iFi Audio, a leader in audiophile innovation, has just launched the iFi GO Pod Air, a more compact and budget-friendly alternative to its acclaimed GO Pod. Designed to free your favorite wired IEMs from their cables without compromising sound quality, the GO Pod Air promises Hi-Res Bluetooth audio, smart features for everyday use, and audiophile-grade performance in a sleek, travel-ready form.
Whether you’re commuting, working out, or on a Zoom call, the GO Pod Air delivers studio-quality audio on the go, with intuitive controls, exceptional battery life, and full support for all major Bluetooth codecs.
Transform Your IEMs with Hi-Res Bluetooth Audio
The GO Pod Air is more than just a Bluetooth adapter—it’s a full-featured Hi-Fi wireless solution for IEMs, combining iFi’s award-winning Bluetooth architecture with advanced components typically found in high-end audio gear.
Key Features:
Supports 24-bit/96kHz Hi-Res Wireless Audio
Cirrus Logic DAC chips for dynamic and detailed playback
Balanced amplification with auto impedance matching (16, 32, 64 ohms)
Comprehensive codec support: SBC, AAC, aptX, aptX HD, aptX Adaptive, LDAC, LHDC/HWA
Dual microphones with cVc noise suppression
Touch controls and voice assistant support
IPX5 water resistance
7 hours playback + 15-hour charging case
Same Magic, Now More Portable
Unlike most wireless earbuds that rely on a single chip for connectivity, conversion, and amplification, the GO Pod Air separates each stage for true Hi-Fi performance. iFi uses the Qualcomm QCC514x Bluetooth chip, Cirrus Logic MasterHIFI DACs, and a dedicated clocked amplifier to deliver pristine audio, all in a form factor that’s over 40% lighter and nearly 20% more compact than its predecessor.
At just 10 grams per pod, the GO Pod Air is ideal for audiophiles who refuse to compromise on sound while on the move.
Total Compatibility with Your Favorite IEMs
The GO Pod Air includes interchangeable ear loops to support a wide range of IEM connector types. Standard bundles include 2-pin and MMCX, while T2, Pentaconn, and A2DC options are also available separately.
iFi’s auto impedance detection ensures optimal performance for different IEMs. Just insert your earphones, place the pods in the case, and let the system auto-adjust—no manual setup needed.
Premium Codecs Without Compromise
While most wireless earbuds limit codec support, the GO Pod Air delivers audiophile-grade flexibility. Whether you’re using an iPhone, Android device, DAC transmitter, or Hi-Res player, the GO Pod Air supports:
SBC (standard)
AAC (Apple devices)
aptX / aptX HD / aptX Adaptive (Android)
LDAC and LHDC/HWA (Hi-Res audio)
With this universal codec support, the GO Pod Air guarantees superior wireless audio on any device.
Built for Work and Play
For professionals, the GO Pod Air makes remote work easier with responsive touch controls and dual microphones featuring Qualcomm’s cVc echo and noise suppression technology. You’ll enjoy clear calls even in noisy environments, and quick access to Siri or Google Assistant for hands-free commands.
When it’s time to relax or hit the gym, the IPX5 water resistance, disableable touch controls, and 15-hour total battery life make the GO Pod Air the perfect all-day companion.
The iFi Go Pods Air will cost $249. You can find more from iFi at Audio46.
