Noble Audio has announced the launch of Osprey, a new addition to its acclaimed true wireless earbud range. Designed to bring the brand’s celebrated sound signature to a wider audience, the Noble Audio Osprey true wireless earbuds combine hybrid driver technology, high-resolution wireless codec support, and a premium design at a more accessible price point.
A New Entry Point Into Noble Audio’s True Wireless Range
Noble Audio has built a strong reputation among audio enthusiasts for precision tuning, distinctive craftsmanship, and high-performance sound. With Osprey, the company aims to make its true wireless listening experience more accessible without sacrificing the musicality and refinement associated with the Noble Audio name.
Positioned as the most approachable model in the Noble true wireless series, Osprey is intended for listeners who want a premium everyday earbud with engaging sound, modern wireless features, and a carefully crafted design.
Hybrid Dual-Driver Design for High-Fidelity Sound
At the heart of the Noble Audio Osprey is a hybrid dual-driver configuration that pairs a 10mm dynamic driver with a custom balanced armature. This setup is designed to deliver a full and expressive sound signature, combining controlled bass, natural mids, and clean, extended highs.
The earbuds offer a frequency response of 20Hz to 40kHz, supporting Noble Audio’s goal of delivering a cohesive and immersive listening experience. Osprey also supports LDAC, alongside SBC and AAC, helping preserve detail and resolution when paired with compatible devices. For listeners who want true wireless earbuds suitable for commuting, working, travelling, or relaxing at home, Osprey is designed to deliver balanced sound that remains comfortable and engaging during longer listening sessions.
Premium Noble Audio Design and Everyday Comfort
Osprey continues Noble Audio’s distinctive design language with a striking marbled faceplate finish, giving each earbud a refined and recognizable aesthetic. The design reflects the brand’s long-standing focus on craftsmanship and individuality. The earbuds are housed in a compact, ergonomic shell designed for a secure and comfortable fit. This helps improve passive isolation and ensures the hybrid driver system performs consistently. Multiple eartip options are included, allowing users to find the best seal for comfort and sound quality. A compact aluminium charging case adds durability and portability while maintaining a premium feel.
Bluetooth 5.4, ANC and Multipoint Connectivity
The Noble Audio Osprey is built around the Airoha 1571 chipset and supports Bluetooth 6.0 for stable wireless performance. The earbuds also include multipoint connectivity, allowing users to switch between devices more easily, such as a phone and laptop.
Additional wireless features include TrueWireless Mirroring, Active Noise Cancellation, and Hearing Through mode, giving listeners more flexibility across different environments. For calls, Osprey includes dual microphones with cVc noise reduction to improve voice clarity.
Battery Life and Charging
Battery life is rated at up to 7 hours of playback with ANC off and up to 5 hours with ANC enabled. The 500mAh charging case extends total listening time, while a 10-minute quick charge provides approximately 2 hours of playback. Charging is handled via USB-C, and the earbuds are supported by the Noble Audio app, which provides access to EQ controls and over-the-air updates.
Noble Audio Osprey Key Specifications
- Hybrid dual-driver configuration: 10mm dynamic driver + custom balanced armature
- Frequency response: 20Hz – 40kHz
- Bluetooth 5.4
- Airoha 1571 chipset
- Codecs: SBC, AAC, and LDAC
- Multipoint connectivity
- Active Noise Cancellation and Hearing Through mode
- Dual microphones with cVc noise reduction
- Up to 7 hours of playback with ANC off
- Up to 5 hours of playback with ANC on
- 10-minute quick charge for approximately 2 hours of playback
- USB-C charging
- Noble Audio app support with EQ and OTA updates
Pricing and Availability
The Noble Audio Osprey will be available for pre-order from 4 June 2026 through selected retailers, including Audio46. The earbuds are priced at $199.
Osprey will also be showcased at HIGH END Vienna 2026, allowing visitors to try Noble Audio’s latest true wireless earbuds ahead of release.
