Sound Particles has announced the release of inShaper, a new waveshaper plugin aimed at music producers and post-production professionals looking for creative distortion with minimal complexity. Designed to deliver interesting sonic results through a streamlined interface, inShaper focuses on expressive sound shaping, real-time modulation, and compatibility with modern immersive workflows.
Rather than overwhelming users with technical barriers, inShaper emphasizes fast experimentation, allowing distortion to become a musical and rhythmic tool rather than a static effect.
Dual-Waveform Distortion for Richer Harmonics
At the core of inShaper is a flexible Single- and Dual-mode design. Users can work with a single shaping curve for precise, controlled distortion or blend two curves together for more harmonically complex results. This dual-waveform approach enables subtle saturation, aggressive wave folding, or evolving textures that respond dynamically over time.
The modifier mix between curves can be modulated in real time, making it possible to smoothly morph distortion characteristics and create constantly shifting timbres—ideal for sound design, electronic music, and cinematic effects.
LFO Modulation for Rhythmic and Evolving Distortion
InShaper includes an integrated LFO modulation system that allows users to animate key parameters such as drive, gain, bias, and modifier mix. With multiple waveform options, DAW synchronization, and channel offset controls, the plugin excels at creating rhythmic distortion effects that move in time with a project.
This modulation system makes inShaper particularly useful for pulses, movement-based textures, and evolving soundscapes, where distortion becomes part of the groove rather than a fixed coloration.
65+ Shaping Curves and Gain-Linked Drive Control
The plugin offers over 65 shaping curves, ranging from subtle waveshaping to aggressive distortion and wave folding. This wide selection allows producers to explore everything from warmth and punch to extreme sound design.
To maintain musical balance, inShaper features a drive linked to gain, ensuring that added distortion character does not result in unwanted volume jumps. This makes it easier to dial in saturation while keeping output levels consistent across a mix.
Spatial Modulation and Multichannel Support
A standout feature of inShaper is its ability to work with space. By applying different LFO offsets to each speaker, users can create spatially dynamic distortion effects that move across the sound field. This makes the plugin especially appealing for immersive audio, film, and game audio workflows.
InShaper supports mono, stereo, surround, and immersive formats, ensuring compatibility across traditional music production and advanced post-production environments.
Key Features at a Glance
- Dual-waveform engine with Single and Dual shaping modes
- 65+ distortion and waveshaping curves
- Drive linked to gain for consistent output levels
- Advanced LFO modulation with DAW sync and channel offsets
- Spatial distortion through per-speaker modulation
- Full multichannel and immersive audio support
A Creative Distortion Tool for Modern Production
With inShaper, Sound Particles continues to expand its ecosystem of creative audio tools, delivering a distortion plugin that balances depth with accessibility. Whether used for subtle harmonic enhancement, rhythmic modulation, or immersive sound design, inShaper positions distortion as a dynamic and expressive element within modern music and post-production workflows.
You can check out inShaper, including a free trial here.
