- Kiwi Ears x HBB Punch IEMs
- Zipper Case
- 2-pin cable with 3.5mm or 4.4mm connector
- S/M/L silicone ear tips
- 2 pairs of replaceable filters
- User manual
Kiwi Ears has some pretty stellar designs, and the Punch fits right with them. Being called “Punch,” I thought there would be more red worked into the shell’s color palette, but it’s hard to complain about the purple scales on black. You get your typical ChiFi IEM shape that is a good size to look like something that can reasonably fit in your ear. All the creases and bulges it features on its resin chassis are sure signs of a good fit, and that’s exactly what the Punch gives you. They hold steady in your ear and sit comfortably without any fatigue.
The Kiwi Ears x HBB Punch is a hybrid in-ear monitor built around a five-driver setup, combining one 10mm composite dynamic driver, two Knowles RAB 32257 balanced armature drivers, and two Sonion electrostatic drivers per side. Its tuning is centered on strong sub-bass impact, with a 15dB sub-bass emphasis handled by the dynamic driver, while the Knowles BA drivers support the midrange and the Sonion EST drivers extend the treble up to 40kHz. The design also uses a 3-way passive crossover with separate sound tubes for each driver type, helping the Punch maintain separation across its full 5Hz–44kHz frequency range.
There’s plenty to enjoy with the Punch’s soundstage and spatial imaging presentation. It spans fairly wide while allowing sound elements to showcase scale and positional accuracy. The soundstage never engulfs your head, though, and it shows a limited amount of headspace. As a result, the response feels flat, but the Punch is still able to stack its layers in a way that makes room for some spatial depth. This is mostly due to the fine level of separation the Punch is capable of, spreading out performances to put enough space between them, making each section more hyper-individualized. If you’re looking for something more holographic, the Punch doesn’t give you that, and its lack of height might turn you off a bit, but if you’re just looking for accurate placement, it’s more than acceptable.
Bass heads will be happy to know that the Punch’s most dominant feature is its low-end ability. It makes “Punch” a fitting name for this IEM, because that’s exactly what it does. It’s a deep, impactful bass that has a solid body lifted up by its sub-bass foundation. Ressonance is tight but vibrates richly, emphasizing the clarity and detail of this collection of low-end frequencies. What really makes it stand out to me is its sense of movement.
Bass notes don’t just bloom into the mix; they crawl up and emanate with a highly resolving surface. This gives the lows a lot of depth, but it also works for the bass dynamically, allowing it to be tonally gripping even when the bass takes a step back in the mix. This consistent propulsion of bass notes is super fun and exciting, but if you’re not into bass-heavy music, I can see the low-end profile being a bit overbearing at times.
Even if the midrange can’t match the bass’s energy, the Punch still provides an organized sound signature that keeps the frequencies from falling into the background. Its warmth is definitely the most prominent element of the Punch’s midrange timbre, but the rest of the resposne still reproduces a full tone that evens out the sound signature, keeping the frequencies from appearing like a haze. Everything has room to breathe, and specific plucks and strikes of notes can come through with clean detail. However, there’s a limit to how much individual instruments can snap in a mix. Transients arrive very softly, which keeps some sound elements from really cutting through and having an identity outside of the low-mids.
The treble lacks spark and crispness, leaving the frequencies feeling a tad dull outside of some clickiness. Nothing ever sounds muffled, but the roll-off is very steep here. If you find any sense of brightness fatiguing, the Punch will sound fine here, but as an overall sound signature, it feels like the highs are on a short leash.
The Kiwi Ears x HBB Punch is a fittingly named IEM that puts its strongest emphasis on bass impact, sub-bass depth, and overall low-end movement. Its dynamic driver gives the sound a strong physical foundation, while the rest of the hybrid driver system helps keep the presentation organized enough to avoid becoming overly messy or congested. The soundstage has good width and accurate placement, and the midrange maintains enough warmth and body to support the Punch’s bass-forward identity.
However, this is not an IEM for listeners who want a bright, crisp, or especially balanced sound signature. The treble is noticeably restrained, and the softer transient response means some instruments lack the sharper definition that more analytical IEMs can provide. Still, for those who want a comfortable, stylish hybrid IEM with a fun, full-bodied sound and serious bass authority, the Kiwi Ears x HBB Punch delivers exactly what its name promises.
| Pros | Cons |
The Kiwi Ears x HBB Punch is available from Linsoul.
