HomeReviewsAmp and DAC ReviewsFiiO BTR25 Review: A Pocket-Sized Bluetooth DAC/Amp for IEMs and Headphones
A good portable Bluetooth DAC/amp should make it easier to use your favorite wired headphones wherever you listen. The FiiO BTR25 takes that idea a step further by putting much of what made the BTR17 appealing into a smaller package. That makes it an interesting option for anyone who rotates between IEMs on the go and full-size headphones at home. Let’s see how well the BTR25 fits into both setups and what it brings to the headphones I already enjoy.
  • FiiO BTR25
  • USB-C to USB-C data cable
  • Detachable clip
  • After-sales service card
FiiO BTR25 volume knob
Build
Right out of the box, the BTR25 strikes the perfect balance between size and material. Smaller portable DAC/Amps like the iFi Go Blu and Go Blu Air are tiny, but lack the build quality that the BTR25 has. The BTR17 was basically a larger version of this new device, which is exactly what it needed to be. This shrunk-down BTR17 looks as sleek and practical as ever, coming in black, dark green, and gold. It’s an aluminum alloy body with a 1.3-inch color display that actually reads off the track name and artist you’re listening to. The trade-off for being a smaller DAC/Amp is that you get a smaller volume knob, but it’s still fun to use and clicks into place, never feeling loose. It has one USB-C slot for both charging and data transfer, utilizing the switch on the side to indicate PC, phone, or Bluetooth use.
FiiO BTR25 clip
Inside the FiiO BTR25, an ESS ES9069Q DAC handles digital-to-analog conversion, while two ES9603Q headphone amplifiers drive the 3.5mm single-ended and 4.4mm balanced outputs. The fully differential circuit separates conversion from amplification, and independently regulated power sections support low-impedance loads. Output impedance stays below 0.3 ohms, which helps preserve the intended tuning of sensitive multi-driver IEMs. The balanced output delivers up to 460 mW per channel into 32 ohms.
The FiiO BTR25 uses a Qualcomm QCC3095 chip with Bluetooth 6.2 to stream audio from your phone to wired headphones or IEMs. It supports aptX Lossless, aptX Adaptive, aptX HD, and LDAC, along with LE Audio via LC3. The codec you can use depends on your source device, and aptX Lossless also requires a strong enough connection to maintain lossless playback. The BTR25 can connect to two phones at once, making it easier to switch between sources without re-pairing.
The FiiO BTR25 lasts up to 10 hours over Bluetooth with the SBC codec through its 3.5mm output, or up to 9 hours through the 4.4mm balanced output. With LDAC, FiiO rates playback at up to 8.5 hours through either jack. Wired Phone mode extends runtime to up to 11 hours, and a full charge takes about 90 minutes or less over USB-C.
FiiO BTR25 with MEze 105 AER headphones
Using the BTR25 with the Sivga Nightingale Pro, I noticed some immediate differences. As much as I’ve come to like the Nightingale Pro since it was released, it has some drawbacks; however, pairing it with the BTR25 fixes many of them. For instance, the BTR25 resolves a lot of the disjointed treble frequencies for me. They sound much more balanced and have a more refined edge while staying smooth. The bass still feels tight and neutral, but maintains its balance as well. This is the region that is the most gratifying to EQ, as it only needs slight adjustments to really bring out the energy of the lows. The midrange is also granted that refined edge from the treble, giving instruments more detail, like the buzzing of strings. It sounds more elegant and clear with the BTR25.
Moving over to the Meze 105 AER, the BTR25 continued to reveal more clarity in the sound signature. Here, the bass had a lot more prominence in the mix, so the BTR25 did a bit more with it. It slightly deepens the sub-bass frequencies, revealing more physicality and weight to the tone. Added separation and width from the soundstage also help with this, as the 105 AER doesn’t sound as narrow. Nothing ever felt constricted with this pairing, and the 105 AER now had the presentation of a higher-end open-back headphone. Spatial imaging has more dimension to it, and sound placement is able to be expressed with more identifiable localization. This ended up being the pairing I was most impressed by, since the BTR25 was able to preserve the AER’s musical flavor while lifting a veil from it and expanding the stereo field.
The FiiO BTR25 gets the everyday details right. Its aluminum body feels sturdy, the color display is easy to read, and having both 3.5mm and 4.4mm outputs makes it easy to switch between IEMs and full-size headphones. The biggest draw for me was how it worked with two very different pairings. The Sivga Nightingale Pro sounded smoother through the treble and clearer through the mids, while the Meze 105 AER gained some sub-bass weight and a wider stereo image. The 105 AER was my favorite pairing because it kept the headphone’s musical character while giving instruments more room and clearer placement. If you want a compact Bluetooth DAC/amp that can pull double duty on the go and at your desk, the BTR25 is easy to recommend.
The Fiio BTR25 is available at Audio46.
