HomeLatest NewsJBL Reveals Club Pro True Wireless
JBL has dabbled in its fair share of true wireless systems like the Live 300 or the Reflect Flow. Now, they’ve announced their latest foray with the Club Pro. This true wireless promises to bring that big JBL sound with a variety of features, including the use of their MyHeadphones app.
Features
  • Legendary JBL Pro Sound
Your workday playlist sounds even more inspiring with full, immersive JBL Pro Sound. Use the JBL My Headphones app to customize the sound to your liking or choose presets from STAGE+ created by the world’s top DJs.
  • Adaptive Noise Cancelling with Smart Ambient
In a crowded coffee shop trying to drown out the loud conversation at the next table? Activate the noise-canceling technology and stay focused. Walking in a busy street? Let in the surrounding sounds and keep walking safely. Need to have a quick chat with your coworkers? TalkThru makes it easy to do it by keeping your headphones on.
  • Zero Hassle Connectivity
our JBL CLUB PRO+ TWS pair seamlessly to your device as soon as you flip open the case, thanks to Dual Connect + Sync technology. And no need to remember which one to grab first, because you can do all the things with either earbud, whether you’re using both or just one.
  • Even More Voice Clarity in Perfect Stereo Sound
Have no fear about taking a call outside on a breezy day. 3-mic beamforming technology delivers crystal clear calls with all the sound you want while eliminating the background noise you don’t.
  • All-Day Wireless Power
Make it all the way through your workday with an 8-hour charge and 3 times more from the case (24 hours). If you need a little extra juice, just 10 minutes in the charging case will get you another hour’s use. The stylish, ergonomic charging case supports both totally wireless Qi charging and Type-C connectors
  • Tap To Talk
Just tap the iconic JBL logo either to talk to Google or to activate Amazon Alexa. Three sensitive mics mean your digital assistant won’t have any trouble hearing or understanding you.
Driver Size 6.8 mm/0.27″ Dynamic Driver
Power supply 5V 1A
Earpiece 6.85g per pc (13.7g combined)/
0.015 lbs per pc (0.03 lbs combined)
Charging case 55.4g/0.12 lbs
Headset battery type Lithium-ion polymer
(3.7V, 55mAh)
Charging time (USB-C) 2 hrs from empty
Music play time with BT on and ANC on Up to 6 hrs
Music play time with BT on and ANC off Up to 8 hrs
Frequency Response 10Hz – 20kHz
Impedance 16 ohm
Sensitivity 102 dB SPL@1kHz/1mW
Maximum SPL 99dB
Microphone sensitivity 6 dBV@1kHz/Pa
Bluetooth version 5.1
Bluetooth profile version A2DP V1.3,
AVRCP V1.6, HFP V1.7
Bluetooth transmitter frequency range 2400 – 2483.5 MHz
Bluetooth transmitter power <9.5 dBm (EIRP)
Bluetooth transmitter modulation GFSK,
Ï€/4 DQPSK, 8DPSK
Maximum operation temperature 45°C
Look out for the JBL Club Pro+ TWS and more from JBL at Audio 46.
