HomeLatest NewsThe Perfect Workout Earphones - MEE Audio X8 Secure-Fit Wireless
The Perfect Workout Earphones – MEE Audio X8 Secure-Fit Wireless
Music is an important part of the modern day workout and having the right music playlist to accompany your daily exercise is essential. Even more essential to the music however is your earphones. Having the perfect workout earphones that stay in place and deliver quality sound can boost your mood through your daily exercise routine. The MEE Audio X8 Secure-Fit Wireless Sports Earphone is one of the latest products on the market that promises to deliver a lot to your workout.
The MEE Audio X8 Wireless Sports In-Ear Headphone utilizes a one-piece design. The left and right earphones are connected via a short, durable wire with all the controls and technology incorporated between. The X8 features an over ear design with flex-hooks that easily hooks over the ear and around the back of the neck. The pivoting nozzles on the eartips allow the earphone to stay in place while staying relatively comfortable during high-impact workouts.
The X8 In-Ear Headphone also features sweat-resistant nano coating for the most intense workouts and the inline rechargeable battery lasts up to 8-hours at a time. Pairing the X8 to your smartphone or wireless device is simple as it utilizes Bluetooth 4.1. You also get a carrying case with the X8 and 4 sets of eartips in different sizes for a perfect custom fit.
MEE Audio is known for quality in design and sound. The X8 Wireless Wireless Sports Earphone delivers excellent sound with full bass making it perfect for intense workout sessions. The inline microphone and controls are the icing on the cake as the X8 can have you from workout mode to business mode in seconds. Make or take calls via your smartphone with the push of a button and get back to your mix in no time.
So what makes the X8 Wireless from MEE Audio the perfect workout earphone? They’re durable, easy to use and sound great. All for a great price. Finding a good set of workout earphones is tough and you won’t find a better Bluetooth Sports earphone in the under $100 range that works as well as the X8.
SPECIFICATIONS
Speaker Specifications
driver size 8 mm
frequency response 20 Hz to 20 kHz
Bluetooth Specifications
Bluetooth version 4.1
operating range 30ft (10m)
Bluetooth profiles supported A2DP, HSP, HFP, AVRCP
additional audio codecs supported SBC, aptX®, AAC
Battery Specifications
battery type 2x built-in rechargeable Li-Poly battery
music playback time 7.5 hours
talk time 8 hours
standby time 300 hours
charging time 2 hours
charging connector type micro-USB
Microphone Specifications
directivity omnidirectional
frequency response 100 Hz to 8 kHz
Product Details
ear coupling intraaural (in-ear)
cable length 14.5 inches (37 cm)
weight 0.5oz (16g)
water resistance technology splash-proof nano-coating
Steven Newcastle
Noble Audio Iris Review: A Refined Dynamic-Driver IEM
Noble Audio has built its reputation on visually distinctive IEMs with carefully engineered sound, and the Iris brings that philosophy to a more focused...
