HomeLatest NewsAudio Technica Launch New ATH-TWX9 True Wireless Earbuds
Sound is one of the most influential ways to connect people, whether it’s feeling the passion of an artist while listening to a live performance, experiencing the imagination of the creator through an exciting video, or simply communicating with friends, family, and co-workers remotely. Creating an intimate sound space has become one of the main goals of premium next-generation headphones.
The truly wireless ATH-TWX9 headphones offer the freedom to customize your sound space for an advanced audio experience. The headphones are also designed to fit any ear shape to provide intimate, comfortable sound. Enjoy an immersive listening space in any environment with an advanced noise-canceling function. Other features include 360 Reality Audio for a realistic 3D sound stage; the advanced Snapdragon Soundâ„¢ platform for higher quality music, video, and calls; and a deep-UV sterilization system that simplifies everyday care of your headphones. Designed with users in mind, these headphones offer the ultimate advanced, intimate audio experiences.
Features
• Truly wireless in-ear headphones with digital hybrid noise-canceling technology
• Ambience control (noise-canceling and hear-through) can be employed for music playback and calls
• Use the touch sensor to choose from five preset noise-canceling modes or optimized noise canceling that adapts to your current environment
• Hear-through function allows you to hear ambient sounds (plus your own, unmuffled voice) so you can talk to others around you without removing your earbuds
• Newly designed 5.8 mm high-resolution drivers deliver an extended high-frequency range and improved sound detail
• Compatible with Qualcomm® Snapdragon Sound™, Qualcomm® aptX™ Adaptive audio, and Sony’s 360 Reality Audio to deliver an advanced listening experience
• Eartips feature a hybrid structure of hard and soft silicone for the best fit and sound performance and come in three different lengths for each size (XS/S/M/L)
• Dual high-performance MEMS (micro-electromechanical system) mics, beamforming technology, and Qualcomm® cVc™ Generation 8.0 technology ensure crystal-clear call quality
• Sidetone circuitry improves conversations by letting you hear your voice in the headphones when making calls on most smartphones
• Qualcomm® TrueWireless Mirroring enables independent transmission to the left and right earbuds, reducing sound interruptions and delays for videos
• Multipoint pairing function allows you to stay connected to two Bluetooth devices at once
• Approximately 6 hours of continuous playback with up to 18.5 hours of extended use
• Charging case’s deep-UV LED sterilization system (with unique mirror processing) eliminates bacteria and viruses from the surface of the headphones**
• Charging case is compatible with Qi wireless chargers (sold separately) for easy place-and-go charging
• A-T Connect app gives you additional control: activate low latency mode, personalize noise-canceling system, adjust and save EQ to the headphones, change L/R volume balance, select desired voice assistant (such as Amazon Alexa Built-in or Google Assistant), change codecs, and more
• Rain and water splashproof design (IPX4*-equivalent)
• Flexible dual- or single-ear usability
• Includes 30 cm (1.0′) USB-A/USB-C charging cable
  • Type: Dynamic
  • Driver: 5.8 mm
  • Sensitivity: 102 dB/mW
  • Frequency response: 10 to 40,000 Hz
  • Impedance: 16 ohms
64 Audio Announces Ocean, Their New Flagship UIEM
During CanJam SoCal, 64 Audio introduced their latest UIEM. Looking to succeed the Fourté's ten-year reign as 64 Audio's flagship, the Ocean aims to...
Baum Audio Ellipse Review
