HomeReviewsHeadphone ReviewsJBL Endurance Peak 4 Review
Finding the right pair of true wireless earbuds for workouts can be a challenge, especially when balancing durability, sound quality, and long-term comfort. The JBL Endurance Peak 4 aims to check all those boxes with a rugged, secure design and a feature set built for active lifestyles. With enhancements to battery life, Bluetooth connectivity, and customizable sound through the JBL Headphones app, these earbuds position themselves as a versatile option for both fitness enthusiasts and casual listeners. Let’s take a closer look at how the Endurance Peak 4 performs across design, functionality, and sound to see if it stands out in the competitive sports earbud market.
  • 1 x JBL Endurance Peak 4 headphones
  • 1 x Charging case
  • 1 x Enhancer
  • 1 x 3 sizes of eartips
  • 1 x Warranty / Warning (W / !)
  • 1 x QSG / Safety Sheet (S / i)
JBL Endurance Peak 4 single
If you’re looking for true wireless earbuds that hook around your ears, the Endurance Peak 4 are exactly what you need. It’s an in-ear headphone that’s very secure and form-fitting, allowing the earbuds to stay in place during intense exercise. My favorite aspect of this design is actually its build quality. It has IP68 dust and water protection, so you won’t have to worry about using the Endurance Peak 4 in those environments (they are supposed to endure, after all). However, it’s the actual earpiece design that actually caught my attention. The texture of the earbuds reminds me of the hard surface of a barbell, and even though the chassis still feels plasticky, it still feels like more attention was paid to this build than to a lot of other wireless sports earbuds in this price range.
JBL Endurance Peak 4 case open
The JBL Endurance Peak 4 uses a 10mm dynamic driver, which is relatively large for true wireless earbuds and is tuned for JBL’s signature Pure Bass Sound with Spatial Sound support. Everything appears properly powered in terms of raw output, leaving you with a solid nominal sound level with a good amount of headroom to spare. Noise-canceling helps out with this too, supplying a fair amount of isolation for its price point. Your environment is monitored in real time by the Endurance Peak 4’s array of microphones, which also controls other features like ambient aware and talkthru. The ambient amare mode is responsive and very useful, while talkthru can be a bit finicky.
Through the JBL Headphones app, the Endurance Peak 4 offers a range of customization tools. You can adjust EQ settings, fine-tune ANC and ambient sound levels, and personalize controls to match your preferences. The app also supports features like sound personalization, firmware updates, and control customization, giving users more control over both audio performance and usability.
JBL Endurance Peak 4 case closed
The JBL Endurance Peak 4 uses Bluetooth 5.3, offering a more stable and energy-efficient wireless connection compared to previous generations. This ensures reliable playback with minimal dropouts, which is especially important during workouts or outdoor activity. The earbuds support standard SBC and AAC codecs, providing solid compatibility across both iOS and Android devices. Additional connectivity features include multipoint pairing, allowing you to stay connected to two devices simultaneously, and Google Fast Pair for quick and seamless setup on Android devices. The connection remains responsive for media playback and calls, with low enough latency for casual video viewing, making the Endurance Peak 4 a versatile option for both fitness and everyday use.
The JBL Endurance Peak 4 is built for extended use, offering up to 48 hours of total battery life when combining the earbuds and charging case. On a single charge, the earbuds themselves deliver up to 12 hours of playback with ANC off, or about 8 hours with noise canceling enabled, while the case provides multiple additional recharges. For convenience, the Endurance Peak 4 also supports fast charging, giving you roughly 4 hours of playback from just a 10-minute charge, making it ideal for quick top-ups before workouts or commutes. Overall, the battery performance is one of the standout features here, easily supporting multi-day use without needing to plug in, especially for active users who need reliable endurance from their gear.
JBL Endurance Peak 4 pair
I’m never expecting the widest soundstage or the most immersive spatial imaging on workout earbuds, but the Endurance Peak 4 still makes a solid effort. There’s good left/right channel distinction, with surprising separation and localization across the stereo field. Its wingspan is about shoulder length and quite linear, which is what I’ve come to expect from JBL, but it always comes across very gracefully. If you’re looking for a pair of workout buds that offer more scale to the soundstage, the Endurance Peak 4 might actually be too spread out. However, those looking to also listen to their workout buds casually will be impressed by its more advanced spatial properties.
The most important feature of any pair of workout earbuds is its bass resposne, and JBL usually has no problem delivering in that area. With the Endurance Peak 4, you get a solid thump with its factory tuning that you can adjust with EQ to your heart’s content. It delivers exactly the kind of energy you want for workout sessions, a deep, satisfying rumble with a full body that punches hard. This response can be even more dominating with certain EQ presets like bass, and extreme bass that will really swallow the frequency resposne in a thick cloud of tone. Articulate? No, but the boomy power is what you’re probably looking for in a pair of generously priced workout earbuds.
While you can use EQ to bring out the midrange a bit, the frequency resposne is fittingly U-shaped. Instruments show up to the surface, but their tone is quite thin aside from emphasis in the low-mids and upper-mids. The fundamental midrange is pretty much attenuated, but with EQ, you can get some clarity to sneak through. It feels slightly artificial, though, like the frequencies are being pushed through a tube. Vocals suffer the most with this resposne, lacking proper command and enunciation. They’re not completely in the background, but they definitely lack fullness.
You’re not really looking for crisp and brilliant treble on a pair of workout earbuds, and the Endurance Peak 4 knows that. The jazz preset offers the clearest look at the highs, but it’s still quite veiled. Otherwise, everything is smooth and easy to digest in the high frequencies. They’re unobtrusive but not completely muted with EQ adjustments.
The JBL Endurance Peak 4 succeeds in delivering what most users want from workout earbuds: a secure fit, strong durability, and powerful, energetic sound. Its bass-forward tuning, long battery life, and reliable Bluetooth performance make it an excellent companion for exercise and on-the-go listening. While the midrange and treble lack refinement, and some features like TalkThru can feel inconsistent, the overall package remains highly practical and dependable for its price. For those prioritizing stability, endurance, and impactful sound during workouts, the Endurance Peak 4 is an easy recommendation. It may not satisfy critical audiophiles, but as a fitness-focused true wireless solution, it gets the fundamentals right, and then some.
  • Secure earhook design ideal for workouts
  • Durable build with IP68 dust and water resistance
  • Powerful, punchy bass response
  • Long battery life (up to 48 hours total)
  • Stable Bluetooth 5.3 with multipoint pairing
  • Useful app features (EQ, ANC control, customization)
  • Midrange lacks fullness and clarity
  • TalkThru mode can be inconsistent
The JBL Endurance Peak 4 is available at Audio46.
Klipsch Stratos HP-2 and HP-3 Bring Two-Way Drivers to Premium Headphones
Klipsch is returning to premium over-ear headphones with the new Stratos Series, introducing the closed-back Stratos HP-2 and semi-open-back Stratos HP-3. Announced as part...
Kiwi Ears Astral Review
