Chord Electronics Upgrades Mojo 2 With 4.4 mm Output and USB-C Charging
Chord Electronics, the renowned British manufacturer of high-end audio hardware, has officially upgraded its award-winning Mojo 2 DAC/headphone amplifier with two major enhancements: a 4.4 mm balanced headphone output and switchable USB-C charging. Impressively, these improvements arrive at no increase in price.
With this upgrade, Chord continues to refine what many consider the best portable DAC/amp on the market, further strengthening its appeal to audiophiles, travellers, and desktop listeners alike.
4.4 mm Balanced Output Expands Headphone Compatibility
The most notable hardware change is the addition of a 4.4 mm balanced output, replacing one of the original 3.5 mm jacks. This allows the Mojo 2 to support a much wider range of high-performance and balanced headphones, while still retaining a 3.5 mm connection for convenience.
Both outputs now feature independent volume memory, letting users dial in precise levels suited to each pair of headphones without constant readjustment, a welcome quality-of-life upgrade for listeners who switch between multiple models.
Switchable USB-C Charging Simplifies Everyday Use
Responding directly to user feedback, Chord Electronics has enabled USB-C charging through the existing USB-C data port, eliminating the need for separate charging connectors. This upgrade streamlines daily operation and brings the Mojo 2 in line with modern charging standards.
Despite the addition of standard USB-C power, the device retains its full range of digital inputs, including optical, coaxial, Micro-USB (data), and USB-C (data/charging).
What Makes the Mojo 2 Unique?
Designed, engineered, and handcrafted in the UK, the Mojo 2 remains one of the most technically advanced portable DAC/amps available. Its performance is anchored by Chord’s proprietary technologies and custom engineering.
Proprietary FPGA Architecture
At the heart of the Mojo 2 is an ultra-powerful custom FPGA, loaded with Chord’s proprietary digital audio code developed over more than 20 years. This architecture enables exceptional clarity, dynamic range, and transient response far beyond typical chip-based DACs.
World’s First Lossless UHD DSP
One of the Mojo 2’s standout innovations is its 104-bit fully transparent lossless DSP, allowing users to fine-tune frequencies without degrading audio quality. This ensures ideal playback across genres, recording types, and connected devices.
Advanced Menu System & Features
The redesigned interface includes:
  • Four-level crossfeed adjustment
  • Mute and button-lock functions
  • Control over lossless tone shaping
  • USB-C charging toggle
  • Distinct polychromatic control spheres for intuitive navigation
Improved Power Management & Longer Battery Life
The Mojo 2 introduces a highly efficient FPGA-controlled charging system, reducing power loss by 75% and ensuring faster, cooler charging. The battery delivers more than eight hours of playback and supports an enhanced Intelligent Desktop Mode for long-term powered listening without damaging the battery.
Premium Build Quality and Broad Compatibility
The Mojo 2 is handmade from precision CNC-milled aircraft-grade aluminium, maintaining its reputation for exceptional durability and craftsmanship. Its continued inclusion of Micro-USB ensures seamless compatibility with the Chord Poly streamer, expanding the device into a full-featured wireless streaming solution.
Digital inputs include:
  • USB-C (data + charging)
  • Micro-USB (data)
  • Optical
  • Coaxial (with dual-data support for use with the M Scaler)
You can find more from Chord at Audio46.
Previous articleHEDD Audio HEDDphone D1 Review: Comfort, Clarity, and True Audiophile Transparency
Next articleQobuz and ECM Records Launch Exclusive Hi-Res Advent Calendar for December 2025
