HomeReviewsHeadphone ReviewsBeyerdynamic DT 72 IE Review
Beyerdynamic continues to expand its Tesla.11 IEM series with the DT 72 IE, a model specifically tailored for guitar and vocal clarity. Designed with critical midrange detail in mind, these wired in-ear monitors aim to deliver a studio-like presentation of acoustic instruments and vocals. But how well do they hold up in everyday listening? Let’s break down what you get in the box, how the DT 72 IE feels in your ear, and most importantly, how it sounds across the frequency spectrum.
  • DT 72 IE DRUM & BASS
  • JACK ADAPTOR: 3.5 MM TO 6.35 MM
  • INTERCHANGEABLE WAX GUARDS
  • SILIKON EAR TIPS
  • COMPLYTM MEMORY FOAM EAR TIPS
  • HARDCASE
Beyerdynamic DT 72 IE single
I’ve reviewed the Beyerdynamic DT 70 and 71 IE already, and the DT 72 doesn’t change anything from those designs. You can expect the same shape and materials for its shell, which I find altogether very comfortable to wear, even if it requires you to bend the ear loops in the right way. I still wish these IEMs were at least color-coded so you could tell the difference between them all more easily.
Beyerdynamic DT 72 IE cable
All of these new Beyerdynamic IEMs use the same Tesla.11 dynamic driver. Just like all of the other IEMs in this line, the DT 72 IE uses a 3.5mm termination, and can be driven from any standard headphone output.
Beyerdynamic DT 72 IE pair
If all you need your IEMs to do is offer a wide soundstage, then the DT 72 IE will deliver that. It’s an unapologetically linear soundstage without a clear amount of depth to it. The spatial imaging is very accurate and defined, but everything sits on a flat plane in the stereo field. Nothing ever appears congealed in the mix, making the DT 72 IE a great option if you need all the instruments to be separated from each other distinctly. Don’t expect considerable tallness from these IEMs, but if you can get past that, you shouldn’t be disappointed.
This is not the IEM from this line that offers you bass. If you’re looking for a more engrossing bass response, check out the DT 70 and 71 IE. The DT 72 IE is comparatively limp in its bass response, however, it fits the IEM’s express purpose. For that reason, the bass doesn’t take anything away from the experience of listening, as long as you’re aware of the earphones’ guitar and vocal purpose.
All the meat that the DT 72 IE offers is in its midrange frequencies. As long as you’re exclusively listening to guitars and vocals, the DT 72 IE will have an incredibly natural and authentic response. Everything about these performances is transparent and articulate to a point where the instruments feel like they’re being played directly to you in a studio. It’s an incredibly realistic display of sound, one that’s uncolorized but still emotional. While there might not be much weight behind notes, there’s still a liveliness to the instrument that makes it feel very physical. The same goes for vocals, which are evenly balanced and full of expression. It’s the resolve that really captures performances well, especially from female vocal performances.
The treble has enough presence to make an impression, with ringing tails and specs of brightness that cover tones well. It’s all easy to consume, never feeling harsh, but also never feeling too soft. The timbre is as natural as the midrange, with a sense of control and tightness that helps make the sound signature feel complete.
The Beyerdynamic DT 72 IE may not be the go-to choice for bass heads or electronic music fans, but for guitarists, vocal enthusiasts, and those seeking an uncolored, midrange-focused IEM, it delivers in spades. Its honest sound signature makes it an excellent tool for studio work or casual listening where clarity and articulation are paramount. While it shares the same ergonomic and visual DNA as the DT 70 and 71 IE, the DT 72 IE stands apart with its tonal tuning and mid-centric performance. If you’re looking for a pair of IEMs that emphasize realism over richness, the DT 72 IE is one of the most compelling options under Beyerdynamic’s umbrella.
  • Exceptional midrange clarity
  • Accurate imaging
  • Comfortable fit
  • Natural timbre
  • Controlled treble
  • Lacks deep bass
  • Flat soundstage depth
  • Identical design to other models
The Beyerdynamic DT 72 IE is available at Audio46.
