HomeReviewsBest Noise Cancelling HeadphonesSennheiser Momentum True Wireless 5 vs. Apple AirPods Pro 3: Which Earbuds...
Sennheiser Momentum True Wireless 5 vs. Apple AirPods Pro 3: Which Earbuds Are Better?
The Sennheiser Momentum True Wireless 5 and Apple AirPods Pro 3 are two flagship earbuds built around very different priorities. Sennheiser prioritizes detailed sound, broad Bluetooth codec support, and long-term practicality, while Apple emphasizes effortless integration, smart features, and a seamless experience across its ecosystem. Both models deliver effective active noise canceling, strong bass, and the convenience expected from premium true wireless earbuds. However, their differences become clearer when you compare fit, connectivity, battery life, and sound quality. Which pair is the better choice? Let’s take a closer look at the Sennheiser Momentum True Wireless 5 vs. AirPods Pro 3.
Momentum True Wireless 5 AirPods Pro 3
  • MOMENTUM True Wireless 5 earbuds
  • One charging case
  • One USB-C charging cable
  • Ear tips (XS/S/M/L)
  • Battery replacement tool
  • Documentation
  • AirPods Pro 3
  • MagSage Charging Case (USB-C) with speaker and lanyard loop
  • Silicone ear tips (five sizes: XXS, XS, S, M, L)
  • Documentation
Sennheiser Momentum True Wireless 5 vs. Apple AirPods Pro 3 single
The Momentum True Wireless 5 introduces one of Sennheiser’s most comfortable earbud designs yet. Its housing is slimmer and less cumbersome than previous generations, allowing the earbuds to sit more securely in the ear. The smooth shape also makes them easy to wear for long listening sessions without drawing much attention to their presence.
Apple retains the recognizable stem-based design of the AirPods Pro line. The AirPods Pro 3 feel light and secure when their shape agrees with your ears, and the inclusion of five ear-tip sizes offers more room to find a proper seal. Still, listeners who have struggled with the AirPods fit in the past may not find this generation radically different. Both earbuds are comfortable, but the Momentum True Wireless 5 has the more accommodating design. Its narrower shell feels stable without relying on a stem, while its understated appearance looks more like a traditional premium IEM. The AirPods Pro 3 are better suited to exercise, however, thanks to their IP57 dust and water-resistance rating and built-in heart-rate sensing.
Sennheiser Momentum True Wireless 5 vs. Apple AirPods Pro 3 case closed
The AirPods Pro 3 are the more feature-rich everyday companion, particularly for iPhone owners. Personalized Spatial Audio with dynamic head tracking supports music and video playback, while Live Translation, hands-free Siri, automatic device switching, and workout heart-rate sensing expand their usefulness beyond listening. Apple’s ecosystem integration remains the major reason to choose them. Sennheiser takes a more audio-oriented approach. Its Sound Control app provides greater influence over the listening experience, while aptX Lossless and aptX Adaptive support give compatible Android users higher-quality wireless options. The earbuds and charging case also use replaceable batteries, giving the Momentum True Wireless 5 a major advantage in long-term serviceability.
Both models offer strong active noise canceling. The AirPods Pro 3 are especially effective at suppressing common environmental noise and remain competitive with the best ANC earbuds. Sennheiser’s system also provides convincing isolation and adds automatic wind-noise suppression for outdoor use. Apple has a slight edge in overall noise canceling, but the difference is not large enough to make ANC the sole deciding factor. For smart functionality, the AirPods Pro 3 win. For audio controls, codec flexibility, and repairability, the Momentum True Wireless 5 offers the more substantial package.
The Momentum True Wireless 5 uses Bluetooth 6.0 and supports multipoint connectivity. Its codec selection includes SBC, AAC, aptX, aptX Adaptive, and aptX Lossless. That makes it the more versatile option across different devices, especially for listeners using compatible Android phones or dedicated Bluetooth transmitters.
The AirPods Pro 3 can connect to Apple and non-Apple Bluetooth devices, but their best features are reserved for the Apple ecosystem. Pairing with an iPhone is nearly instantaneous, and switching among an iPhone, iPad, Mac, and Apple Watch feels effortless. They are less compelling for Android users, who lose much of the functionality that distinguishes AirPods from ordinary wireless earbuds. Sennheiser wins for cross-platform connectivity and codec support. Apple wins for convenience within its own ecosystem.
Battery performance is split depending on how the earbuds are used. The Momentum True Wireless 5 delivers up to 12 hours of playback with ANC turned off and six hours with ANC enabled. Its charging case increases total playback time to 40 hours. An eight-minute quick charge adds roughly one hour of listening, and the case supports both USB-C and Qi wireless charging.
