelling wireless headphones built for noticeably different listeners. The Momentum 5 represents the company’s mainstream flagship, combining a musical sound...
