Home Reviews Audiophile Reviews Final Audio D8000 DC Review
The world of high-fidelity audio is constantly evolving, and at the forefront of this evolution is the Final Audio D8000 DC Pro Edition Headphones. This review takes an in-depth look at what makes these headphones a remarkable choice for audiophiles and casual listeners alike. In this review, we explore the unique features, design enhancements, and sonic performance that set the D8000 DC apart from its predecessors and competitors in the market.
  • D8000 DC Pro Edition Headphones
  • Protective Hard Shell Suitcase
  • Washi Earpads (Installed)
  • 4.4mm TRRRS Balanced Silver Coated Cable
  • 4-pin XLR Silver Coated Cable
  • Final Audio Warranty
D8000 DC headband
Structurally, the D8000 resembles its past iterations with its classic appearance. However, Final has built the DC from the ground up, and there are little differences you start to notice when looking at the original. Of course, the most obvious difference is this version is completely silver instead of black, but there have been versions of the original D8000 like that before. Then I noticed the new grille ring surrounding the logo plate, and the new, thicker earpads. Then I picked up the headphones and they were shockingly light, with the large earcups not weighing them down whatsoever. It makes the flexibility of the D8000 much more of a factor, especially when concerning the fit.
This is the most comfortable these headphones have ever been, with the new washi paper earpads can headband padding combined with the improved clamp force resulting in the best seal possible. Adjusting the headphones and bringing the new headband padding down on your head feels so different from past models, and makes for a comfortable fit that I can wear for hours without feeling fatigued.
D8000 DC above
While the D8000 DC still supports a planar magnetic driver, it has been redesigned since the last few iterations. It implements a new Air Film Damping System (AFDS) which aims to improve transient response, as well as eliminate noise. Final Audio has also given the DC a re-engineered acoustic chamber for better signal flow and optimal tuning.
D8000 DC side
Listening to how the soundstage and imaging of the D8000 DC extend to reach its true scale is quite the experience. It feels encapsulating, as the soundstage of the DC can wrap around a wide-open headspace appearing like a bubble. The spatial imaging communicates a very holographic stereo field that individualizes sound elements with exceptional separation. You feel like you’re in the middle of everything, with all the instruments and effects floating around you. There’s a real live feeling to the sound like the track is being performed directly in front of you. It achieves this with its ability to feature specific positioning that showcases the distance between sounds. Having great height also grants results in that department as well, as the layers can scale with tons of dimension.
There’s a very dominant mid-bass focus on the D8000 DC that punches hard. Its tone is very rumbly and thumpy, vibrating across the sound spectrum with deep resonance. It gives the bass shape and clarity without overwhelming the sound signature in its thick, engrossing response. The DC exhibits tight control while featuring a bass that smoothly passes over transients. You might be looking for a more direct slam, but the DC is more relaxed in that regard. While the mid-bass shows the most meat of the sound signature, the sub-bass also has a presence. It’s more laid back in the mix, but you can always perceive the bass with a clear foundation that blooms with effective depth.
Most of the midrange frequency detail can be found in the low-mids, where the DC features an intimate, warm timbre. With this response, the midrange is capable of showing a ton of weight behind notes, even when the fundamental frequencies are very relaxed. The mids take on an easy-going character, like a mild gloss that doesn’t put a veil on the sound elements. You’ll never sense many incredible artifacts from instruments, but the performances still have clarity and detail associated with them. Everything appears full and easy to define, with vocals making a strong case for its overall ability. While they lack some crispness, vocals blare out with authority, and harmonies dance around them being kept out of the background.
The best aspect of the highs is their height. It’s how the high-end frequencies keep their presence in the sound signature, operating with a level of smoothness that’s easy for anyone to enjoy. They have great detail, and it’s balanced evenly with the rest of the sound signature. They never overexert themselves into anything resembling brightness. They’re kind of a chameleon in the mix, as though their clarity and detail are noticeable, they never call much attention to themselves.
The Final Audio D8000 DC Pro Edition Headphones exemplify a perfect blend of advanced technology, luxurious design, and exceptional auditory performance. With a focus on comfort, an expansive soundstage, and a balanced sonic signature, these headphones elevate the listening experience to new heights. Whether you’re diving into the depths of an orchestral symphony or enjoying the latest album by your favorite artist, the D8000 DC ensures every sound resonates with clarity and richness. For those seeking a top-tier audio experience, investing in the D8000 DC is a decision that promises to deliver hours of immersive enjoyment. Explore the nuances of sound with the D8000 DC and discover a fidelity level that transforms how you listen to music.
The Final Audio D8000 DC is available at Audio46.
Previous articleBeyerdynamic AMIRON 300 Vs Sennheiser Momentum 4 True Wireless Comparison Review
Next articleSpinfit NEO Eartips Review
