HomeIndustry NewsFerrum Releases BROEN Network Streaming Transport for High-End Digital Audio Systems
Ferrum has announced the launch of BROEN, a new premium network streaming transport designed to deliver uncompromising digital audio performance. Built to integrate seamlessly with Ferrum’s award-winning WANDLA DACs and HYPSOS hybrid power management system, BROEN expands the company’s high-end audio ecosystem with a dedicated digital streaming solution.
Rather than functioning as a conventional network streamer, BROEN operates exclusively in the digital domain. Ferrum designed the transport to provide a clean, precise digital signal path while offering broad streaming support, flexible networking, and intuitive system control for serious hi-fi listeners.
SERCE Digital to Digital Module
At the center of BROEN is Ferrum’s newly developed SERCE DDC module, a Digital-to-Digital Converter engineered to optimize digital signal handling. By focusing entirely on digital processing, SERCE helps maintain precision throughout the playback chain while keeping input and output domains fully separated.
BROEN also features galvanically isolated audio outputs and ultra-low-jitter audio clocks, both intended to preserve signal integrity and reduce unwanted interference. For users building a high-end digital front end, this gives BROEN a clear technical focus: deliver the cleanest possible digital signal before it reaches the DAC.
Wired, Wireless, and Optical Networking Support
Ferrum has equipped BROEN with both Wi-Fi connectivity and a modular SFP network port, giving users multiple ways to integrate the streamer into their system. The SFP socket supports either a standard Ethernet module or an optical module, allowing BROEN to connect directly to compatible SFP network switches.
This opens the door for optical network transmission, which can help reduce electrical noise in demanding hi-fi setups. Ferrum includes an SFP module for standard RJ45 Ethernet connection in the BROEN package, making wired network integration available right out of the box.
Ferrum Streaming Control Technology and WANDLA Integration
BROEN has been developed around Ferrum Streaming Control Technology, also known as FSCT. This allows the transport to communicate directly with Ferrum’s WANDLA range of DACs when connected via USB.
With BROEN and WANDLA linked together, users can control playback from the WANDLA touchscreen or supplied remote control. Artist information, album details, and playback status can also be displayed directly on the DAC. Together, BROEN and WANDLA create a more complete streaming DAC and preamplifier system, designed to function as a unified Ferrum ecosystem.
Designed to Pair with HYPSOS Power Management
For users who want to push performance further, BROEN is fully compatible with Ferrum’s HYPSOS hybrid power management system. When connected through the proprietary Ferrum Power Link with 4TSD voltage sensing, BROEN and HYPSOS communicate with each other to maximize electrical performance.
This makes BROEN especially attractive for existing Ferrum users who already own WANDLA, HYPSOS, or both. The new transport is not only a standalone streamer but also a purpose-built extension of Ferrum’s modular high-end audio platform.
Powered by Volumio with Extensive Streaming Support
BROEN runs on the Volumio streaming platform, giving users access to a wide range of streaming services and playback features. Supported options include Spotify and Spotify Connect, TIDAL and TIDAL Connect, Qobuz and Qobuz Connect, AirPlay, UPnP/DLNA, internet radio, CD playback, and multi-room playback.
The platform also includes AI-powered SuperSearch, Infinity Playback, enhanced artist and album metadata, and over-the-air firmware updates. With a plugin-capable platform and the ability to add new functionality over time, BROEN has been designed with long-term flexibility in mind.
Future-Ready Expansion and Everyday Usability
Ferrum has included several features that help BROEN adapt as a user’s system evolves. An internal SSD slot provides additional storage flexibility, while the modular SFP socket allows networking options to be upgraded in the future.
Despite its advanced digital architecture, BROEN’s front panel has been designed for simple day-to-day operation. Ferrum emphasizes ease of use, giving listeners quick control without excessive menu navigation.
The Ferrum BROEN is available now, priced at $2,275. You can find it now at Audio46.
Key Features
  • New SERCE Digital to Digital module
  • Ferrum Streaming Control Technology
  • Ultra-low jitter audio clocks
  • Galvanically isolated audio outputs
  • Wi-Fi connectivity
  • Modular SFP Ethernet and optical networking support
  • Powered by Volumio
  • Spotify Connect, TIDAL Connect, and Qobuz Connect
  • AirPlay support
  • UPnP/DLNA renderer
  • Internet radio and CD playback
  • Multi-room playback
  • AI-powered SuperSearch
  • Infinity Playback
  • Over-the-air firmware updates
  • Internal SSD expansion
  • Plugin-capable platform
  • Full compatibility with WANDLA and HYPSOS
Sound Particles has announced major updates to Energy Panner 2 and Brightness Panner 2, two dynamic panning plugins that turn audio characteristics into movement....
