HomeFeatured ColumnsNew Release MEE Audio M6 PRO 2nd Generation with Customization
Cult followers of MEE Audio are in for a treat as the company has just launched the second iteration of their popular M6 PRO in-ear monitors. Meet MEE Audio M6 PRO 2nd Generation with Customization.
The new IEM retains the key features found in the first generation M6 PRO consisting of an over-ear hook design for a secure fit, MMCX connections for swapping out detachable cables, and multiple ear tips (foam and silicone) for users to find the perfect fit. The included Comply foam tips were specially selected for their ability to reduce outside noise which enables safer listening volumes and improves sound quality for a superior audio experience.
The earbud housings have also been modified for added durability. M6 PRO housings are sweat-resistant and their connection points and other hardware have been redesigned for the 2nd generation model to improve toughness under harsh conditions. The cables, as I previously mentioned, are interchangeable. You’ll find both an audio cable and a cable with a built-in mic and controller in the box.
Probably the most exciting feature is customization. MEE Audio M6 Pro 2nd Generation is specially designed to fit personalized custom-engraved faceplates. P.S. These are fashioned exclusively for use with MEE Audio M6 PRO 2nd Generation.
MEE Audio also includes a lifetime replacement guarantee (even for pairs that you’ve lost). You’ll need to simply contact MEE Audio, let them know what the deal is, and pay half the price of your original pair for a replacement. Not bad!
If interested, MEE Audio M6 PRO is available for a mere $49.99. MEE Audio Artwork engraved faceplates are an additional $20 and custom faceplates are $30 from MEE Audio. If you order now they’re offering a special $5 discount.
Driver Dynamic, 10mm
Frequency Response 20 Hz to 20 kHz
Impedance 16 Ohms at 1K
Sensitivity 100±3 dB (1mW at 1KHZ)
Maximum Power Input 30mW
Cable 51 inches (1.3m), detachable, 3.5mm, right angle plug
Water Resistance Rating IPX5
Included Accessories
M6 PRO In-Ear Monitors
Stereo Audio Cable
Stereo Cable with In-Line Remote and Mic
Carrying Case
Comply Memory Foam Eartips
Silicone Eartips (6 pairs)
Shirt Clips (2)
Quarter-inch Adapter
User Manual
Sade
Sade
Meze Arta vs. Empyrean II: Which Planar Headphone Has the Better...
The Empyrean II already feels like a complete expression of what Meze does well. It has the comfort and craftsmanship the brand is known...
