HomeReviewsBest Noise Cancelling HeadphonesJVC Kenwood Glass Core Pro Review: A New Standard for Wireless Sound?
The JVC Kenwood Glass Core Pro aims to deliver a premium listening experience in a modern true wireless design. Entering an increasingly competitive category, these earbuds promise to balance sound quality, everyday functionality, and long-term comfort. Let’s examine their design, features, wireless performance, battery life, and overall sound to see how they compare with other high-end true wireless earbuds.
  • Kenwood Glass Core Pro Earpieces
  • S, MS, M, ML, L ear tips
  • USB Type-C charging cable
  • Charging case
JVC Kenwood Glass Core Pro single
JVC keeps to a stemmed earphone shell like the Wood Masterpiece. The Kenwood Glass Core Pro is a bigger earphone than the Wood Masterpiece, with a wider stem but an adequately sized housing that is shaped to fit cozily in your ear. The earphones have very little weight to them, so when they hang off your ear, the housing and nozzle can steady the earphones so they feel secure and comfortable.
JVC Kenwood Glass Core Pro case open
The Kenwood Glass Core Pro is built around a hybrid driver system combining a 10mm dynamic driver with a MEMS driver. Its glass diaphragm is designed to minimize unwanted vibration while improving clarity and spatial detail across the frequency range. It’s an innovative design that is joined by all the features you buy a pair of true wireless earphones for, including noise-cancellation. While it’s hard to dethrone the best ANC earphones, the Glass Core Pro makes a great attempt with some very strong noise-isolation.
You can quickly cycle between ANC and environmental awareness through the physical buttons on each stem. These buttons are a good alternative to sometimes finicky touch controls. There are some odd feedback sounds that indicate a registered press that seem overly theatrical for just playing and pausing music. The same goes whenever you reinsert the earphones into your ear. This isn’t much of a complaint, but it’s a bit strange compared to other true wireless earphones.
JVC Kenwood Glass Core Pro case closed
The Kenwood GLASS Core Pro uses Bluetooth 6.0 with Power Class 1 output for a strong and stable wireless connection. It supports SBC and AAC for broad device compatibility, along with LDAC for higher-resolution wireless playback from compatible sources. This codec selection allows the earbuds to accommodate everyday streaming while offering improved detail and bandwidth for listeners using supported high-resolution devices.
With active noise cancellation turned off, the Kenwood GLASS Core Pro delivers up to 14.5 hours of playback from the earbuds and as much as 49 hours with the charging case. Enabling ANC reduces those figures to 12 hours per charge and 40.5 hours in total. The earbuds take approximately 1.5 hours to recharge, while the case requires around 2.5 hours.
JVC Kenwood Glass Core Pro pair
You expect more from higher-end true wireless earphones, and the JVC Kenwood delivers on those expectations with its soundstage and spatial imaging. The Glass Core Pro offers a wide scope of sound not unlike what you hear on a good pair of IEMs. It’s an accurate display of positional information, with each instrument having a clear identity of where it’s coming from. Tracks that have instruments panned to extreme left or right positions are communicated well with the Kenwood, translating a proper scale that feels big and almost endless. The Glass Core Pro rarely lets its barriers be known, which allows the soundstage to really wrap around and showcase its layers more naturally. It’s not always the most expansive or dome-like, but the Kenwood is much more articulate and organized than most consumer true wireless earphones.
With its innovative vibrating glass plate, the Kenwood Glass Core Pro is meant to put a spotlight on the bass. One of the first things I noticed when testing these earphones for the first time was how clean and thumpy the lows were. The clarity was the most surprising aspect, bringing shape and weight to the bass tone, but the Kenwood gives you some extra edge without going too far. Everything about the bass is very concise and evenly distributed, but the level of depth it’s able to convey is where the Kenwood gets really impressive.
The level of detail sinks deep into instruments, resulting in more expressive bass notes that vibrate accurately. It’s not just for added texture; the timbre of the lows is very natural, but the sub-bass has just enough energy to elevate and round out the tone. The dynamism of these frequencies is unlike anything you’ll hear over true wireless earphones. You don’t even need to worry about the bass being a boring reference, because its mid-bass punch is so snappy and supported by such a rich body that the lows still groove and bounce around super smoothly.
While the midrange can be a bit thin at times, its resolution is very clear and detailed. It has a big envelope, even if the individual instruments lack a certain amount of body. The fundamental midrange feel is scooped a bit, but the low-mids and mid-treble are properly emphasized for high energy and livelier sound elements. It’s an organized and full midrange that favors certain frequency ranges and brings them up front. Vocals are the most dominant, with female voices being properly underlined and accentuated in the mix. The mid-treble elevates this region with a crisp tone that is smooth and never blaring. It makes the midrange seem very resolving, but not as naturally as the bass.
The treble has a very nice flavor to it, supplying crisp frequencies that are tight and shimmery. Everything is well controlled while also being detailed and transparent in tone. Cymbals have a rich glimmer, but when sounds taper off, they feel like they hit a wall. This subtracts from the Kenwood’s overall height, but high-frequency clarity is never brought into question. For a pair of true wireless earphones, it’s an immensely satisfying tone that will please listeners no matter their preference in sound profile.
The JVC Kenwood Glass Core Pro offers a distinctive alternative to more conventional premium true wireless earbuds. Its spacious imaging, exceptionally clean bass, detailed midrange, and crisp treble create a sound that feels closer to a refined IEM than a typical consumer wireless model. The presentation has a few limitations, including occasionally thin mids and restricted treble decay, but its overall clarity and organization remain impressive.
Strong noise isolation, physical controls, Bluetooth 6.0, LDAC support, and excellent battery life make the Glass Core Pro a capable everyday wireless earbud as well. For listeners who prioritize articulate bass, precise spatial imaging, and high-resolution wireless sound, the Kenwood Glass Core Pro is an innovative and rewarding option.
The JVC Kenwood Glass Core Pro is available at Audio46.
