HomeIndustry NewsGrado GW200 Announced: Open-Back Wireless Headphones With New S Drivers and 60+...
Grado GW200 Announced: Open-Back Wireless Headphones With New S Drivers and 60+ Hour Battery Life
Grado Labs has announced the Grado GW200, its latest pair of open-back wireless headphones. Building on the GW100 introduced in 2018, the new model brings technology from Grado’s Signature Line into a Bluetooth design with updated construction, expanded ear cushion compatibility, and a battery rated for more than 60 hours of listening.
New 44mm S Drivers Bring Signature Line Technology to Wireless
The GW200 features newly developed 44mm S dynamic drivers with paper-composite diaphragms derived from the larger drivers used in Grado’s HP100 SE and S950 headphones. This brings elements of the company’s higher-end acoustic engineering into its wireless lineup.
According to Grado, the drivers are tuned to deliver clear detail, distinct instrumental separation, and a natural sense of recording ambience. The company also describes a refined bass response intended to provide weight and articulation while preserving the openness associated with its headphones. The open-back construction remains central to that approach, supporting the spacious presentation Grado aims to carry over from its wired models. These are manufacturer descriptions; listening impressions will depend on hands-on evaluation.
Bluetooth 5.4 With aptX Lossless Support
The Grado GW200 uses Bluetooth 5.4 and supports a broad selection of audio codecs:
  • aptX Lossless
  • aptX Adaptive
  • aptX HD
  • aptX
  • AAC
  • SBC
That codec selection gives the GW200 flexibility across different playback devices, although access to individual codecs depends on the connected source. Listeners with compatible hardware can take advantage of aptX Lossless or aptX Adaptive, while AAC and SBC provide additional compatibility. A built-in microphone is also included.
More Than 60 Hours of Battery Life and Passive Wired Playback
Grado rates the GW200 for 60+ hours of battery life, giving listeners extended playback between charges. Charging takes place through USB-C, and a charging cable is included. For wired listening, the headphones feature a single-sided 3.5mm input that supplies audio to both earpieces through one cable. The GW200 can operate in wired mode without Bluetooth or battery power, allowing playback to continue when the battery is depleted. This makes the wired connection useful both as an everyday listening option and as a backup when charging is inconvenient.
Updated Design and Signature Headband
The GW200 introduces a redesigned matte-black housing inspired by the styling of Grado’s Signature Line. At 235 grams, it pairs a lightweight build with the company’s latest Signature headband assembly. The headband incorporates a padded leather strap and an internal flexible steel band that allows users to adjust inward tension. Stainless-steel height rods, redesigned gimbals, and reinforced junction blocks are intended to improve stability, adjustment, and durability. Controlled housing rotation helps limit unnecessary movement while retaining enough flexibility to accommodate different fits. Together, these changes place greater emphasis on comfort and mechanical refinement for longer listening sessions.
F Cushions and Expanded Earpad Compatibility
Grado supplies the GW200 with its F cushions, which form part of the headphone’s acoustic tuning. Internal acoustic slits promote airflow and contribute to the intended open presentation. Unlike earlier GW100 models, the GW200 supports Grado’s complete range of headphone cushions. This gives owners more options to adjust fit and comfort, as well as experiment with how different cushions affect the sound.
Grado GW200 Specifications
Specification Grado GW200
Driver type Dynamic
Driver size 44mm
Acoustic design Open-back
Frequency response 16Hz–34kHz
Nominal impedance 38 ohms
Sensitivity 104 dB SPL at 1mW
Total harmonic distortion Less than 0.3% at 100 dB
Driver matching 0.05 dB
Bluetooth version 5.4
Supported codecs aptX Lossless, aptX Adaptive, aptX HD, aptX, AAC, SBC
Rated battery life 60+ hours
Charging connection USB-C
Wired connection Single-sided 3.5mm input
Microphone Built-in
Included cushions F cushions
Weight 235g
MSRP $329 USD
The Grado GW200 open-back wireless headphones are available for preorder at the price of $329. You can find them soon at Audio46.
Loewe Leo vs Focal Bathys MG: Which Luxury Wireless Headphones Are...
There’s a point where buying wireless headphones becomes less about checking off features and more about finding a listening experience that feels special. The...
Kiwi Ears Astral Review
