HomeReviewsAudiophile ReviewsAudio-Technica ATH-AWX7000 Review: Beautiful Wood, Bold Sound
Wooden headphones have long held a special place in Audio-Technica’s lineup, combining traditional craftsmanship with the pursuit of high-end sound. The Audio-Technica ATH-AWX7000 continues that tradition, entering a competitive field of closed-back audiophile headphones where distinctive materials are only part of the appeal. At this level, the listening experience needs to be just as compelling as the presentation. Let’s explore its design, comfort, and sound to see how this latest wooden headphone makes its mark.
  • Cable (3.0 m (9.8′)/6.3 mm (1/4″) gold-plated stereo plug)
  • Balanced cable (2.5 m (8.2′)/XLR-M connector (4-pin))
  • Hard shell carry case
  • Cable pouch
Audio-Technica ATH-AWX7000 headband
Audio-Technica’s wooden headphone designs are back with the AWX7000. Inspired by Shinto shrines and Buddhist temples, the AWX7000 has beautifully hand-finished ear cups with Echizen lacquer. The earcups are made from deerskin, and everything is supported by a magnesium frame. Not every set of high-end headphones needs to have a sound design philosophy or theme behind it, but it’s always appreciated when it does. This translates to the fit as well, as the AWX7000 has a good level of comfort for long listening sessions. There isn’t a ton of weight to them, and the frame feels sturdy, making the cups feel secure as the pads rest gently on your head.
Audio-Technica ATH-AWX7000 ear cups
The Audio-Technica ATH-AWX7000 features 58mm dynamic drivers that combine newly developed HMD (Hybrid Matrix Diaphragm) technology with the precision HXDT molding process introduced in the ATH-ADX7000. Each composite diaphragm pairs a polymer film with a metal dome, using an expanded bonding area to distribute stress and help maintain its shape under high air pressure. HXDT molding ensures precise diaphragm roundness, allowing the assembly to move as a single unit with controlled, piston-like motion. This construction is designed to improve transient response and dynamics while maintaining stable movement at frequencies below the audible range for extended bass reproduction. A magnetic circuit incorporating non-oriented electrical steel sheet further minimizes energy loss and improves electrical conversion efficiency.
Audio-Technica ATH-AWX7000 above
A closed-back headphone doesn’t always mean the soundstage feels limited by physical barriers. The AWX7000 is the perfect example of just how open and immersive a closed-back headphone can sound. Its spatial display sets a high standard for closed-back headphones that aim to deliver accurate positioning while letting elements take full form in a localized area of the mix. When you pan different instruments to a specific position, the AWX7000 presents them in a truly carved-out space. This lets the sound take on a new dimension, where the space around the instrument becomes part of that sound’s identity.
Its ability to separate these layers is impeccable compared to other closed-back headphones, letting the soundstage breathe in an immersive space. It’s not just a floaty space, though, as the AWX7000 still prides itself on being articulate and studio-quality, making it one of the rare closed-backs that has anchored spatial positioning while still feeling like your head is encased in a sound dome. So you get studio-quality presentation with a live setting, where everything sits in front of you at close range. You’re not just listening to two separate channels being blasted into your ears; the soundstage projects the space with natural scale.
The AWX7000 has a substantial bass response that makes the biggest impression on the sound signature. Tonally, the AWX7000 is very bold, with a level of impact that vibrates the foundations of the lows. There’s a thickness to it that makes the timbre very dark but not unclear. You still get a sense of finesse with bass grooves and drum kicks, which feel rounded and articulate in their movement. If the AWX7000 didn’t have this sense of bass depth, I can sense it might degrade into a foggier resolution. Instead, you get a bass that has a defined, physical resposne with a particular coloration that has an earthy texture. The sub-bass has a lively rumble which expands outward for a very enriching sound. The frequency content is dense, resulting in a highly resonant mid-bass that is responsible for a lot of that dark tonality. It’s also responsible for the AWX7000’s punch, which is hefty and full. If you get excited by headphones that have a cinematic bass scale, the AWX7000 is one of the best I’ve heard in a while.
For lack of a better word, the midrange of the AWX7000 is weird. The meat of the instruments keeps that low-mid focused warmth while keeping ressonance controlled so that the surface of the sound is clear and detailed. Nothing is veiled, even with the bleedy extension of the low-mids. Instruments have good shape, and notes have directness in the mix. Transients are a bit slow, but the full scale of the sound elements comes in with a full display. Now for where the weirdness comes in. It’s the vocal resposne. Both male and female vocals have a strange hollowness to them, sometimes placing them behind the instruments. They consistently feel far away, never taking a commanding stance in the mix, creating this dissonance between the instrumental clarity and the vocal clarity. It’s a weird dynamic, but it’s not necessarily something that keeps me from enjoying the sound signature.
The AWX7000 feels like it shouldn’t have the high-frequency detail it does. A lifted treble with instances of glistening tones really helps round out the sound signature in interesting ways. With the mid-treble being lower in the mix, the upper-treble gets to make a statement, resulting in a glaring tone that might not be everybody’s cup of tea. There is brightness, and it can sometimes feel hot, but it is never piercing. They have a raw presence in the mix that can be quite biting at times, but not to a degree where the headphones are hard to listen to.
The Audio-Technica ATH-AWX7000 delivers a memorable listening experience, with an expansive soundstage and substantial bass that give music an immersive, almost cinematic scale. Its precise imaging and instrumental separation keep that presentation articulate, while the lacquered wooden design and comfortable fit add to its appeal as a luxury closed-back headphone. However, its tuning comes with some distinct quirks. Vocals can sound hollow and distant, and the upper treble occasionally brings a biting brightness that sits in unusual contrast to the warm, dense lows. Those characteristics make it harder to recommend universally, particularly for listeners who prioritize vocal presence or tonal neutrality. For those drawn to powerful bass, convincing spatial depth, and traditional Japanese craftsmanship, though, the ATH-AWX7000 offers a distinctive experience worth hearing.
Pros  Cons
  • Spacious soundstage with precise imaging
  • Powerful, textured bass
  • Clear instrumental separation
  • Beautiful lacquered wooden ear cups
  • Comfortable fit and sturdy magnesium frame
  • Vocals can sound hollow and distant
  • Pricey
The Audio-Technica ATH-AWX7000 is available at Audio46.
