Base-Audio is back with a pair of high-fidelity in-ear headphones for the audiophile and commuter. Meet Base-Audio G8 high-fidelity headphones.
Base-Audio G8 High-Fidelity Headphones
These in-ear headphones are currently a working prototype that looks to be of a durable body. The exterior is an aluminium heavy-duty enclosure while the cord connector reinforces the cable to prevent breakage, kinks, and premature wear and tear on your wires. The wire is also flat to keep it from tangling.
When it comes to sound, Base-Audio promises some of the best. The headphones support an impedance of 32 ohms which makes them great for playback using portable, smart devices. The G8s have been fitted with 9 mm drivers that are said to deliver strong bass and a bright sound signature across the entire frequency response range of 20-20,000 Hertz. Designed to equip listeners with premium passive sound isolation, the earbuds should be able to retain depth and detail in your music, while still maintaining an open soundstage.
Although, the brand keeps the rest of their inner hardware a secret they’ve showcased some of the glowing reviews they’ve received on Amazon for their G7 headphones, in hopes that you’ll know to expect the best from their much smaller counterparts.
They’ve received comments like “comfortable and top quality headphones” and “the sound quality is far superior to anything I have had in the past.”
Following in the footsteps of its predecessor, the G7 headphones, Base-Audio G8 earphones are made available via Kickstarter. The Super Early Bird special grants interested buyers the opportunity to snag them at $39 before they hit the market this December for $69.
