HomeReviewsHeadphone ReviewsBeyerdynamic DT 770 PRO X Review
Beyerdynamic has a whole slate of classic headphones in their lineage. Starting with the DT 770 Pro and going all the way through to the newer DT 700 Pro X, Beyerdynamic has a long history of audio excellence. And with their centennial arriving, the German company has added a limited edition headphone to their lineup. That’s right, to celebrate 100 years in the audio industry, Beyerdynamic has released the DT 770 Pro X Limited Edition. But this isn’t just a cosmetic upgrade. There’s plenty of changes in tech and features to cover, including a detachable cable and upgraded driver tech. So let’s get under the hood and take a look at what this special edition headphone has to offer.
What’s in the Box:
  • DT 770 Pro X Limited Edition Headphones
  • 3 meter straight cable
  • 1/4 inch to 1/8 inch jack adapter
  • Drawstring bag
DT 770 Pro X Limited Edition logo on the yoke of the headphone
Build
Weighing in at 305 grams, the DT 770 Pro X Limited Edition is built just like the original DT 770 Pro. It’s a rugged device that is meant to last you, pretty much forever. Of course there used to be one issue with the DT 770 Pro that caused it to last only a short amount of time: the cable. On the original DT 770 Pro, the cable was not detachable. This meant if your cable broke, the whole headphone was toast. But now, taking a cue from other newer entrants into the Beyerdynamic line, these new Limited Edition Beyers come with a detachable cable. The cable connects to the headphone via a single 4-pin mini XLR. So if you ever want or need to switch out the cable for a new one, you can.
Elsewhere around the headphone are velour earpads, a memory foam head cushion, and plastic and metal accoutrement on the yokes and ear cups. Notably on the yokes are a logo denoting the limited edition status and centennial commemoration.
Beyerdynamic DT 770 Pro X Limited Edition cable
Fans of the original DT 770 Pro may remember that it came in multiple driver variants. These included a 32 ohm, 80 ohm, and 250 ohm version. However the new Limited Edition variant comes in just one driver orientation. The DT 770 Pro X LE uses the same Stellar.45 driver unit as the newer DT 700 Pro X.
Getting a little more specific, Stellar.45 uses a neodymium magnet and voice coil made from t copper-plated precision wires to deliver a light-weight but highly conductive driver system. This, in theory, results in a low-distortion, low impedance headphone that aims to deliver “studio-quality sound.”
At 48 ohms, I was able to drive the DT 770 Pro X straight out of my laptop just fine. However, I did find that the headphones benefited slightly from a little extra power, specifically in the low end. If you’re using these with a USB audio interface or dongle amp, you’ll get the best possible performance from the headphone. However, a connection straight from a phone or laptop will do you just fine as well.
Beyerdynamic DT 770 Pro X Limited Edition ear cups and connector
Listening Impressions
From a bird’s eye view, the DT770 PRO X aims for a fully neutral sound signature. The reason for this is that these are meant to be professional mixing headphones. The DT 770 Pro X LE is geared towards professional use first, as evidenced by the words “professional headphones” on the front of the box. That said, if you’re looking for a highly detailed, reference level closed-back headphone, you might want to pay attention to these.
Low End:
The low end is extremely neutral. So if you’re a basshead, you may want to bow out here. That said, the bass is extremely well controlled, tactile, and accurate. Sure, I would’ve loved a little bit more midbass love to help get further into the groove. But if I was mixing/mastering audio, that midbass hump would give me an inaccurate picture of the audio I’d be monitoring. Given the meek bass response, I still found it to be dynamic and fast. Furthermore, I found extension to be solid and the midbass transition, while staying under control, was solid.
Mids:
The mid range of the DT 770 Pro X is really nice. Like the bass, it’s mostly linear. However, there is a little added juice in the upper mids that give vocals a really nice presentation. Separation is top notch here. In fact, there were times where I was awestruck by the amount of detail that these fit in. This is likely a product of that lean bass response not clouding any detail. But it’s also helped by a top end that looks to push details forward as much as possible, which is likely why that shimmering upper midrange sounds so good.
High End:
I don’t want to overstate the treble here, but I would describe this as a top-end forward headphone. Don’t get me wrong, there’s never a moment where it sounds shrill or too sibilant. But the precision details on this headphone all come from the treble presentation. The DT 770 Pro X LE is sharp and precise. As a fan of warmer headphones, I was able to appreciate the controlled brightness of these. In fact, where the original DT 770 Pros were a little bit too bright for me, these feel just right. So if you’re into bright, reference level headphones, these will be right up your alley.
Birds eye view of Beyerdynamic DT 770 Pro X Limited Edition
Final Thoughts
Coming in at $199, the Beyerdynamic DT 770 Pro X Limited Edition presents an excellent value for the detail-oriented listener and audio professional alike. Pulling tech and design from two successful headphones (the original DT 770 Pro and DT 700 Pro X), this is a very formidable limited edition option. As the production of this headphone is time-limited, you might want to act fast.
You can find the Beyerdynamic DT 770 Pro X Limited Edition on Audio46.
