HomeReviewsAudiophile ReviewsCampfire Audio Alien Brain Review
Campfire Audio’s new Alien Brain IEMs are here. Designed for discerning listeners, these earphones promise an exceptional audio experience paired with stunning aesthetics. Featuring a unique outer dome design and meticulously crafted from premium PVD stainless steel, the Alien Brain not only looks remarkable but also stands out with its outstanding build quality. Let’s delve into the unmatched sound quality, intricate design, and impressive accessories that make the Alien Brain a worthy investment for music lovers seeking clarity, depth, and versatility in their listening experience.
  • Alien Brain Earphones
  • Time Stream cables in 3.5mm & 4.4mm balanced
  • Portable DAC Dongle
  • IEM Case
  • Breezy Bag Micro
  • Silicone Eartips – Small, Medium, Large
  • Foam Eartips – Small, Medium, Large
  • High and Clear Eartips – Small, Medium, Large in high traction silicone
  • Microfiber Cleaning Cloth
  • IEM Cleaning Tool
Alien Brain single
The Campfire Alien Brain has a cool design that fits with the brand’s usual eye for craftsmanship. Its main feature is the outer dome, which gives these IEMs the name Alien Brain. The material surrounding this dome is a black PVD stainless steel shell made from full billet CNC. This feels like a highly durable construction and makes for one of Campfire’s better builds. What I like most about it is the size of the shell, which appears like a shrunken-down Solaris, which will help with the IEM’s overall comfort level. Having a plethora of different tips to choose from should also help. Campfire Audio is always good with that, but they go a step further, adding new, clear tips that offer more options for different fits. Overall, the Alien Brain secures well, even with its bigger nozzle.
Alien Brain Cable
The Alien Brain uses a dual-magnet dynamic driver and four balanced armatures. The dynamic unit has a new diaphragm that is made with a glass dome and polyurethane coating. With a 7.8-ohm impedance, the Alien Brain is very easy to drive. Using the Astell & Kern HC4, the Alien Brain was incredibly sensitive to volume, so keep an eye on where you set your gain because these IEMs aren’t afraid to blast power.
Alien Brain pair
One of the first aspects of the Alien Brain that immediately caught my attention was its separation and imaging. I was struck by the large amounts of space between instruments and how much headspace the stereo field offered. It features left and right channels that are highly distinct from one another, spreading the mix outward. This results in a very large scope of sound, helped by great layering and depth. Instruments and effects fold over each other without appearing jumbled together, showcasing organized stacks of holographic spatial imaging. You get a good sense of panning movement, not just from left to right, but up and down as well.
What impressed me the most was how distant some sounds were displayed. Some sounds stick out in front of you, while others come at you from a specific origin further away. It becomes a very active soundstage, featuring sounds that aren’t nailed down to a specific area, but rather they hover in a more dimensional space for heightened immersion.
This is a very elegant bass response that has a main focus on clarity over anything. It might not give you the impact you’re looking for, but the mid-bass still has punch. Not only that, but bass instruments are very articulate, supplying you with detailed notes and grooves. The sub-bass has a subtle bump that gives the low end more depth, but don’t expect any significant rumble.
The Alien Brain has a balanced bass with a layer of thump, but its drive is more reserved. It works best when you hear its soft blooms that underline bass synths and strings. The low-end features a lot of character with its tone, establishing a level of weight, and shaping notes in a way that grips you. You might not get this response consistently, but if you primarily listen to jazz, chamber music, and some ambient electronic or EDM, then the bass has a lot to offer.
The Campfire Alien Brain gets all the detail in the midrange. Its frequency content is lush and features a rich timbre that makes instrument and vocals appear real and lively. It almost has a studio quality to it, like the instruments are being played to you. You can feel this with the pluck of strings on an acoustic guitar being a huge standout. Details and hidden artifacts are translated well through the Alien Brain, giving clarity to notes and vocal performances. There’s a strike to it that’s very impressive, adding shape to the sound while showcasing plenty of room.
While some frequencies have some peaks to them, the highs are mostly brought under control. You don’t have to ever worry about the Alien Brain being too harsh or bright. Expect some hard-hitting frequencies, though. Thankfully, the Alien Brain provides transparency and coloration to its highs, which makes them more enjoyable to listen to. Having an extended height really accelerates their ability, showcasing sizzle and glimmer wth more of an airy timbre.
The Campfire Alien Brain earphones excel in delivering a rich and immersive auditory experience that is hard to rival. Whether you are listening to complex orchestral arrangements or the subtle nuances of acoustic performances, these IEMs provide clarity and detail that truly enhance your musical journey. With a thoughtful design that prioritizes comfort and optimal sound, along with an array of accessories that cater to different preferences, the Alien Brain stands as a testament to Campfire Audio’s commitment to quality craftsmanship. For those ready to elevate their audio experience, the Campfire Alien Brain is an excellent choice that fuses style, durability, and breathtaking sound clarity.
The Campfire Audio Alien Brain is available at Audio46.
