At what point does a pair of wireless headphones become a luxury purchase? With a $2,000 price tag, the Loewe Leo puts that question front and center. There’s no shortage of premium Bluetooth headphones promising great sound and everyday convenience, so entering well above the usual flagship price takes confidence. Loewe brings its background in luxury consumer electronics to the category, but how does that translate to the listening experience? Let’s find out whether these wireless noise-canceling headphones make a convincing case for their asking price.
- Loewe Leo Wireless Headphones
- Carrying Case
- Leather Carrying Pouch
- USB-C Charging Cable
- USB-C to 3.5mm Cable
- Quick Start Guide
You imagine a lot when thinking of a set of $2000 Bluetooth headphones. The Loewe Leo is the first I’ve seen, and from the build of it, I get it(kind of). These are an exceptionally well-built pair of headphones made from anodized aluminum that makes up its frame, which feels hard and extremely durable. It provides value and good looks to boot, feeling sleek with a modern style. Everything feels well supported, from the ear cups to the headband.
If I could point out a slight caveat, it’s that the ear cushions could be a bit more plush. I think the comfort level of the Leo is good, but for the price, I would like wearing them to feel cozier. They offer good support and hold tightly to your head, but more breathability would be nice, and thicker stock pads that are deeper would really help that. What I really like, though, is the Leo’s dual volume dials. Using a knob to increase volume always feels better than buttons or touch sensors, and the Leo is one of the only headphones that makes that happen.
The Loewe Leo uses two 50mm dynamic drivers with OCE (olefin composite elastomer) diaphragms, paired with a Texas Instruments OPA1622 SoundPlus amplifier. The diaphragms are designed for high stiffness and controlled internal damping to reduce unwanted resonance and distortion. The headphones have a specified acoustic frequency response of 20Hz–20kHz, rated within ±3dB.
Adaptive active noise cancellation continuously analyzes surrounding sound and adjusts its response as the environment changes. A five-microphone system supports noise cancellation and hands-free calling, while transparency mode allows outside sound through when greater awareness is needed. You expect the ANC to be strong for the price, and it certainly is. Sony might still be the industry leader by a hair, but the Leo makes a good case with its superb isolation.
The Loewe Leo app provides EQ adjustments, ANC and transparency controls, spatial audio settings, customizable shortcuts, and multipoint connection management. Mimi Sound Personalisation tailors playback to the listener’s hearing profile, while low-latency and voice-control options offer further flexibility. The integrated Leo Assistant adds voice-powered tools for capturing notes, answering questions, checking the weather, and translating speech.
The Loewe Leo features Bluetooth 5.3 with LE Audio and support for SBC, AAC, LC3, and LC3+ codecs, offering wireless Hi-Res Audio playback at up to 24-bit/96kHz. Multipoint connectivity allows pairing with multiple devices and switching between sources such as a smartphone and laptop. Wireless range is specified at approximately 10 meters, while the Loewe Leo app provides multipoint management and a low-latency audio setting.
The Loewe Leo houses a 660mAh rechargeable battery, offering approximately 45 hours of playback with active noise cancellation enabled and up to 65 hours with ANC switched off. A full charge takes around two hours, and the headphones support listening while charging. The battery can also be replaced through a service procedure, helping extend the headphones’ usable lifespan.
You will probably expect a lot from the Leo’s sound considering the price, and it makes an immediate impression with its expansive soundstage. I haven’t heard a Bluetooth headphone that matches the width and dimension the Leo puts on display. Its headspace is open and holographic, the sound forming a sphere that engulfs your head, and that’s without spatial audio. This is a non-linear stereo image with an incredible sense of depth. Instruments are layered and separated with tact, while filling out the space with full-bodied sound.
The Leo has an immense sense of scale that preserves a breathable space, so the sound doesn’t just shout out in front of you at all times. Panning has a more pointed sense of movement, with sounds dancing across your head rather than moving in a straight line. When you turn on spatial audio, you’ll notice the instruments become unbound from the stereo image, able to display slightly more dimension than in standard mode. It’s not the kind of spatial audio that makes the sound feel hollow and reflective, as the soundstage keeps everything close and organized. I prefer normal stereo mode, but activating spatial audio on the Leo doesn’t feel like it’s degrading the presentation of the sound elements in any way.
Enjoyment of the Leo’s frequency response will mostly depend on EQ, particularly how much bass you want. There are two presets that will give you a good sense of what the Leo can really offer here: bass and pop. Activating the bass preset makes the Leo a bass-dominant headphone, but in a way that feels clean and smooth. The tone has a present thump that mostly takes up the mid-bass frequencies, growing in scale and adding weight to the sound signature. Bass notes are very full and resonant, but the timbre is more natural rather than dark. Switching to the pop setting, the bass becomes tighter and punchier. Ressonance shrinks, but bass notes become more concise. Slightly more detail is added to round out the shape of notes and overall make bass performances more articulate and realistic.
Using the in-app EQ’s neutral filter gives you the best impression of the Leo’s midrange resposne. It certainly gives you the clearest vocals, clearer than the actual preset labeled “vocal.” That one makes everything sound thin and boxy, but the others do a better job clearing things up. The neutral filter allows instruments to sit at a balanced level, sitting in a more prominent position in the mix and allowing their details to be more pronounced. Instruments feel more roomy, and their tone is lively, even when notches are still noticeable. The resolution never feels completely defined, as a low-mid cloud very slightly hangs around, but instruments still have a mass to them that seems right.
Although you can boost some treble frequency ranges, the highs mostly stay tamed. While not completely absent, the Leo’s treble is tonally plain. The frequency content is there, and it’s all timbrally clean, but you don’t get a lot of energy from them. Some nice height is offered, but they definitely lack a clear tail that extends the upper highs. With that said, everything still sits right in the highs. Nothing is dulled, and the mid-treble even offers a bit of spark, but the highs are still carefully controlled, which results in a less exciting frequency response.
The Loewe Leo’s strongest argument for its $2,000 price is its soundstage. Its width, depth, and enveloping imaging deliver one of the most distinctive spatial presentations I’ve heard from Bluetooth headphones, even without activating spatial audio. Add an exceptionally sturdy aluminum build, excellent noise cancellation, satisfying volume controls, and long battery life, and there’s plenty to appreciate. However, the ear cushions could feel more indulgent, the midrange retains a slight cloudiness, and the restrained treble doesn’t deliver much excitement. EQ helps bring out the Leo’s strengths, particularly when choosing between fuller bass and a tighter, more balanced presentation. For listeners who prioritize expansive imaging, substantial construction, and wireless convenience, the Loewe Leo offers a compelling luxury experience.
The Loewe Leo is available at Audio46.
