HomeReviewsAudiophile ReviewsHEDD Audio HEDDphone DX Review
HEDD Audio brings a studio perspective to the world of high-end headphones, where what makes a pair useful for critical listening can also make it worth reaching for after hours. The HEDDphone DX sits in a crowded field of premium open-back headphones, and I wanted to see how naturally it fits into both kinds of listening. Let’s look at what it’s like to live with and where it fits among the options at its price.
  • HEDD Audio HEDDphone DX
  • Protective carrying case
  • 4.4mm Pentaconn balanced cable
  • Warranty
HEDD Audio HEDDphone DX headband
HEDD Audio doesn’t really go for the flashy audiophile design for their headphones. Their past efforts like the HEDDphone D1 have established a very pro audio look. As a result, the HEDDphone DX has a pretty standard look, but it still looks super clean and practical. Aesthetically, I actually really like the full black grille on top of a grey interior. It looks very unique in that regard, but the value of the HEDDphone DX comes from its build quality and comfort.
At first you might think that the frame and yokes don’t seem very appealing for an over a thousand dollar headphone, but the suspension headband and ear cups still have a very solid construction. This makes for a lighter and more practical design, which significantly affects sustained listening sessions. The DX is very comfortable, supported by its well-maintained weight distribution and perforated velour ear pads that rest comfortably on your head and give your ears a good amount of breathing room no matter the size.
HEDD Audio HEDDphone DX above
The HEDD Audio HEDDphone DX uses a newly designed driver configuration that integrates a 50mm high eXcursion dynamic driver with a thin-ply carbon diaphragm(TPCD). This new diaphragm was designed to be more effective at managing ressonance peaks without dampening. The multilayered carbon controls resonance and shapes it with more precision, which allows the driver to reproduce transients without smearing them. In terms of specs, the HEDDphone DX has a frequency range of 5Hz-40kHz, with an impedance of 32 Ohms, and a sensitivity of 100dB/mW. The DX wasn’t very hard to drive, but a small amplifier or interface is always recommended for headphones like this.
HEDD Audio has a strong reputation for delivering a grand soundstage that lets instruments occupy a natural space. The DX is one of their best for spaciousness, delivering their most open and layered headphone soundstages. It feels completely organic, as the sound is pushed out into the open air while performances are clearly locked into specific positions. Each position is direct, but presented from a good distance. Nothing feels floaty, but the HEDDphone DX still manages to project its soundstage holographically, with non-linear spatial imaging that allows sounds to completely engulf your personal headspace. Pan moves have incredible depth and dimension, their traversal across the stereo field pinpoint accurate. Even sudden shifts in angle are given a spotlight, showing off not just the shape of the sound, but where it precisely fits in the sonic environment.
Every space sounds real, whether it’s a concert performance or the live room of a studio. The tallness of instruments sits out in front and is elevated to communicate this space across the left and right channels. Stereo separation gives the instruments plenty of breathing room to communicate complex layers with graceful organization to deliver a soundstage that is sweeping and highly immersive. The HEDDphone DX could possibly take the spot of one of the best soundstages I’ve heard in this price range.
Headphones like the ones that HEDD Audio has produced can provide a suitable reference bass for low-end analysis. With the HEDDphone DX, the bass goes a step beyond, delivering proper definition with deep impact. The tone is rich and highly resonant while also being controlled and accurate. The result is a bass that balances a clean timbre with more theatrical sensibilities, including a clear sub-bass bloom with a rumbly foundation that gives the response tons of vigor. These characteristics don’t make the HEDDphone DX any less of a contender for critical listening, as it delivers its frequency content with incredible smoothness. Biggness is tightened to be fully understandable in how elegantly bass grooves are reproduced without losing scale. The body and shape of the bass frequencies are always present, and its form allows for different regions to appear in stacks that keep diving deeper.
One of the most lush and resolving midrange sound signatures I’ve heard over headphones recently. The HEDDphone DX is extremely accurate to where a mix sits on the frequency spectrum, rather than the track getting new textures reproduced by the driver’s specific tuning. The timbre is incredibly natural and refined, showcasing tonal purity and balancing it with smooth transients that give the HEDDphone DX such vivid sound reproduction that is almost serene. Instruments and vocals have cutting precision and realistic clarity that is totally surgical, capable of both critical analysis and musical enjoyment. Assessing the DX’s midrange frequencies feels like the perfect combination of raw studio accuracy and enthralling musicality. Notes are hyper-specific, especially from clean guitar picking that really pops in a lifelike way. Vocals are crisp and very airy in the upper-midrange, highlighting female performances that have an ethereal quality to them.
In the highs, you don’t have to worry about feeling any sense of excessive brightness or piercing. The treble has great clarity with plenty of detail, expanding the height of the sound signature and exhibiting a natural presence. Frequency content is plentiful and spread out enough to feel full and convincing. This gives the highs an airy quality that doesn’t sizzle as much, but retains texture by sounding realistic. You get good energy to them while still being perfectly even in the mix. Reverb tails extend outward into the open air, and you can hear them decay with precision.
The HEDDphone DX has one of the best soundstages I’ve heard in its price range. Its sense of distance is what impressed me most. Instruments have a clear place in the mix, and I could follow a pan across the stereo field as easily as I could hear a reverb tail fade into the room. The tuning holds up just as well under closer listening. The bass has real sub-bass weight and definition, the midrange gives vocals and guitars a lifelike presence, and the airy treble keeps fine details audible without turning sharp.
The DX looks understated for its price, but I appreciated the suspension headband and breathable velour pads more with each long session. If you’re shopping for premium open-back headphones that can pull double duty for critical listening and full-album sessions, the HEDDphone DX is an easy recommendation. I’d put it high on the shortlist for anyone who values precise imaging and a convincing sense of space.
The HEDD Audio HEDDphone DX is available at Audio46.
Best Black Friday Headphone and Earbud Deals of 2026
The best Black Friday headphone deals range from $50 noise-canceling earbuds to flagship open-back headphones at $500 off. We’ve rounded up our picks across...
T+A Solitaire T Pro Review
