HomeReviewsAudiophile Reviews64 Audio Ocean Review: Can These High-End IEMs Raise the Bar?
64 Audio has given audiophiles plenty of reasons to take in-ear listening seriously, and the Ocean offers a fresh opportunity to hear what the brand can achieve. In a crowded field of high-end IEMs, reputation and an elaborate driver configuration only tell part of the story. What matters is how convincingly everything comes together when the music starts. Let’s explore its design, comfort, and sound to see where it stands in the world of premium in-ear monitors.
  • Ocean Universal In-Ear Monitors
  • Carry Case
  • TrueFidelity Foam Tips (S, M, L)
  • SpinFit Silicone Ear Tips (S, M, L)
  • Silicone Ear Tips (S, M, L)
  • 3.5 mm Shielded Cable
  • 4.4 mm Balanced Shielded Cable
  • Shirt Clip
  • Cleaning Tool
  • Cleaning Cloth
  • Round Sticker
  • Apex Modules (m20, m15, m12, mX)
64 Audio Ocean single
If you’re familiar with the design of most 64 Audio IEMs, the Ocean keeps a lot of the brand’s staples. Everything from its shape to its aluminum shell gives you everything you would need from a high-end IEM from 64 Audio. The Ocean’s main identifier is its wavy faceplates, which are machined and finished with a champagne copper. IEMs rarely have as good a build as 64 Audio IEMs, and the Ocean is no exception, but how do they feel to wear? They’re as good as the rest of them in terms of comfort. They’re light, and the housing sits in your ear, so long as you choose the right set of tips, and thankfully, the Ocean comes with an abundance of them.
64 Audio Ocean cable
The 64 Audio Ocean is a six-driver hybrid in-ear monitor featuring two dynamic drivers in a cone-to-cone isobaric arrangement for bass, two midrange balanced armatures, one high-mid balanced armature, and a tia high-frequency driver. It has interchangeable apex modules, back-vent filters, and stainless steel tia screens, offering 32 tuning combinations.
  • Frequency Response: 5 Hz – 22 kHz
  • Sensitivity: 103.7 dB/mW @ 1 kHz
  • Impedance: 9.5 Ω @ 1 kHz
64 Audio Ocean pair
As soon as I hit play on the first track, the Ocean opens up and spreads out considerably. You are met with an immense scale that engulfs your head in its stereo sound, with massive width and spacious imaging. Almost immediately, I knew this was a winner. I’ve heard IEMs with great soundstages that cost much less than the Ocean, but they can never reach this level of precision and bigness. I have never heard a set of IEMs sound so direct yet so grand in its presentation. Yet, the Ocean very much sounds like an IEM soundstage, rather than a vast open space where the instruments float around for general immersion. The Ocean has impeccable dimension that allows the sound to breathe while still being very up in front of your face. It offers plenty of headspace, but the imaging stays concise and anchored, so everything is easy to localize at a glance. The result is a soundstage that reproduces a real space, not an exaggeration of one. You can hear piano keys gliding across the left and right channels with some up-and-down motion, calling attention to mic placement, and enveloping you in the physical presence of that instrument.
The 64 Audio Ocean comes with various extractable nozzles and filters that alter the sound with subtle changes. To me, the reference filters are how the Ocean is supposed to sound, sticking to purity and detail over texture and coloration. That doesn’t always go over well with the bass heads, but the Ocean includes these screw-in filters that will boost the lows a few notches. By itself, the Ocean’s reference tuning reproduces a punchy, hard-hitting bass that is exceptionally resolving and tactile. Bass notes are full and come through with a naturalistic timbre. The frequencies are very balanced, but still have good impact. If you need your lows to show some more gusto, screwing in the red filters has some slight benefits. The sub-bass has significantly more bloom to it, as the frequencies rise up to a more present surface and vibrate. No matter how you tweak it, the bass will show you impressive clarity and weight; it just depends on how much you want of it.
The midrange frequencies really dominate the sound signature of the Ocean. It cuts forward, showcasing sharp transients that result in fast attacks on notes for a lively response from instruments. It’s dense and rich with details, and so transparent that the natural buzz of strings resonates with an elegant glow. Everything is right there, bodied and defined for an incredibly vivid presentation. Vocals feel underlined with a sense of command, appearing above the instruments and sitting slightly around your forehead. For those looking for midrange purity and hyper-detail, the Ocean feels like the new standard for that in IEMs.
You might be expecting this region to be very bright, and while that tone is there, it is highly refined. The treble has a satisfying glint to it that lets the high frequencies be naturally biting while expressing good control and dynamism. Its tail doesn’t seem to extend that far, but the surface of the tone is resolving enough to portray a natural form. It sparkles and glistens but also sounds tight and organic, never feeling like it’s too much to handle.
The 64 Audio Ocean delivers one of the most compelling listening experiences I’ve had with a pair of IEMs. Its spacious soundstage earns attention immediately, but the precise imaging and vivid midrange make the deeper impression. Instruments have convincing body and texture, vocals command the mix, and the bass brings satisfying impact without obscuring finer details. Refined treble ties everything together, adding sparkle while keeping the presentation controlled. The tuning options give you room to adjust the balance, although the reference configuration already feels remarkably complete. For listeners who prioritize midrange clarity, natural timbre, and a grand yet focused presentation, the Ocean makes a strong case for itself among high-end audiophile IEMs.
The 64 Audio Ocean is available at Audio46.