The AirPods Pro 3 offer up to eight hours of listening with ANC enabled and up to 24 hours when including the charging case. That gives Apple an advantage for a single ANC listening session, but Sennheiser provides substantially more total playback before the case needs to be recharged. The AirPods Pro 3 are better for listeners who keep ANC active throughout the day. The Momentum True Wireless 5 are the stronger option for travel and extended use away from a power source.
Sennheiser Momentum True Wireless 5 vs. Apple AirPods Pro 3 pair
The soundstage reveals a major philosophical difference between these earbuds. The AirPods Pro 3 produce the larger image, with a wide, tall presentation that can make tracks feel grand and energetic. However, individual elements do not always occupy clearly defined positions. Separation is limited, and the image can feel more diffuse than precise. Sennheiser’s presentation is less expansive but considerably more organized. Instruments and effects have more distinct identities, and the stage offers convincing depth without pushing everything toward the center. The Momentum True Wireless 5 allow layers to breathe and wrap naturally around one another, making complicated mixes easier to follow.
Apple’s Spatial Audio expands the sense of scale but can further blur placement and narrow the stereo image. Dolby Atmos on the Sennheiser also produces a less natural result than standard stereo. Neither spatial mode represents these earbuds at their best, although Apple’s implementation is more deeply integrated with supported content. The AirPods Pro 3 sound bigger, but the Momentum True Wireless 5 sound more accurate and controlled.
Both earbuds prioritize bass, but they approach it differently. The AirPods Pro 3 deliver the harder and more aggressive response. Their lows are thick, meaty, and forceful, giving electronic music, hip-hop, and pop an immediate sense of drive. The bass can dominate the tuning, but it maintains enough clarity to remain exciting rather than completely muddy.
The Momentum True Wireless 5 also produces a rich and physical low end, yet its bass is smoother and more disciplined. Sub-bass provides foundational weight, while the mid-bass carries a full tone without excessive resonance. It is still a gratifying presentation, but it integrates more naturally with the rest of the frequency range. Bass enthusiasts who want the strongest impact may prefer the AirPods Pro 3. Listeners seeking depth, texture, and control should favor the Momentum True Wireless 5.
The midrange gives Sennheiser one of its clearest advantages. The Momentum True Wireless 5 has a warm lower-mid emphasis, but its presentation remains clean and direct. Instruments exhibit more body, and vocals occupy a more natural position in the mix. It is not the most resolving midrange available from a true wireless earbud, but it feels cohesive and appropriately balanced.
The AirPods Pro 3 use a more pronounced V-shaped tuning. Their mids are textured, but instruments often lack body and vocals do not always cut through with enough presence. With the bass occupying so much of the foreground, much of the mid-range can feel pushed backward. For vocal clarity, instrument timbre, and general balance, the Momentum True Wireless 5 is the easy winner.
Sennheiser also offers the more convincing treble response. The Momentum True Wireless 5 produces crisp, controlled highs with enough definition to give cymbals and percussion a distinct edge. The treble rolls off before becoming especially airy, but it maintains a natural character without causing fatigue.
The AirPods Pro 3 are similarly non-fatiguing, although their highs have less detail and consistency. Cymbals can sound slightly staticky rather than crisp, and the upper frequencies rarely establish a strong presence. The smoothness makes them easy to listen to, but it also limits their sense of fidelity. Neither earbud is extremely bright, but the Momentum True Wireless 5 supplies more definition, better timbre, and a more complete high-frequency response.
The Sennheiser Momentum True Wireless 5 is the better choice for listeners who place sound quality first. Its bass is deep without overwhelming the mix, its mids are cleaner and more substantial, and its highs have greater definition. Add its precise soundstage, aptX Lossless support, multipoint connectivity, longer total battery life, and replaceable batteries, and Sennheiser offers the more versatile premium earbud overall. The AirPods Pro 3 remain the better lifestyle product for committed Apple users. Their seamless pairing, automatic device switching, Personalized Spatial Audio, Live Translation, heart-rate sensing, strong ANC, and IP57 protection create an experience that reaches well beyond audio performance. They also offer longer playback with ANC enabled on a single charge and a more aggressive bass response.
If you want the more balanced and audiophile-oriented sound, choose the Momentum True Wireless 5. If convenience, fitness features, and Apple ecosystem integration matter most, the AirPods Pro 3 are the more natural fit. In the Sennheiser Momentum True Wireless 5 vs. AirPods Pro 3 comparison, Sennheiser wins on sound and flexibility, while Apple wins on connected features and everyday simplicity.
The Sennheiser Momentum True Wireless 5 are available at Audio46, and the Apple AirPods Pro 3 are available on Amazon.
