HomeReviewsHeadphone ReviewsEarFun Air Pro 4+ Review
The EarFun Air Pro 4+ enters the true wireless market as a feature-packed pair of earbuds designed for everyday listening, commuting, and high-resolution Bluetooth audio. Let’s break down the unboxing experience, design, functionality, connectivity, battery life, and full sound analysis to help you determine whether these earbuds fit your needs.
  • Air Pro 4+ true wireless earphones
  • Charging case
  • USB-C charging cable
  • 5 pairs of ear tips
  • User manual
EarFun Air Pro 4+ single
I’ve reviewed a handful of EarFun earbuds, and if you asked me to pick out a specific pair from a pile, I wouldn’t be able to, including the original Air Pro 4. The Air Pro 4+ is endearingly generic, but it is comfortable enough to make up for it. They are practical and ergonomic. Wearing these earbuds allows for unintrusive listening.
EarFun Air Pro 4+ case open
The Air Pro 4+ uses a hybrid dual-driver system, combining an ultra-light FeatherBA balanced armature driver with a powerful 10 mm composite dynamic driver. The drivers are aligned with an 11-degree offset inside a specially designed “Nano Side-Fitted Acoustic Architecture” (NSAA), a design intended to reduce interference between the drivers and deliver a clearer, full-spectrum sound.
In terms of ANC, the Ear Fun Air Pro 4+ features solid noise isolation for the price, although it has trouble attenuating high-end noise. Otherwise, the Air Pro 4+ is pretty advanced for $99 earbuds. They have AI-assisted adaptive ANC and environmental sound that detects obstructive noise in real time. It’s also advanced in its customizable controls and in-ear detection, which are highly responsive. Using the touch sensor controls on the earbuds gives you quick actions with only a slight delay.
EarFun Air Pro 4+ case closed
On the connectivity side, the earbuds run on Qualcomm’s QCC3091 chipset with Bluetooth 6.0 and support high-resolution wireless audio codecs (including LDAC, aptX Lossless, and LE Audio/LC3), enabling near-CD quality sound over Bluetooth. You also get a multipoint connection and fast pairing, making the Air Pro 4+ one of the best options for connectivity.
Battery and convenience features round out the package: the earbuds deliver up to 12 hours per charge (with ANC off) or around 8–10 hours with ANC on, and the included charging case extends total listening time to about 54 hours, with support for both rapid charging and wireless charging.
EarFun Air Pro 4+ pair
For a pair of affordable true wireless earbuds, the Air Pro 4+ conveys a good sense of space. It’s not a very wide stage, but instruments have a fair amount of separation and spatial identity. Everything is very closed-in and linear, but the Air Pro 4+ preserves what it can of the stereo field, avoiding a confined space where sound elements feel trapped in the middle. Nothing appears small either, as the Air Pro 4+ maintains a good sense of scale throughout each track. The soundstage conveys proper movement from left to right, even when hard barriers are easy to notice.
The Air Pro 4+ has a warm, thick bass with a fair amount of control. It’s easy for wireless earphones in this price range to have a muddier bass tone, but the Air Pro 4+ is surprisingly clean. It has an impressive bloom that will stand out to any bass lover, but it’s also a tight sound that separates itself from the low-mids. There’s not exactly a ton of depth to these frequencies, as everything pools to the surface, but the texture feels richer than most other wireless earbuds in this price range.
While definitely a V-shaped sound signature, the Air Pro 4+ has some impressive highlights in the midrange. Instruments have a simplistic level of clarity, but there’s actually some good definition here. Sound elements appear individualized in the mix, showcasing a roomy presentation that makes the Air Pro 4+ a more capable true wireless product than a lot of other earphones. Vocals are the most resolving area of the frequency response, featuring clear performances that appear intimate and immersive. You don’t get much note definition, but the veiled layer of texture doesn’t feel hollow. It’s a bit thin, but never muffled.
The treble is neither harsh nor detailed. It features a highly consumable range of tonal clarity without much height or fullness. There’s a clear clickiness to the timbre that allows for slightly more airiness, but the upper-highs are rolled off significantly. Everything is easy to digest, and even exhibits a fair level of gain, but its ability is quite plain.
The EarFun Air Pro 4+ manages to bring together an impressive list of modern features, hybrid drivers, adaptive ANC, LDAC streaming, Bluetooth 6.0, and multipoint, while still maintaining a strong sonic identity for under $100. Its warm, clean low end, intimate mids, and easy-listening treble make it a reliable choice for casual music lovers and commuters alike. While its soundstage and treble extension won’t compete with premium flagship earbuds, the Air Pro 4+ excels where it counts: comfort, functionality, battery life, and versatile everyday performance. If you’re looking for a high-value pair of true wireless earphones that deliver more than their price tag suggests, the EarFun Air Pro 4+ is absolutely worth considering.
• Strong codec support (LDAC, aptX Lossless, LE Audio)
• Effective adaptive ANC
• Long battery life with wireless charging
• Reliable Bluetooth 6.0 with multipoint
• Warm bass and clear vocals
• Responsive touch controls
• Rolled-off treble
• Narrow soundstage
• ANC struggles with high-frequency noise
• Generic design
The EarFun Air Pro 4+ is available directly from EarFun.
