HomeReviewsBest Noise Cancelling HeadphonesBeyerdynamic Aventho Y Review
Choosing the right pair of wireless headphones can be difficult, especially with so many options available at different price points. Features like build quality, comfort, battery life, connectivity, and sound all play a role in deciding which pair is worth your money. The Beyerdynamic Aventho Y enters this competitive market as a more affordable wireless option from a well-known name in audio. On paper, it offers a mix of features that make it worth taking a closer look at, but specifications don’t always tell the whole story. Let’s take a closer look at its design, features, connectivity, battery life, and overall sound to see how it performs in everyday use.
  • AVENTHO Y
  • USB-C CHARGING/
    AUDIO CABLE
  • DRAWSTRING BAG
Beyerdynamic Aventho Y headband
The appearance of the Aventho Y reminds me of JBL’s Bluetooth headphones in that they come in a variety of colors and feel very toy-like, especially the style of its physical design and switches. The Aventho Y has a better frame, though, and all-around better build quality even with a less sophisticated look compared to other headphones in their catalog. Its durable construction includes a premium aluminum yoke, replaceable battery, and interchangeable ear cushions, which all make for an overall stable and practical construction that I don’t think any other Bluetooth headphone can match in this price range.
Beyerdynamic Aventho Y above
While not the most complex interior, the Aventho Y still excels with its selection of features. There’s sound personalization with EQ, and of course, ANC. The Aventho Y isn’t going to have the strongest noise-canceling out there, but it gets the job done for commuting, which is all you can really ask for in this price range.
With the Aventho Y, you can expect a fast, stable connection with support from Bluetooth 6.0. Pairing is lightning quick, and it also offers a multipoint connection. Where the Aventho Y feels very standard, though, is in its selection of CODECs. You only have access to SBC and AAC, so if you’re looking for higher quality through LDAC or aptX Lossless, you won’t get that here.
For a Bluetooth headphone priced like the Aventho Y, the battery life is quite extravagant. There is an advertised 90 hours of playtime from the Aventho Y, and in practice that seems about right as long as you have ANC turned off. With ANC on, you still get 60 hours of battery life, which is still outstanding.
Beyerdynamic Aventho Y side
Just off my first listen, this is already the best soundstage on a Bluetooth headphone in this price range. The Aventho Y immediately jumps out with a wide left-to-right spread that creates impressive scope. Of course, this isn’t going to be the most dimensional stage, or the most open, but the Aventho Y has a surprisingly organized sound placement that fits with Beyerdynamic’s in-house standards. It’s fairly precise for a hundred-and-fifty-dollar Bluetooth headphone, and how the display is handled is beyond the performance of most wireless headphones.
I find Beyerdynamic headphones to have a sort of sneaky good bass tone, and that’s also true for the Aventho Y. This time, the bass doesn’t need to be sneaky at all. It clearly dominates the frequency response with thick, punchy tonality that feels right for this kind of headphone. Adding to that is a character that only Beyerdynamic can achieve in this price range. Every thump is met with a clear sub-bass bloom that not only supports the tone with a distinct foundation, but invigorates it with a buttery-smooth vibration. It’ll be hard to find another wireless headphone with this level of depth and clarity, as others easily fall into muddiness. The Aventho Y finds a great middle ground between fun and naturalness, supplying instruments with a full impact without driving into bloat.
You might be expecting the midrange to take a bit of a backseat, but the Aventho Y does a great job maintaining a level of energy that complements the sound signature. You get a full tone that doesn’t have perfect resolution but has a great scale that is supported by the soundstage’s established room. This results in instruments that aren’t quite physical, but still strike with a good level of authority. It individualizes elements of the mix in a way that doesn’t feel possible for an affordable Bluetooth headphone like the Aventho Y.
Beyerdynamic headphones are known for their bump in treble, but that’s usually not a favorable sonic character for a generously priced wireless headphone. The Aventho Y doesn’t really care about that, so you’ll get all the crispy treble you’ll need for a headphone like this. It’s nowhere near peaky, though, as the timbre of the highs is very airy and tuned with tightness and balance. You might find some spots that can get slightly hot, but it works to supply high-end frequency content that feels alive.
The Beyerdynamic Aventho Y is a solid wireless headphone that offers a good balance of features, design, battery life, and sound quality. While it may not have the most advanced features in its class, it covers the basics well and offers plenty for its price. Its long battery life, reliable Bluetooth connection, useful features, and enjoyable sound make it a practical choice for everyday listening. There are some compromises, particularly with codec support and ANC performance, but they may not matter to everyone. Overall, the Aventho Y is a well-rounded option for anyone looking for a capable wireless headphone without spending a lot of money.
  • Excellent sound quality
  • Wide soundstage
  • Punchy, well-controlled bass
  • Up to 90 hours of battery life
  • Solid build quality
  • Bluetooth 6.0 and multipoint support
  • Replaceable battery and ear cushions
  • Only supports SBC and AAC codecs
  • ANC performance is average
  • Treble can get slightly sharp at times
The Beyerdynamic Aventho Y is available at Audio46.
