Home Reviews Headphone Reviews Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Review
Buy Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones
Just the other day I got a chance to listen to the Audio Technica ATH-ANC700BT. It was a really awesome and affordable wireless, noise cancelling headphone, and if you haven’t had a chance to check out the review, I recommend doing so here. However, today I received another new wireless, noise cancelling headphone from Audio Technica, the ATH-WS990BT. This one falls into the Solid Bass line and costs a bit more than the other. So how does this one perform? Is it worth spending the extra $50 on them? Today I’ll find out with this Audio Technica Solid Bass ATH-WS990BT wireless, noise cancelling headphones review.
In the Box – Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Review
-Audio Technica Solid Bass ATH-WS990BT headphones
-1.2 m audio cable
-Micro USB charging cable
-Drawstring carrying pouch
-Documentation
Specifications – Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Review
-Frequency response: 5 Hz to 40 kHz
-Impedance: 30 ohms
-Sensitivity: 101 dB/mW
-Driver: 53 mm, dynamic
-Type: over-ear, closed back, wireless, noise cancelling
-Bluetooth codec: Bluetooth 4.1, aptX, AAC, SBC
-Battery life: 25 hours when Bluetooth and noise cancelling used; 30 hours when only Bluetooth used
Design – Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Review
Headband
The headband of the Audio Technica Solid Bass ATH-WS990BT is made of metal. On its underside is a memory foam cushion coated in soft perforated pleather. In addition to its soft cushion, the headphones are also comfortable because the don’t clamp the head super tightly. Additionally, they are very flexible and would easily fit folks with bigger heads than mine.
Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Headband
Earcups
The earcups of the Audio Technica Solid Bass ATH-WS990BT are pretty large and oval-shaped. Toward the bottom of the cups, you’ll find all the buttons and controls (on/off, volume, playback, noise cancelling, etc). The cups are plastic and swivel, rock and turn in their yolks. Additionally, they have a pretty sleek and snazzy look.
Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Earcups
Earpads
The Audio Technica Solid Bass ATH-WS990BT has angled, memory foam earpads which are coated in the same soft pleather material as the headband. There is a lot of space in the middle of the pads for larger ears. Additionally, the pads are thick enough so the ear doesn’t touch the earcup. They are comfortable and accommodating.
Audio Technica Solid Bass ATH_WS990BT Bluetooth Noise Cancelling Headphones Earpads
The headphones were easy to connect to my phone. Once I turned them on, they popped up in the Bluetooth device list on my phone immediately. I was most impressed by the strength of the Audio Technica Solid Bass ATH-WS990BT’s Bluetooth connection. I walked over 30 feet away and the headphones wouldn’t break up even when I didn’t have line of sight.
Noise Cancellation
The noise cancellation of the Audio Technica Solid Bass ATH-WS990BT is pretty light. It is not super intense at all. For those that like a mild noise cancellation, you’ll like it in these headphones. Additionally, a touch control on the bottom of the earcup toggles the noise cancellation on and off. Also, it can put the headphones into “hear through” mode, which amplifies the world around you using the same microphone used in the noise cancellation.
Sound – Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Review
Low Frequencies
As you might expect by the name of these headphones the Audio Technica Solid Bass ATH-WS990BT headphones are heavy on the low frequencies. This heaviness works really well for some genres, and not so well with others. Regardless, if you’re a basshead, these headphones will not disappoint. The low end is fun and energetic, and can add emotional impact especially in genres that use a lot of synthesized instruments like pop, hip-hop, and electronic music.
Mid Frequencies
The Audio Technica Solid Bass ATH-WS900BT headphones emphasize the high-mid frequencies as well. As a result, the high-mids feel balance nicely against the bumped low frequencies. Additionally, vocals and other high-mid rich instruments like horns and strings have nice detail. The low mids are emphasized as well but blur a little bit with the low frequencies. As a result of this boost, the midrange feels a little bit scooped in general so pianos and guitars get more of their energy from the low-mid than from detail in the midrange.
High Frequencies
Additionally, due to a boost which sounds like it is around 10 kHz or 11 kHz, cymbals and the vocal breath sound airy, clear and detailed.
The soundstage of the Audio Technica Solid Bass ATH-WS990BT has pretty awesome left-to right image considering these are noise cancelling headphones. Additionally, the sense of height with these headphones impressed me because it was actually pretty decent in comparison to others in the price range. The sense of depth of the headphones isn’t great but I was still impressed with the responsiveness of these cans.
Overview – Audio Technica Solid Bass ATH-WS990BT Wireless Noise Cancelling Headphones Review
In conclusion, the Audio Technica Solid Bass ATH-WS990BT headphones are a really solid set of noise cancelling, wireless cans for the bassheads out there. The headphones are comfortable, the noise cancellation is mild, and the sound was good. It sounded the best to me with music with a lot of synthesized instruments like pop, hip-hop, and electronic.
The Audio Technica Solid Bass ATH-WS990BT headphones are available for the best price here:
Audio 46: Be sure to use the discount code “majorhifi”
Audio Technica Solid Bass ATH-WS990BT on Amazon
Buy Audio Technica Solid Bass ATH-WS990BT Best Bluetooth Noise Cancelling Headphones
Previous articleGrado SR80e vs Sennheiser HD 559 Comparison Review
Next articleFiiO F9 PRO In-Ear Headphones Review
