Home Reviews Comparison Reviews Campfire Audio Iris vs Sennheiser IE 200 — In-Depth IEM Comparison Review
Affordable in-ear monitors continue to push the boundaries of performance, and two models that stand out in the entry-to-mid audiophile space are the Campfire Audio Iris and the Sennheiser IE 200. While both target listeners looking for high-quality sound at a reasonable price, their design philosophies and tuning approaches differ significantly. This comparison explores how each performs across build quality, sound signature, comfort, and overall value to help determine which IEM best fits your listening preferences.
Iris IE 200
  • Time Stream Metal – 3.5, 4.4
  • Dimensional Folding Wallet – Gray
  • Breezy Bag Jr mesh zipper case
  • Breezy Bag Micro two-pocket mesh
  • Foam tips (sml)
  • Silicone (sml)
  • High & Clear silicone (sml)
  • Microfiber cleaning cloth
  • IEM cleaning tool
  • IE 200 Earphones
  • Braided Cable with MMCX Connectors and 3.5mm Plug
  • Silicone and Memory Foam Sets (S, M, L)
  • Pouch
  • Safety guide
The Sennheiser IE 200 opts for a far more understated and utilitarian design, while the Campfire Audio Iris takes a more ambitious approach to design with its compact 3D-printed acrylic shells. These shells are lightweight and visually distinctive, giving the Iris a modern, handcrafted aesthetic that feels true to Campfire Audio’s boutique roots. Meanwhile, the IE 200’s compact black housings are designed with ergonomics and durability in mind rather than visual flair. The shells sit naturally in the ear, benefiting from Sennheiser’s long history in professional and consumer audio ergonomics.
From a design perspective, the Iris feels more premium and expressive, while the IE 200 emphasizes simplicity and functional longevity. In terms of fit, the Iris’s lightweight shells make them easy to wear for extended periods once a proper seal is achieved, though some users may need to experiment with tips to find optimal stability. The IE 200’s smaller, ergonomic housings tend to fit more consistently across different ear shapes, providing a secure and fatigue-free experience with minimal adjustment. For listeners planning long listening sessions, the IE 200 generally offers a slightly more reliable fit, while the Iris rewards careful tip selection with excellent comfort.
The Campfire Audio Iris features a hybrid driver system that pairs a large 10 mm custom ADLC (Amorphous Diamond-Like Carbon) dynamic driver for low frequencies with a balanced armature tweeter dedicated to upper mids and treble. This dual-driver setup allows the Iris to combine punchy bass extension with crisp, detailed highs, an approach that aims to deliver both impact and clarity across the spectrum.
By contrast, the Sennheiser IE 200 relies on a single 7 mm TrueResponse dynamic driver designed for balanced, natural-sounding reproduction. While it doesn’t use multiple drivers like the Iris, Sennheiser’s TrueResponse unit is engineered to minimize distortion and maintain linearity across the frequency range. The result is a more unified tuning that prioritizes tonal cohesion and neutrality over the layered presentation of a hybrid design. In practical terms, the Iris’s hybrid drivers tend to emphasize separation and sparkle, while the IE 200’s single dynamic driver favors smoothness and coherence.
Soundstage on the Iris favors width, while the IE 200 offers a more intimate soundstage. The Iris has an expansive left-to-right presentation, giving music a spacious, immersive feel. While depth is more limited, the overall presentation feels open and enjoyable, especially for cinematic or atmospheric tracks. With the IE 200, you get more precise imaging and strong instrument separation. Rather than emphasizing size, it focuses on clarity and placement, making it well-suited for analytical listening and detailed mix evaluation.
Low-frequency reproduction is one of the Iris’s defining traits. Its dynamic driver delivers bass that is both impactful and well-controlled, giving music a sense of physical presence without overwhelming the rest of the frequency spectrum. The IE 200 takes a more restrained approach to bass, favoring accuracy over sheer impact. Its low end is tight and articulate, integrating smoothly with the midrange rather than calling attention to itself. While it may lack the visceral slam of the Iris, it offers a cleaner and more reference-oriented presentation that appeals to listeners who value balance and realism. The Iris has a more satisfying punch that works particularly well with electronic music, hip-hop, and modern pop, while still maintaining enough discipline to avoid muddiness.
Midrange tuning on the Iris leans slightly relaxed, placing vocals and instruments comfortably within the mix without pushing them aggressively forward. This results in a smooth, forgiving presentation that works well for casual listening and long sessions, though it may feel less intimate on vocal-centric recordings. In contrast, the IE 200 excels in midrange clarity and presence. Vocals are more forward and detailed, giving acoustic recordings, singer-songwriter tracks, and dialogue a natural and engaging character. The midrange accuracy is one of the IE 200’s strongest attributes, contributing to its reputation as a budget-friendly audiophile IEM.
The Iris’s treble response is airy and clean, while the IE 200 is bright and energetic. The balanced armature tweeter that the IE 200 possesses helps add clarity and openness, helping the Iris sound lively while remaining relatively smooth at higher volumes. With the IE 200, detail retrieval and articulation are more enhanced, particularly for cymbals and upper harmonics, but it can sound sharp for listeners who are sensitive to treble or who listen at higher levels for extended periods.
The Campfire Audio Iris and Sennheiser IE 200 represent two different interpretations of value in the budget audiophile IEM space. The Iris stands out with its hybrid driver design, punchy bass response, and exceptionally generous accessory bundle, making it an appealing choice for listeners who want a lively, engaging sound with modern features. The IE 200, on the other hand, prioritizes tonal accuracy, midrange clarity, and long-term usability. Its single dynamic driver tuning delivers a more neutral and analytical presentation that appeals to purists and critical listeners.
Ultimately, choosing between the two comes down to listening preferences. If you want an energetic, bass-forward IEM with a premium feel and strong out-of-the-box value, the Campfire Audio Iris is the better fit. If your priority is balanced sound, natural mids, and a reliable everyday IEM for critical listening, the Sennheiser IE 200 remains one of the strongest options in its class.
The Campfire Audio Iris and the Sennheiser IE 200 are available at Audio46.
Previous articleIs The Strauss & Wagner Graz A Good Cable Upgrade For HiFiMAN Headphones?
Next articleFiio Jade Audio JT7 vs FT1 Pro: Head-to-Head Budget Planar Headphones Comparison
