- Egret headphones
- 4.4 balanced cable
- Leather carrying case
- Hemp bag
- 3.5mm adapter
- Quarter-inch adapter
The Sendy Egret is a lot like the rest of their selection, well-crafted and aesthetically pleasing. It’s built like Sivga’s P-II model with a slightly different grille pattern. The wooden build and metal frame always feel very premium on Sendy headphones, but that wouldn’t matter as much if they weren’t comfortable. Thankfully, the Egret features soft pads and an adjustable suspension headband that allows for a flexible fit that feels secure without any unnecessary pinch. As a bonus, the Egret has a pretty spectacular stock cable. It’s a dual-sheathed design with a durable PVC jacket that combines copper and silver in a nice braided chord.
The Egret supports a significantly large 98*84 planar magnetic driver with a nano-scale composite diaphragm. It uses electric beam evaporation to coat the aluminum circuits onto the diaphragm. This is implemented to ensure precise vibration control, cleaner layering, and a stable signal output.
The more I listened to the Egret, the more I felt like it desperately needed to break out of its shell. Soundstage and spatial imaging are the biggest culprits for this, appearing narrow and not very open. Only when instruments occupy the hard ends of the left and right channels does the Egret display any considerable wingspan. Otherwise, the soundstage has trouble dictating channel separation, resulting in a stereo field that appears tall but non-distinct in terms of positioning.
While the scale of the bass is admirable, the Egret is a bit dry in its timbre. There’s little texture, and the sub-bass is almost muted. It’s a tone that feels limp, but you can still feel its presence. The bass isn’t completely missing from the sound signature, but it certainly doesn’t make a significant impression on you. Bass notes slightly resolve with detail and control, but nothing is quite natural, and the coloration is pretty plain.
The midrange oushes forward and has more defined properties, but the Egret, again, runs into a timbral gripe. Everything feels cold and resembles the same dryness that the low end has. Instruments have a standard level of clarity, but there’s virtually no room for the midrange to express space, so nothing feels localized or layered. This results in a midrange that has a clinical display without any of the grace.
The highs are the most satisfying region of the sound signature. Its timbre has the cleanest frequency content, featuring the most resolving details that result in extended tails and even some shimmer. Nothing feels harsh, but the Egret is also not shy about expressing crispness. It’s the most natural part of the sound signature, appearing like a veil being lifted to show you raw high-end tone.
The Sendy Egret is a headphone that makes a strong first impression through its premium construction, thoughtful ergonomics, and technically ambitious planar magnetic driver. Its design reflects the brand’s commitment to craftsmanship, offering a luxurious feel that easily competes with other headphones in its class. Comfort is also a highlight, making it suitable for extended listening sessions without fatigue. However, when it comes to sound performance, the Egret presents a more nuanced picture. While the treble delivers excellent clarity and resolution, the overall tuning leans toward a dry, clinical character that may not appeal to listeners seeking warmth or musicality. The soundstage feels constrained, and both the low end and midrange lack the richness and spatial depth needed to fully immerse the listener.
For those prioritizing build quality, detail retrieval, and a clean high-end response, the Sendy Egret still holds appeal. But if your preferences lean toward expansive staging, natural timbre, and a more engaging tonal balance, there may be stronger contenders in the planar magnetic headphone space.
| Pros | Cons |
The Sendy Audio Egret is available here.
You can find more from Sendy Audio at Audio46.
