HomeIndustry NewsSNOWSKY Launches Nature Headphones and Echo Nano Hi-Res Music Player
SNOWSKY, FiiO’s lifestyle-focused audio brand, has introduced two affordable products designed to encourage more intentional listening. The new lineup includes the Nature over-ear headphones and Echo Nano, an ultra-compact high-resolution music player inspired by the portable MP3 players of the 2000s. While Nature emphasizes large dynamic drivers and a natural tonal presentation, Echo Nano offers local lossless playback in a device small enough to fit comfortably in the palm of a hand. Both products are available now, with prices starting below $50.
SNOWSKY Nature Features a New 50mm Dynamic Driver
The SNOWSKY Nature is built around a newly engineered 50mm dynamic driver. Its larger diaphragm is designed to move more air while maintaining control throughout the frequency range, promising greater authority, reduced distortion, and a more realistic presentation.
Central to the driver is a Japanese carbon black composite diaphragm. Its construction combines a 19-micron PET structural layer with a 30-micron TPU damping layer, balancing rigidity with flexibility. According to SNOWSKY, this combination helps minimize the metallic or plastic coloration sometimes associated with conventional diaphragm materials while preserving natural timbre and transient detail. The company says its goal was not simply to improve measurable performance, but to create a more lifelike and emotionally engaging listening experience.
Nature Combines Practical Design With Balanced Cable Support
Nature uses a self-adjusting sliding headband and weighs 280 grams. A detachable dual 3.5mm TRS cable makes the headphones easier to maintain and allows listeners to substitute compatible balanced headphone cables. An included microphone-equipped cable provides in-line controls for calls and everyday media playback. This mixture of replaceable connections and balanced cable compatibility gives Nature some welcome flexibility at its entry-level price.
Echo Nano Revives the Dedicated Portable Music Player
The SNOWSKY Echo Nano is a tiny high-resolution music player inspired by the simplicity of early-2000s MP3 players. It is intended for listeners who want to enjoy their music libraries without the notifications, apps, and other distractions associated with smartphones. Its enclosure is CNC-machined from 6-series aluminum-magnesium alloy. Navigation is handled through a multifunction metal scroll wheel, while a low-power 0.91-inch OLED display shows essential track information. At only 84 × 23 × 14mm and 33.5 grams, the Echo Nano is designed to be highly portable. It is available in Black, White, Pink, Sky Blue, Green, Purple and Titanium finishes.
Cirrus Logic DAC Supports Hi-Res PCM and Native DSD
Inside the Echo Nano is a Cirrus Logic CS43131 DAC. Local playback supports PCM files at resolutions up to 24-bit/192kHz and native DSD decoding up to DSD256.
Supported formats include:
  • DSD
  • WAV
  • FLAC
  • APE
  • MP3
  • M4A
  • OGG
  • WMA
The player supports microSD cards with capacities up to 256GB, providing space for a substantial offline music library. SNOWSKY estimates that this is enough storage for approximately 500 albums, depending on file format and resolution. A five-band dynamic equalizer is also included, offering six built-in presets alongside a customizable EQ option.
Echo Nano Doubles as a USB DAC
In addition to local music playback, the Echo Nano can operate as a USB DAC for smartphones and computers. Its UAC-compliant USB DAC mode supports playback up to 48kHz/16-bit, allowing compatible devices to use the Nano’s dedicated Cirrus Logic audio circuitry. The unit also provides USB data mode, firmware updates over USB and support for CTIA-compatible in-line headphone controls. Wired headphones connect through a 3.5mm single-ended output. In high-gain mode, the Echo Nano delivers up to 125mW per channel into 32 ohms. Its listed audio specifications include a signal-to-noise ratio of at least 129dB, dynamic range of at least 127dB, and THD+N below 0.0003%.
The SNOWSKY Nature headphones and Echo Nano portable music player are available now.
