HomeIndustry NewsFiiO Unveils the K17 R2R Pro: Compact Streaming Headphone Amp with Powerful...
FiiO Unveils the K17 R2R Pro: Compact Streaming Headphone Amp with Powerful Desktop Audio Features
FiiO has officially introduced the K17 R2R Pro, a new all-in-one desktop audio solution that combines a DAC, streamer, and headphone amplifier into one compact chassis. Designed for audiophiles who want premium sound without the complexity of multiple separate components, the K17 R2R Pro aims to deliver high-end performance with modern convenience. Set to make its debut at High-End Vienna, the new model builds on the success of the earlier K15 and K19 while adding FiiO’s proprietary resistor ladder DAC design and expanded streaming functionality.
Proprietary R2R DAC for Natural Sound
The centerpiece of the K17 R2R Pro is FiiO’s custom 5 + 24-bit R2R PRO resistor array architecture. R2R DAC designs are highly regarded among enthusiasts for their smooth, organic presentation and natural tonal character.
According to FiiO, the K17 R2R Pro is engineered to produce:
  • Rich harmonic detail
  • More analog-like sound reproduction
  • Enhanced musical realism
  • Smooth and engaging tonal balance
Users can also choose between NOS (Non-Oversampling) and OS (Oversampling) playback modes, allowing listeners to tailor the sound signature depending on their preferences and source material.
Powerful Headphone Amplifier with 4000mW Output
Beyond its DAC section, the K17 R2R Pro includes a fully discrete Class AB transistor current-boosting amplifier circuit. Power output is rated at an impressive 4000mW + 4000mW, giving the unit enough headroom to drive a wide variety of headphones.
This makes it suitable for:
  • Sensitive in-ear monitors
  • Dynamic driver headphones
  • High-impedance studio headphones
  • Power-hungry planar magnetic headphones
The combination of power and refinement positions the K17 R2R Pro as a serious desktop headphone amp for demanding users.
Built-In Streaming and Network Connectivity
The K17 R2R Pro is also designed as a network-ready streamer, making it more than just a DAC/amp. It supports QPlay wireless streaming and includes multiple connectivity options for stable playback.
Features include:
  • Dual-band 2.4GHz / 5GHz Wi-Fi
  • Gigabit Ethernet
  • Local media playback
  • Wireless music streaming support
This gives users flexibility, whether they prefer wired network stability or wireless convenience.
Advanced 31-Band Parametric EQ
One of the standout modern features is the inclusion of a 31-band high-precision parametric equalizer with Auto EQ functionality. Users can fine-tune headphone response or customize their sound signature with professional-level precision.
EQ adjustments can be accessed through:
  • The FiiO Control smartphone app
  • A web browser on laptop or desktop
  • Saved directly onto the K17 R2R Pro device
This level of customization makes the K17 R2R Pro especially appealing to headphone enthusiasts who want precise tuning control.
Low Noise Design and Premium Build
FiiO has also focused heavily on noise reduction and clean power delivery. The K17 R2R Pro includes:
  • USB ground loop isolator to reduce interference
  • 35W low-noise linear power supply
  • Stable internal power regulation for better audio performance
The front panel is centered around a 3.93-inch touchscreen display, offering quick access to settings, playback, VU meters, themes, and clock modes.
An included aluminum alloy infrared remote adds convenient control from across the room.
A Complete Desktop Audio Hub
The K17 R2R Pro is positioned as both a standalone headphone listening system and a centerpiece for larger hi-fi setups. With premium DAC technology, strong amplification, streaming support, and advanced EQ tools, it offers a comprehensive solution for listeners seeking desktop simplicity with audiophile-grade sound.
  • Proprietary 5 + 24Bit R2R PRO resistor arrays
  • NOS/OS dual modes
  • Discrete Class AB transistor current-boosting headphone amp circuit
  • 4000mW + 4000mW high-power output
  • 31-band high-precision PEQ + Auto EQ
  • DAC/Amplifier · Local playback ·
  • QPlay support
  • 3.93-inch touchscreen
  • Aluminum alloy infrared remote control included
  • 2.4G/5G dual-band WiFi + Gigabit Ethernet
You can find more from Fiio at Audio46.
