HomeIndustry NewsYamaha R200A Stereo Receiver Combines 100W Power, Bluetooth, and Vinyl Playback
Yamaha has introduced the R200A, a two-channel Hi-Fi stereo receiver designed to make traditional and modern music sources easy to access from a single component. Available in black or silver, the Yamaha R200A combines 100 watts per channel of amplification with Bluetooth Multipoint, a dedicated phono input, an AM/FM tuner, and support for two pairs of speakers.
Positioned as an approachable starting point for a home Hi-Fi system, the R200A can accommodate vinyl playback, CD players, wireless streaming, radio, headphones, and an optional powered subwoofer. Yamaha has also engineered the receiver with optimized Hi-Fi circuitry and an anti-vibration center beam to support clear imaging, dynamic performance, and a spacious soundstage.
Yamaha R200A Delivers 100W Per Channel
At the center of the Yamaha R200A is an integrated two-channel amplifier rated at 100W per channel into 8 ohms. Yamaha lists high dynamic power of 125W, 150W, 165W, and 180W per channel into 8-, 6-, 4-, and 2-ohm loads, respectively. The receiver has a specified frequency response of 20Hz to 20kHz within ±0.5dB, extending from 10Hz to 100kHz within ±3dB. Total harmonic distortion is rated at no more than 0.2%, while the CD input carries a signal-to-noise ratio of at least 100dB. Yamaha says the R200A’s internal design is intended to preserve musical detail while producing precise imaging and a wide soundstage. Its anti-vibration center beam helps reinforce the chassis and reduce unwanted resonance.
Bluetooth Multipoint Connects Two Devices
For wireless listening, the Yamaha R200A supports Bluetooth 5.3 with Multipoint connectivity. This allows two compatible source devices to remain paired simultaneously, making it easier to switch between music from a phone, tablet, or another Bluetooth device. The USB port is reserved for firmware updates rather than music playback. Wired source components can instead connect through the receiver’s three analog RCA inputs.
Dedicated Phono Input for Vinyl Playback
The R200A includes a dedicated phono input, allowing users to connect a compatible turntable without adding a separate external phono preamp. This gives the receiver a useful mix of classic and contemporary playback options, whether listeners are building a vinyl system or primarily streaming over Bluetooth. An integrated AM/FM tuner provides 40 station presets for quick access to music, news, and talk radio. Yamaha includes both AM and FM antennas in the box.
A/B Speaker Outputs and Subwoofer Expansion
With A/B speaker selection, the Yamaha R200A can power two pairs of speakers. Owners can use four speakers in one room or route audio to speakers in two separate spaces. Secure binding-post terminals provide the physical speaker connections. A dedicated subwoofer output also allows the system to expand with deeper low-frequency reproduction. This makes the R200A suitable for listeners who want to begin with a straightforward stereo setup and add a powered subwoofer later. The receiver can be operated from its front-panel controls or with the included remote control. An automatic standby function helps limit unnecessary power use, with standby consumption rated at 0.3W or less.
Yamaha R200A Specifications
  • Amplification: Two channels with subwoofer output
  • Rated output power: 100W + 100W into 8 ohms, 40Hz–20kHz, 0.2% THD
  • High dynamic power: 125W/150W/165W/180W into 8/6/4/2 ohms
  • Frequency response: 20Hz–20kHz ±0.5dB; 10Hz–100kHz ±3dB
  • Total harmonic distortion: 0.2% or less
  • Signal-to-noise ratio: 100dB or greater for CD input
  • Analog RCA inputs: Three
  • Phono input: Yes
  • Headphone output: Yes
  • Subwoofer output: Yes
  • Bluetooth: Version 5.3 with Multipoint
  • Radio: AM/FM tuner with 40 presets
  • Speaker support: A/B speaker selection
  • USB: Firmware updates only
  • Dimensions: 17.13 × 5.39 × 12.91 inches
  • Weight: 16 pounds
  • Finishes: Black or silver
What Comes With the Yamaha R200A?
The package includes the Yamaha R200A Hi-Fi stereo receiver, a remote control, two AAA batteries, AM and FM antennas, a Quick Guide, and a Safety Guide.
A Versatile Starting Point for a Hi-Fi System
The Yamaha R200A brings together the features many listeners need for an accessible two-channel setup. Its 100W-per-channel amplifier, Bluetooth Multipoint support, phono input, radio tuner, A/B speaker outputs, and subwoofer connection provide plenty of flexibility without making the system unnecessarily complicated.
For music fans assembling their first component-based stereo, or anyone seeking a straightforward receiver for wired and wireless sources, the R200A appears designed to offer a practical route into Yamaha Hi-Fi.
You can find more from Yamaha on their website here, and from Audio46.
Bluesound Adds Apple Music to BluOS With Free Software Update
Bluesound has announced Apple Music support for its wireless speakers, stereo components, and soundbars through a free BluOS software update. Available starting October 20,...
