Home Reviews Amp and DAC Reviews iFi Go Pod Max Review
iFi Go Pod Max pair The iFi GO Pod Max is a game-changer for audiophiles who want to enjoy high-fidelity sound without the wires. Designed for those who already own premium IEMs, this Bluetooth adapter brings lossless wireless audio to your daily setup. Whether you’re commuting, working remotely, or lounging at home, the GO Pod Max offers the convenience of Bluetooth connectivity without sacrificing the sonic integrity of your favorite IEMs. With a sleek aluminum chassis, touch controls, and impressive battery life, the GO Pod Max aims to be the most audiophile-friendly true wireless adapter on the market today.
  • iFi GO Pod Max (pair)
  • 0.78mm 2-pin ear loops (pair)
  • MMCX ear loops (pair)
  • Charging case with UV sterilization
  • USB-A to USB-C charging cable
  • Instruction card
iFi Go Pod Max single
The main chassis of the Go Pod Max is made from aluminum and textured polymer. If you’re familiar with past versions of the Go Pods, the Max doesn’t take too far of a departure. The presentation of these Bluetooth adapters makes the Go Pod Max feel like a luxury item, built to last, and a major statement piece for your daily commute. Those worried about the main body of the Go Pod Max being distracting to wear will be happy to find that they feel light and natural with your IEMs.
iFi Go Pod Max open case
What makes the Go Pod Max more advanced than its counterparts is its inclusion of K2HD technology. This allows the Go Pod Max to maintain a 96kHz sampling rate, upscaling potentially lost frequency data that Bluetooth CODECs compress. In terms of functionality, the Go Pod Max uses touch controls that handle playback, taking phone calls, and using the voice assistant on your phone. It helps make your IEMs more interactive with your phone, and the controls themselves are fairly responsive.
iFi Go Pod Max pair
The Go Pod Max uses a QCC5181 chipset and supports the latest version of Bluetooth 5.4 for high range and fast connectivity. Having the Go Pod Max is highly advantageous for Android users, as it supports CODECs like LDAC and aptX Lossless, which will be better for your IEMs if you subscribe to music streaming services like Apple Music or Tidal.
For the standards set by true wireless IEM adapters, the Go Pod Max has a respectable battery life. The Go Pod Max should last for 7 hours off a single charge, and 35 hours when you factor in the charging case. This will be good for a few days of use before you need to put them back on the charger.
iFi Go Pod Max with FlipEars Aegis
I used the Noble Audio Van Gogh, Sivga Que UTG, FlipEars Aegis, and 64 Audio U18t as pairings for the GO Pod Max to test their sound quality. This selection granted me a variety of sound signatures to judge the Go Pod Max with to better asses its performance as a whole. The first thing you’ll start to notice is just the level of power the Max can output.
If you think that consumers’ true wireless earbuds are too low in volume, this would be your solution. What you might be worried about is the resolution of the sound compared to being hard-wired. Bluetooth is known to compress the sound, especially compared to how mid-range and high-end IEMs typically sound through DAC/amps or standard headphone sockets. While that might be true, I think the sound that the Go Pod Max brings to your selection of IEMs does justice to the definition and timbre of the IEMs I selected.
Out of the selection I picked, the FlipEars Aegis has the most aggressive sound signature. The bass has a growly foundation to it, which the Go Pod Max replicates with similar detail. The size of this rumble is scaled back a bit, but the response still has a strong shape to it. It shares a similar experience with the U18t and Van Gogh, which also have expansive bass frequencies that are slightly restrained but still clear and precise.
In the midrange, the Go Pod Max maintains a ton of transparency and roominess that selections like the U18t and Que UTG uphold. Those who aren’t looking to spend a ton on IEMs after purchasing the Max will benefit from a pairing with the UTG, as it will maintain the natural liveliness of the midrange. The Go Pod Max has a similar clarity with its treble, which the Van Gogh is strongly enhanced by. Its light airiness takes on a greater shimmer and height.
The iFi GO Pod Max is one of the most refined and feature-rich wireless IEM adapters you can buy. With support for high-resolution Bluetooth CODECs, solid battery performance, and K2HD technology that helps restore compressed audio, it delivers a listening experience far beyond what standard true wireless earbuds offer. While it won’t completely replace a wired DAC/amp setup in terms of absolute fidelity, it comes remarkably close, especially when paired with resolving IEMs like the 64 Audio U18t, FlipEars Aegis, or Noble Audio Van Gogh. If you’re serious about sound and want wireless freedom without compromise, the iFi GO Pod Max is one of the best options available in 2025.
The iFi Go Pod Max is available at Audio46.
Previous articleNoble Audio Van Gogh Review
Next articleRevolutionize Your Sound with KRK’s New Kreate Series Studio Monitors
