Audio Technica ATH-ANC700BT vs JBL E65BTNC Headphones Comparison Review
Buy Audio Technica ATH-ANC700BT vs JBL E65BTNC Noise Cancelling Headphones
Since I recently got my hands on the Audio Technica ATH-ANC700BT, I have been curious to try them alongside the JBL E65BTNC. Both are the same price at $199, and they both are wireless noise cancelling headphones. Which headphone is best for which type of person? Today I’ll try to find out with this Audio Technica ATH-ANC700BT vs JBL E65BTNC headphones comparison review.
In the Box
Audio Technica ATH-ANC700BT JBL E65BTNC
1.2 m audio cable Audio cable
USB charging cable USB charging cable
Pouch Documentation
Documentation
Headband
Both the Audio Technica ATH-ANC700BT and the JBL E65BTNC have plastic headphones with metal extenders. One major difference is that the JBL E65BTNC’s headband is thicker and coated in cloth. On the other hand, the ATH-ANC700BT is a bit thinner and just as one small bit of padding along the top which is coated in pleather.
Additionally, the JBL E65BTNC squeezes the head a bit tighter than the Audio Technica ATH-ANC700BT. As a result, the ANC700BT feels more comfortable, while the E65BTNC feels a bit more secure.
Audio Technica ATH-ANC700BT vs JBL E65BTNC Noise Cancelling Headphones Headband
Earcups
The earcups of the Audio Technica ATH-ANC700BT and the JBL E65BT are very similar! They are about the same size and shape. One difference is that the ANC700BT swivels a bit more freely in its yolk whereas the E65BTNC cups are a little more limited in their movement.
JBL E65BTNC vs Audio Technica ATH-ANC700BT Earcups
Earpads
The earpads of these two headphones have quite different designs, although both are coated in pleather. The JBL E65BTNC pads are thick and wide. On the other hand, the Audio Technica ATH-ANC700BT has smaller pads that leave a bigger space for the ear. Both are comfortable, although the E65BTNC is more sound isolating.
Best Noise Cancelling Headphones JBL E65BTNC vs Audio Technica ATH-ANC700BT Earpads
Features
Both the Audio Technica ATH-ANC700BT and the JBL E65BTNC have great Bluetooth range. They both work well over 30 feet even without line of sight. Additionally, both connect via Bluetooth version 4.1.
Noise Cancellation
Both the headphones’ noise cancellation feel a bit different from each other. The JBL E65BTNC seems to be a little bit stronger, although that might also be due to its proficient sound isolation. Both do a great job of cancelling low frequency information which makes me think they’d be great for wearing on airplanes.
Microphone
After doing a quick recording using both microphones, it was clear that the JBL E65BTNC sounded clearer than the Audio Technica ATH-ANC700BT.
The low frequencies and low-mid frequencies of the JBL E65BTNC are accented a lot. This will make folks who like a lot of bass happy. However the Audio Technica ATH-ANC700BT, which still has a robust bass response, is clearer sounding and has a more vivid midrange. Additionally, the ANC700BT is brighter, so cymbals sound louder and have more separation than the E65BTNC. Lastly, vocals are a bit higher in the mix than the E65BTNC.
Overview
Both headphones are really good and affordable wireless noise cancelling headphones. If you are the type of person who likes more bass in your music, you would probably prefer the JBL E65BTNC. If you are the type of person who prefers more clarity, you’ll like the Audio Technica ATH-ANC700BT.
The Audio Technica ATH-ANC700BT and the JBL E65BTNC are available for the best price here:
Audio Technica ATH-ANC700BT at Audio 46
JBL E65BTNC at Audio 46
JBL E65BTNC on Amazon
Best Noise Cancelling Headphones Audio Technica ATH-ANC700BT vs JBL E65BTNC
Previous articleUltrasone Signature DXP Headphones Review
Next articleMajorHiFi Music Monday: Wolfe Jackson
