HomeBest OfBest Wireless Headphones That Feature LDAC 2026
If you read a lot of articles about Bluetooth headphones, you’ll see a lot of praise for products that include LDAC. This is a high-quality CODEC developed by Sony but appears in non-Sony products as well. By “high quality,” what it really means is better than your standard SBC, and AAC CODECs that feature standard lossy compression in most Bluetooth headphones. LDAC is still a lossy compression algorithm, but it can handle 990kbps transmission speeds compared to the 328kbps speeds you get from SBC and AAC. That’s what gets it that “Hi-Res” sticker for headphones that use it.
So what are some wireless headphones that use LDAC? There’s a lot out there, but they all contain different levels of sound quality and value through the features they offer. Not all LDAC headphones are the same, so here’s what I think you should look out for.
Sony WH-1000XM6
$459
The Sony WH-1000XM6 continues Sony’s reputation for class-leading wireless noise-cancelling headphones by refining nearly every aspect of the user experience. Its ANC performance remains among the best available, helping create a noticeably quieter and more immersive listening environment whether you’re commuting, traveling, or working in busy spaces. Sound quality feels more spacious and polished than previous generations, with a dynamic presentation that pairs well with Sony’s expanded EQ customization and spatial audio features. Combined with improved comfort, responsive touch controls, and dependable multipoint Bluetooth connectivity, the WH-1000XM6 positions itself as one of the most complete premium wireless headphone packages currently available.
Noble Audio FoKus Apollo
$649
The Noble Audio FoKus Apollo brings a distinctly audiophile-focused approach to wireless listening, combining a hybrid driver configuration with a rich, immersive sound signature that feels both spacious and highly musical. Its low end delivers strong impact and texture, while the overall presentation maintains impressive clarity and separation for a Bluetooth headphone. The Apollo also stands out for its premium build quality, long battery life, and versatile connectivity options, giving it a more upscale feel than many competitors in the category. Rather than chasing a purely analytical sound, it focuses on delivering an engaging and expansive listening experience that makes a strong impression across a wide range of genres.
Audio-Technica ATH-M50xBT2
$219
It’s very generous that the Bluetooth version of one of the most recognizable over-ear headphones supports LDAC. This makes it super easy to recommend, and the sound of the BT2 isn’t far off from what you already get from the wired version of these popular studio headphones. Of course, the wireless version isn’t going to be quite what you’re familiar with, but using LDAC might get you closer to that level of quality.
Edifier WH950NB
$179
It might be surprising to see an Edifier headphone on this list, but I find it to be one of the best and most inexpensive options out there with LDAC. The WH950NB will surprise you in a lot of areas, including its great build quality and battery life. Although there are some trade-offs, like weaker noise-canceling, the WH950NB excels where it needs to. This includes its sound signature, where you can expect a decent soundstage and expressive treble. Using LDAC here definitely complements its sound.
Photo of Mark Levinson No. 5909
Mark Levinson No.5909
$1,099
Going from one of the least expensive LDAC options to the most expensive is quite a jump. However, if you have the money to spend, it’s well worth it. The No.5909 is one of the best wireless headphones around, offering a more premium experience compared to what you’re used to hearing from your common consumer Bluetooth products. Although they’re very bass-heavy, the 5909 has some of the best detail and separation over Bluetooth. They’re extremely comfortable, feeling as premium as their price suggests. With the 5909 using LDAC, there’s no doubt it takes the top spot on this list.
