HomeReviewsComparison ReviewsFinal Audio S4000 Vs E5000 Comparison Review
The Final Audio S4000 and E5000 stand out as two remarkable choices that cater to audiophiles and casual listeners alike. Each model boasts unique features, innovative designs, and sound qualities that appeal to various preferences. In this review, we will delve into the specifications, build quality, and sound performance of both IEMs, highlighting their key differences and similarities. Whether you’re a bass lover or a fan of intricate mids, this comparison will help you choose the right model for your listening experience.
S4000 E5000
  • Silicon carry case
  • Earpiece (Fusion-G 3 size)
  • Ear hook Type A
  • E5000 IEM
  • Silicone carrying case
  • Earpieces (Type E, 5 sizes)
  • Ear hooks
  • Carabiner
  • OFC silver-coated cable
With the Final Audio S4000 and E5000, the S4000 is the option that receives a vital build upgrade. The S4000 has a stainless steel housing with a blast finish. It is much more durable and valuable than the E5000’s stainless steel mirrored finish, which appears more basic in comparison. You also have a major difference in cable connectors, with the S4000 taking up a 2-pin connection over an MMCX one that the E5000 has.
The Final Audio S4000 and E5000 have different driver configurations. With the E5000, you get a 6.4mm dynamic driver, while the S4000 uses two balanced armatures.
S4000 E5000
  • Sensitivity: 112dB
  • Impedance: 48Ω
  • Sensitivity: 93dB
  • Impedance: 14Ω
The S4000 and E5000 have a ton of similarities in their soundstage and imaging. They both have wide linear stereo fields, with accurate positioning and a thinner scale. Both IEMs reach similar height levels, but you get more depth from the S4000’s separation quality. The right and left channels feature more identity on the S4000, but neither pair of IEMs has a particularly dimensional soundstage.
If you’re looking for the best fit for bass, go with the E5000. It’s much punchier than the S4000, but they both have established foundations that help lift its response. They both have a clear sub-bas drive, but I think that drive is greater on the S4000. However, the impact on the E5000 is better. It’s more direct and engaging, while the S4000 has more layers to its bass.
There are a lot of interesting details that reside in the midrange of both the E5000 and S4000. The E5000 has a lot of smooth, natural qualities, while the S4000 is a bit wild. With the S4000, micro details are given more of a highlight, especially with acoustic instruments. You get more even mids with the E5000, but they’re a bit more plain.
Both the E5000 and S4000 have smooth treble signatures, but the S4000 is definitely the brighter of the two. Neither will give you harsh qualities, but the S4000 is more keen to feature sharpness and sizzle. The E5000 is a more digestible high-frequency tone, but it’s also the one with less character.
Both the Final Audio S4000 and E5000 offer exceptional audio fidelity and quality, making them worthy contenders in the realm of high-end in-ear monitors. Your choice ultimately hinges on your sonic preferences: opt for the S4000 for a richer sound with exceptional detail and layering, or the E5000 for a more engaging and punchy bass response. Whichever model you choose, you can rest assured that both IEMs provide an outstanding listening experience that will exceed your expectations.
The Final Audio S4000 and E5000 are available at Audio46.
