HomeReviewsAudio Accessory ReviewsAbyss Diana TC Signature Review: One of the Best Flagship Planar Headphones...
Abyss Diana TC Signature Review: One of the Best Flagship Planar Headphones in 2026
In the world of ultra-high-end audiophile headphones, expectations are always immense. When a flagship model enters the conversation, listeners are looking for more than just impressive specifications or luxurious materials; they want an experience that feels worthy of the investment. The Abyss Diana TC Signature arrives with exactly those expectations attached to it, continuing one of the most recognizable premium planar magnetic headphone lineups on the market. Built for serious listening sessions and designed with Abyss’s unmistakable boutique approach, the Diana TC Signature aims to deliver a refined flagship experience for audiophiles searching for top-tier performance, craftsmanship, and long-term listening satisfaction. Whether you’re searching for a flagship audiophile headphone for critical listening, high-resolution playback, or reference-grade studio immersion, the Diana TC Signature positions itself as one of the most technically accomplished planar headphones available today.
  • Abyss Diana TC Signature Headphone
  • Lambskin Pillow-Top Lambskin Bass Ported Ear Pads (installed)
  • Abyss Diana Headphone Cable (choice of length and connector type)
  • Custom Hard Carry Case with Velvet Interior
  • Quick-start Instruction Card
Abyss Diana TC Signature headband
In terms of frame, this is the same Diana everyone is familiar with. The TC Signature has a new Fibonacci grille pattern, giving the headphones a slightly more futuristic boutique aesthetic, combined with an ultra-slim profile and precision-machined aircraft-grade aluminum construction and luxurious leather materials. One of the best changes to the Diana design is its headband, which favors a better seal than past versions of this model. Even though I’ve liked past versions of the Diana, getting a good seal on them is tougher than most other high-end headphones. With the Diana TC Signature, the ear cups have a better grasp on your head while staying away from a considerable clamp force. This makes the TC Signature the most comfortable version of the Diana yet, impacting both wear quality and sound isolation.
Abyss Diana TC Signature ear pads
The Diana TC Signature uses Abyss’s custom-built 63mm TC Signature planar magnetic drivers, engineered in-house with an ultra-thin diaphragm and a large high-strength neodymium magnet structure designed for exceptionally fast transient response and deep low-frequency extension. The planar transducer is tuned to reproduce sub-bass below 20Hz while maintaining high resolution and low distortion across its full 5Hz–58kHz frequency range. Its nominal impedance is 72 Ohms, which requires more power than most standard headphone outputs. If you’re spending this much on a pair of headphones, chances are you already have a good amplifier to drive them with. For this review, I used an Enleum HPA-23RM.
Abyss Diana TC Signature side
Being that the previous model has a pretty incredible separation and width, the signature version has me excited for how it could expand on such a display. On the TC Signature, separation is effortless, and it has more or less the same amount of scope as the original. Everything sounds like a live environment, and you’re in the front row. It’s like hearing a mix in a control room, where all the sounds are spaced out exactly where they need to be, reproducing individual performances with dimensional accuracy. It’s close, but in a way that still blooms outward, taking angles and distance into account. As a result, the Diana TC Signature can unfold arrangements from front to back with incredible precision, allowing the space to really breathe. It establishes an immersive stereo environment that prioritizes realism without sounding too clinical.
The scale is immense, yet it still sounds like a traditional stereo headphone. That’s really the advantage of the TC Signature’s soundstage over the original. It’s imaging just feels a bit more exact without sacrificing sounding completely flat. Its channel balance brings out more of the instruments’ identities, so they are properly carved out in the sound signature, with their full scope making themselves easily known to you.
If you’re looking for a specific amount of bass power in your premium headphones, the Diana TC Signature will definitely deliver. Its tone is rich and gripping, emerging with a vibrating growl in the sub-bass and hitting hard with ample mid-bass punch. Everything is tight and balanced, with virtually zero bleed for maximum clarity. Nothing about the bass is abrasive or dominating, but the frequency content can be very broad at times, allowing for gratifying grooves even with its neutral timbre. It’s just so resolving and smooth, with a level of detail that is extraordinarily refined.
I wouldn’t consider this a typical bass head response, but it’s hard not to be impressed with its level of control. The TC Signature’s impact is pretty standard, but the level of depth it portrays is extremely valuable. Everything sinks downward and expands without showing any signs of muddiness. There’s a clear body to the resposne in a way that feels evenly dispersed. It makes the lows feel very elegant, even when the scale of the bass isn’t as grand.
The midrange is where the Diana TC Signature shows its most resolution and transparency. Frequencies have a fast transient response, resulting in a sound that has a particular amount of finesse. Instruments are snappy and clean, fully emanating in the mix with liveliness and drive. The strike on notes is very impressive, articulating itself with exceptional clarity. There’s a strong body and shape to everything, allowing the frequencies to expand with fullness. The mids have a lot of layers, displaying a resposne that feels roomy, allowing you to pinpoint raw details and artifacts like finger movements on acoustic string instruments or short breaths from horn blows. Vocals are also very enticing, featuring an intimate response with plenty of command thanks to highlighted enunciation.
While the highs are not as forward as the bass and mids, they still have a lot of clarity. There’s some light shout to the mid-treble, but the frequency resposne really smooths out after that. You get a sense of elevation in the highs, and everything dissipates with a clear sizzle. It showcases a bit of air, but nothing that shows brilliance or glisten. I wouldn’t consider the Diana TC Signature to be sparkly, but the timbre has a slight tinge to it that rings out nicely. It clicks with detail, and its raised height makes all the difference in providing high-frequency definition to this sound signature.
The Abyss Diana TC Signature feels like a culmination of everything the Diana series has been building toward. It maintains the signature spaciousness, speed, and low-end authority that made previous versions so respected among audiophiles, while refining the fit, imaging precision, and overall tonal cohesion into something even more immersive. Its bass reaches astonishing depths without losing composure, the midrange is packed with texture and articulation, and the treble provides enough air and definition to keep the presentation lively without becoming overly analytical. More importantly, the TC Signature never sounds like it is chasing technicality for its own sake. Despite its immense resolving power, it remains emotional, dimensional, and highly musical. For listeners seeking a flagship planar magnetic headphone capable of delivering reference-level detail alongside a deeply engaging listening experience, the Diana TC Signature stands as one of the strongest high-end headphone options currently available.
The Abyss Diana TC Signature is available at Audio46.
