HomeReviewsAudiophile ReviewsLoewe Leo vs Focal Bathys MG: Which Luxury Wireless Headphones Are Worth...
Loewe Leo vs Focal Bathys MG: Which Luxury Wireless Headphones Are Worth It?
There’s a point where buying wireless headphones becomes less about checking off features and more about finding a listening experience that feels special. The Loewe Leo and Focal Bathys MG both occupy that territory, combining premium construction with ambitions that go beyond the usual Bluetooth headphone. At the prices discussed here, $2,000 for the Leo and $1,500 for the Bathys MG, those ambitions come with considerable expectations.
However, spending more doesn’t necessarily mean getting the best performance in every category. Comfort, noise cancellation, sound customization, and tonal balance still involve compromises. This Loewe Leo vs Focal Bathys MG comparison looks at where each headphone earns its luxury status and which strengths make the most convincing case for your money.
Leo Bathys MG
  • Loewe Leo Wireless Headphones
  • Carrying Case
  • Leather Carrying Pouch
  • USB-C Charging Cable
  • USB-C to 3.5mm Cable
  • Quick Start Guide
  • Rigid carrying case
  • 1.2m (3.9ft) Jack cable
  • 1.2m (3.9ft) USB-C® cable
Loewe Leo vs Focal Bathys MG headband
The Leo’s anodized aluminum frame feels sturdy and looks sleek. Its dual volume dials are a standout feature, providing a satisfying way to adjust playback volume. Comfort is good, but the cushions could be deeper, softer, and more breathable. The Bathys MG pairs a bronze-colored aluminum frame with genuine leather detailing for a more distinctive appearance. It also offers a more comfortable fit, remaining snug without considerable pressure during longer sessions. Both feel premium, but Focal has the advantage in comfort.
Loewe Leo vs Focal Bathys MG face off
The Leo uses 50mm dynamic drivers with OCE diaphragms and a Texas Instruments OPA1622 amplifier. Its adaptive ANC provides excellent isolation, while transparency mode lets outside sound through when needed. Loewe’s app includes EQ, spatial audio, hearing personalization, customizable shortcuts, and connection management. These adjustments are useful, particularly because EQ plays a significant role in getting the best sound from the Leo.
The Bathys MG features 40mm magnesium drivers with Focal’s M-shaped dome design. Its standout feature is USB-DAC mode, which supports playback up to 24-bit/192kHz. ANC is functional, but less compelling than the Leo’s isolation. Focal’s app also offers EQ and personalization, although glitches and limited controls make it less useful. Loewe offers the stronger feature package for everyday wireless use. Focal’s main attraction is the option to switch to high-resolution USB listening.
The Leo supports Bluetooth 5.3 with SBC, AAC, LC3, and LC3+, alongside LE Audio and a low-latency setting. The Bathys MG uses Bluetooth 5.2 with aptX and aptX Adaptive, offering strong connectivity and fast pairing. Both include multipoint for switching between devices. Your source’s codec support matters more than the Bluetooth version alone.
The Leo offers approximately 45 hours with ANC enabled and up to 65 hours with it off. Charging takes around two hours, and playback while charging is supported. Its battery can also be replaced through a service procedure. The Bathys MG provides roughly 30 hours with ANC and around 40 hours in USB-DAC mode. Loewe’s longer runtime gives it a clear advantage for travel and frequent use.
Loewe Leo vs Focal Bathys MG side
The Leo’s soundstage is its biggest strength. It creates an expansive, enveloping image with impressive width, depth, and separation. Instruments retain their body while occupying distinct layers, and panning has a convincing sense of movement. This spaciousness is already present in stereo, with spatial audio adding some extra dimension. The Bathys MG emphasizes precise positioning and distinct channel separation, especially in USB-DAC mode. Its presentation is wide and organized, although more contained than the Leo’s. Choose Loewe for a more immersive sense of space and Focal for focused imaging within a clearly structured stereo field.
The Leo offers two useful bass presentations through EQ. The bass preset adds smooth, full mid-bass weight, while the pop preset reduces resonance for tighter, punchier notes. This gives listeners flexibility without making the low end excessively dark. The Bathys MG can produce deep rumble, but its bass definition is inconsistent. Some passages sound muddy, with low frequencies bleeding into the mix. EQ helps clean this up, though it also reduces impact. The Leo makes the stronger case for listeners who want bass that can move between fullness and control.
The Bathys MG delivers rich, textured instruments. Electric guitars have weight, and piano notes strike with convincing force. Instrumental clarity is a strength, although vocals sound more veiled by comparison. The Leo sounds most balanced with its neutral EQ preset, which improves vocal clarity and gives instruments room to breathe. Some low-mid haze remains, preventing the presentation from sounding completely defined. Focal stands out for instrumental texture and presence. Loewe offers a lively, spacious midrange, but benefits more from careful preset selection.
The Leo’s treble stays restrained. There’s some sparkle, but limited upper-frequency extension keeps the presentation from sounding especially energetic. It remains clean, though listeners seeking brighter highs may want more. The Bathys MG delivers greater shimmer and crispness without becoming piercing. Bells and chimes have a satisfying ring, and a modest treble boost can help vocals cut through more clearly. Focal is the stronger choice for treble detail and expression, while Loewe favors a more reserved presentation.
The Loewe Leo is best suited to listeners who prioritize expansive soundstage, effective ANC, and long battery life. Its sturdy build and volume dials add appeal, but the cushions, slight midrange haze, and restrained treble leave room for improvement at $2,000. The Focal Bathys MG offers better comfort, rich instrumental texture, more expressive highs, and USB-DAC playback for $1,500. Its inconsistent bass, shorter battery life, and uneven app experience are the main compromises. Choose the Leo for immersive imaging and everyday wireless convenience. Choose the Bathys MG for comfortable listening, instrumental detail, and the flexibility of a dedicated USB connection.
The Loewe Leo and the Focal Bathys MG are available at Audio46.
Klipsch Stratos HP-2 and HP-3 Bring Two-Way Drivers to Premium Headphones
Klipsch is returning to premium over-ear headphones with the new Stratos Series, introducing the closed-back Stratos HP-2 and semi-open-back Stratos HP-3. Announced as part...
Kiwi Ears Astral Review
